28-11-2026, 13:28:51
Autor Tema: Nosač Motora  (Posjeta: 58192 vremena)
Odg: Nosač Motora
« Odgovori #90 u: 11-01-2015, 17:51:02 »
HM a zašto ne kupiti te poliuretanske i zagurati ih u originalne nosače?   Dobro trenutno mi nije na pameti kako izgleda donji nosač motora.
Offline SS
  • Trade Count: (+14)
  • Postova: 2757
  • AR 156 SW 2.4 JTDm 20V
Odg: Nosač Motora
« Odgovori #91 u: 11-01-2015, 17:52:14 »
Pa ja bi isto...ali nema ih baš...
Čini se da ih nitko ne proizvodi  :metak
Nalazio jesam za neke honde al za 156 komplet nema :ne2:
« Zadnja izmjena: 11-01-2015, 17:52:48 od Selespeed »
Nakon prve ide druga...
Odg: Nosač Motora
« Odgovori #92 u: 11-01-2015, 17:54:47 »
Pa vidis da pise za TS ne za dizel  :Hihi: stavi sve pa nam javi kako je  :ok:
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #93 u: 11-01-2015, 18:01:54 »
Ma je... stavim tebi pa ti reci kako ti je  :dick:
Odg: Nosač Motora
« Odgovori #94 u: 11-01-2015, 18:05:40 »
Samo ti sebi stavi  :cool-smiley-027:
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #95 u: 11-01-2015, 18:06:40 »
Eto ga sad na!  :rol:
Tko će koga hahah  :hshake:
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #96 u: 11-01-2015, 18:10:11 »
Evo nekaj o poliuretanima:
C/P od proizvođača
RED color
hardness of about 80 ShA - suspension components have a hardness similar to the original metal-rubber bushes. However, strength of the polyurethane is many times greater, and the unique properties ensure long lasting comfort. We recommend RED products for all "daily use" car users who want improve stability and better driving.
YELLOW color
hardness of about 90 ShA - recommended for racing, sports, tuned cars. The suspension is much stiffer, as at higher speeds is important. Durability ensures stability of polyurethane suspension for many years.
Odg: Nosač Motora
« Odgovori #97 u: 11-01-2015, 18:19:37 »
poliuretan ce tesko ic na dizela.. ovaj gornji nosac je oke jer nema toliko vibracija na njem tj. nelezi motor na njemu.
bocni i straznji (donji) nose motor na sebi i ako nisu ala orginal trese, benzinac ce ic bez problema al dizel tesko.
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #98 u: 11-01-2015, 18:23:55 »
Da..pa mozda i jesi u pravu...jer i ja ih i jesam isprobao na benzicima, imao vozio i stvar je odlicna!
Al eto prvi dizel pa jos malo tapkam u mraku :ok:
Al bumo videli, javim ak kaj pametnoga nađem
« Zadnja izmjena: 11-01-2015, 18:26:46 od Selespeed »
Offline VIPER999
  • Postova: 1525
  • 155 & Alfetta in progress
    • Malinska, Otok Krk
Odg: Nosač Motora
« Odgovori #99 u: 10-03-2015, 07:40:35 »
Kako moja čađara ima garant preko miljun kilometara iza sebe, i sad moram komplet podvozje promjenit zbog akcidenta  :fp: ... bilo bi pametno promjeniti i nosače motora ... definitvno ...
jel tko zna kolko košta komplet nosača motora za 155 1.9 TD ...  :what:
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #100 u: 10-03-2015, 20:19:00 »
uspio sam uglaviti dio nosača od TS-a (gumenog) na dizela i sad je čak i bolje...radi se o onom gornjem nosaču kod poklopca motora  :ok:
  • Postova: 4015
Odg: Nosač Motora
« Odgovori #101 u: 10-03-2015, 20:28:18 »
Sta pasu?
Ja sam stavio od Imperiuma, mozda mrvicu vise vibrira od org, skoro neprimjetno. Ja zadovoljan za 160kn
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #102 u: 10-03-2015, 20:38:31 »
Ha , uz manje prepravke da!
Isprešao sam stari i uprešao stari TS-ove al nekorišteni nutra i stvar je super.
Meni bolje nego origigi jer kod promjena je malo tvrđi i meni se to sviđa.
Nisam škrt kupit novi al kad mi ovaj vec stoji i skuplja prasinu, rekoh zakaj ne?  ::)
  • Postova: 4015
Odg: Nosač Motora
« Odgovori #103 u: 10-03-2015, 20:57:56 »
Novi original je bezobrazno skup, 1100kn kod nas, oko 100€ izvana.
Di si nasao selene koje si upresao?
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #104 u: 10-03-2015, 21:04:33 »
A ostao mi je sa 147 koju sam imao ranije...prodavao prodavao, nitko nije htio kupiti i eto...
Našao svrhu heheh
Je, bezobrazno su skupi original nosači
al koliko gledam nema se baš izbora dok dodje u pitanje koji od glavnih nosača
  • Postova: 4015
Odg: Nosač Motora
« Odgovori #105 u: 10-03-2015, 21:06:32 »
Da, za ove donje samo original.
Al ovaj gore je relativno nebitan, ne nosi neku tezinu, vise umanjuje vibracije kod saltanja i gasa.
Moj je bio na jednom kraju raspadnut, pa da nisam skidao poklopac i cackao nesto drugo, tko zna kad bi primjetio.
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #106 u: 10-03-2015, 21:09:56 »
Old school... ne diraj dok ide hahah  :ok:
Ja nikako naučiti  :craz
Offline Nik1984
  • Postova: 44
Odg: Nosač Motora
« Odgovori #107 u: 02-05-2015, 09:12:28 »
Pitanje za ljude koji su stavljali zamjenske nosace, da li vam jos uvijek vrijede ili su vec otisli? Ja cu trebat sigurno mijenjat onog prednjeg ba sredini, a vrlo vjerojatno i onoga ispod akumulatora pa da se znam pripremit na ishod :D
Odg: Nosač Motora
« Odgovori #108 u: 02-05-2015, 10:39:15 »
najeftinije - original   :da:
Offline RI 156 SW
  • Postova: 202
  • 156 sw 1.9 jtd, sprint 1.3
    • rijeka
Odg: Nosač Motora
« Odgovori #109 u: 02-05-2015, 11:19:40 »
Kako se ponasaju oni akron koje si montirao?
Cijena je primamljiva.
O O == \°/ == O O
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #110 u: 02-05-2015, 11:30:38 »
 :good post
Odg: Nosač Motora
« Odgovori #111 u: 02-05-2015, 13:24:55 »
onaj zadnji nije "isti" kao original, pase sve kad ga stavis ali je drugciji na izgled, i opet je pocela lagano vibrirat kod ubrzanja.  :Angry1:
gledao sam malo po tal forumu i vecina sta ih je mjenjala ponovo mjenjaju ali na original.
interesanto je da nekad je toliko mirna kod ubrzavanja ,mislis da je benzinac a nekad kao da je jedan cilindar kao enduro :kosa:
Offline RI 156 SW
  • Postova: 202
    • rijeka
Odg: Nosač Motora
« Odgovori #112 u: 02-05-2015, 16:40:24 »
Bas steta,originali koda su pozlaceni kostaju.
O O == \°/ == O O
Offline Luka_ri
  • Postova: 2191
Odg: Nosač Motora
« Odgovori #113 u: 02-05-2015, 22:19:24 »
Ja sam stavio taj kriticni kod kabine originalni. Sad bi volio i ostale promijeniti pa sam mislio ostale staviti zamjenske. Ali nemam hrabrosti...a nemam volje davati jos tri milje kuna za glupe nosace. Ima pametnijih stvari...stvarno su zeznuli s tim nosacima...
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #114 u: 02-05-2015, 23:20:55 »
Hehe nisu zeznuli...to su upravo i htjeli!
Kako na japancu nikad u zivotu ne promjeniš nosač?
Mazda koju sam imao 320 t km nikad nista dirano oko nosaca
Offline Luka_ri
  • Postova: 2191
Odg: Nosač Motora
« Odgovori #115 u: 02-05-2015, 23:24:53 »
A drugo je ako je benzinac. Onda je lako. Sto tvrdje to bolje...
Offline SS
  • Postova: 2757
Odg: Nosač Motora
« Odgovori #116 u: 02-05-2015, 23:47:17 »
Ma znam al poanta je ... da su ga htijeli napraviti da traje, napravili bi ga!
Pa nije to raketna znanost i slijetanje Philae na asteroid :hap:
Odg: Nosač Motora
« Odgovori #117 u: 03-05-2015, 08:01:57 »
evo vam kvalitetan motor ali ce te placat nosace  :hehe:
moraju negdje zaradit
Odg: Nosač Motora
« Odgovori #118 u: 03-05-2015, 21:05:11 »
Moraju bit mekani da ublaže vibracije ali nemogu izdrzat vise od 200tkm  :fp: trebao bi netko probat r3parirat sa nekom kvalitetnijom gumom  :da: pa kostat ce 500 kn max
Offline RI 156 SW
  • Postova: 202
    • rijeka
Odg: Nosač Motora
« Odgovori #119 u: 03-05-2015, 21:16:41 »
O tome i ja razmisljam,princip mi neda da iskrcam toliko para za njih  :tooth:
O O == \°/ == O O
