22-11-2026, 07:05:21
Autor Tema: Giulia - modeli pouzdanost  (Posjeta: 46249 vremena)
« u: 18-03-2018, 13:44:07 »
www.kmon.life/2018/03/here-are-all-problems-that-fca-has.html?m=1
 :cofe2:
Here Are All The Problems That FCA Has Attempted To Fix On The Alfa Romeo Giulia
3:00 AM  Alfa Romeo
The Alfa Romeo Giulia is heralding the Italian brand’s comeback to America by embracing
its heritage: providing an amazing driving experience while managing to have failures on a regular basis. Owners are reporting a multitude of issues online, and it seems like every car that gets sent to a journalist has some type of failure that requires a trip back to Michigan.
Despite excellent driving dynamics, the car has gotten a ton of negative press lately, from Jalopnik (whose editors’ Giulia Q2 had to be towed away after just two days) to this gem from hardcore member of the Alfisti, Sam Smith at Road & Track:
I asked C/D’s technical director, Eric Tingwall, if there was a common thread. “They don’t fail with any kind of consistency, in my experience,” he said. “It’s not like there’s just one component that’s causing this. It’s not just Quads, it’s Quads and 2.0-liters, engines and transmissions.” A few weeks ago, when Tingwall left to test the Alfa Stelvio SUV in Tennessee, he reluctantly packed a code reader in his luggage, assuming it might come in handy. He didn’t need it, but, “Within two miles of finishing the drive, I’m pulling up to the hotel, and the auto-start-stop icon on the dash lit up with a warning light next to it.”
The failures are widespread, but explanations are far and few between. Luckily, there is one way we can get an inside look at the issues that Fiat Chrysler has been tracking.
How To Track Problems
Tech Authority is a subscription-based Mopar service site that provides dealer-level service information to independent shops and individuals for a small fee. Selecting the Giulia brings up all the service and parts information along with 11 Technical Service Bulletins (TSBs).
Manufacturers usually release these bulletins for recurring issues that are not safety related. They’re created with input from engineers as well as technicians, and the final repair procedure might be created by either side. TSBs are recommended repairs for non-safety issues and are usually not applied proactively. A customer has to complain about an issue that matches the description of the TSB in order for the repair to be applied.
The next step up for a TSB at FCA is what is called a Rapid Response Transmittal, or RRT. In the case of the Giulia, nine of the 11 TSBs listed on the Tech Authority site are marked as RRTs—that means they carry a bit more importance than a standard TSB as they often recognize issues that appear more often and for a specific range of VINs and may be applied by the dealer proactively to unsold cars or ones that might come in for standard service even if there is not a customer complaint.
Let’s run down the issues, shall we?
Steering Chatter
The first standard TSB for the Giulia is 02-003-17 and it describes a customer complaint of a steering chatter when steering is at full lock. There is no resolution for this one as it states that the customer should be informed that the chatter is a feature of the “AlfaTM Link” technology which allows an Ackerman angle change to provide the lowest amount of understeer in most driving conditions.
This type of bulletin is not isolated to the Giulia as it has appeared for other cars like the Corvette which use similar steering technology and sticky tires.
Stop/Start System, Heating
TSB 24-002-17 is the other standard TSB which covers the Start/Stop system along with the heated seats. The update changes the programming to allow the rear defrost to continue to function during a Start/Stop operation along with turning up the blower fan. It also updates the heated seat logic to start them at max when the button is first pressed.
Brakes
We jump into the RRTs with brake bulletin 05-004-17 which tries to correct an issue where the brake pad wear sensors may get disconnected. The fix seems more backyard mechanic than engineer, as it requires securing a grommet on the harness by wrapping tape on each side of it so it is built up enough to prevent it from sliding down the harness then using a zip-tie to secure the harness to the brake caliper bracket.
Coolant Hose Retainer
RRT 07-004-17 has been through a couple of revisions but seems fairly standard and describes a coolant hose retainer that has been upgraded from a zip-tie style to a clip style retainer in order to prevent it from breaking and causing the hose to be punctured from rubbing. This procedure pays 0.4 warranty hours or 24 minutes which covers the whole time from the technician pulling the car in to completing the repair and pulling it out.
Electrical Issues, Of Course
No Alfa TSB list would be complete without some electrical issues and RRT 08-026-17 is the first one that falls under that category and describes a problem with the body control module that requires an update in order to make the remote start work consistently.
The next one (08-027-17) also requires an update to the BCM along with an update to the radio frequency hub module in order to fix an issue where the forward collision warning system may turn itself off intermittently along with a repair to the fuel gauge to fix an issue where it showed a bar on the fuel gauge even if the tank was empty. I suspect that some of the stalling issues are related to this gauge malfunction as owners might be driving their cars on an empty tank and causing it to stall or shut down.
The largest electrical update is 08-041-17 which covers the infotainment system and some safety equipment. It fixes a wide array of issues such as the screen locking up or the navigation losing signal and not recovering. It also calibrates the oil status display to show the correct oil level.
The best part of the issue list is related to the lane departure warning system as this update fixes an issue where the lane departure options were appearing in cars that were not equipped with the system.
The last electrical bulletin (08-060-17) is an update to the adaptive cruise control to fix an issue where the wheel speed sensors would lose signal, causing that system to malfunction and a DTC to light up.
There is only one engine performance RRT (18-025-17) for the 2.9-liter twin-turbo V6 engine and it corrects an issue that causes the car to lose its immobilizer code after a remote start operation and light up the check engine light for an invalid key.
That Pesky Turbo Four
The 2.0-liter turbocharged four-cylinder engine has a much lengthier engine performance RRT (18-030-17 REV. B) which is now on its third revision and describes an issue that is very similar to the one shared on these pages last week. The RRT describes and array of codes that might be displayed including ones that relate to the throttle body and the evaporative emissions system. It states that the vehicle may experience these issues immediately after fueling and may also be prone to stalling.
There is no explanation on the source of the issues but it does state that all of the affected vehicles were built prior to April 18, 2017 so newer builds might have already been corrected.
Based on the list of codes in the RRT and the relation to fueling, I speculate that that the updates are trying to correct logic for how the car reads fuel level and pressure and how it interacts with evaporative emission systems. These issues may also be related to RRT above since it also deals with improper fuel level.
And The Transmission
The last RRT (21-032-17) in the list covers the 8HP50 transmission in the 2.0-liter models and attempts to correct a condition where customers are experiencing bumping or jerking after a Start/Stop event. This is another software enhancement which does not require any physical repair.
Most of the repairs are short and involve software updates but most also do not pay very much warranty time to the technician. The software updates usually pay out 12 or 24 minutes to the technician to check the VIN against the RRT list, connect a scan tool to check for the condition, connect a battery charger to maintain voltage, and reflash the car along with any calibrations that may be required after the flash. Except for the bulletins related to remote start, most do not have a paying time allotment to road test the car.
These types of bulletins are not unusual for a brand new car, but the frequency and severity of issues seems to be above average and may be related to the rushed development of the car.
These bulletins are also only issues that FCA has recognized as widespread at this point since browsing the owner forums will reveal a multitude of others which may not have been recognized yet. The issues also are not isolated to U.S. market cars as the list of campaigns and updates for the European market is even longer, according the Alfa owner forums.
Requiring multiple revisions for some of these campaigns does not inspire a lot of confidence but many seems to be tied to early builds of the car so the ones coming off the boat now might be improved.
The Giulia has all the right ingredients to be a successful sports sedan, but FCA might need to bake it just a bit longer to work out all the performance issues.
Bozi was born in the land of the Yugo but grew up flipping Chevys in the Southeast US. His automotive background ranges from running a used car sales and service facility to building junkyard LS engines and fixing endurance cars.
« Zadnja izmjena: 19-03-2018, 05:41:22 od a.m.alfa »
Offline alfaholic290gtar
  • Postova: 9
    • split
Odg: Giulia modeli pouzdanost
« Odgovori #1 u: 18-03-2018, 23:58:27 »
u novom top gear clanku je qv giulia koristena kao daily 9 miseci u tih 9 miseci 3 tjedna je bila na popravcima
ima li iko slicna iskustva, jel moguce da je to samo kod qv modela dosta problema sa elektrikon ili mozda kod modela s volanom na desnoj strani?
evo clanak
https://www.topgear.com/car-news/big-reads/whats-living-alfa-giulia-quadrifoglio
AR ima dusu
Sljedeći korisnici su zahvalili na ovom postu: Vedran97
Offline Viktor
  • Član Alfa kluba 17
  • Trade Count: (+21)
  • Postova: 9231
Odg: Giulia - modeli pouzdanost
« Odgovori #2 u: 19-03-2018, 07:29:49 »
Moj šurjak ima Giuliu 2.2 JTD sa manualnim mjenjačem, točno godinu dana i preko 40.000 km. Do san ni jedan jedini problem, pali vozi.
« Odgovori #3 u: 19-03-2018, 10:08:23 »
Dizeli nisu imali problema. Ipak je to evolucija starih motora i dalje se radi u istoj tvornici od 1994. kada su izašli prvi Family B motori.
Sa druge strane benzinci su skroz novi. V6 iako je baziran na Ferrari V8 nije identičan sa detaljima i što je bitno sklapa se u Fiat tvornici gdje radnici nisu navikli na tako sklopljene motore.
No ipak većina problema je vezana za ECU kod benzinaca i ti problemi su u velikoj većini riješeni updateom prije 11 mjeseci.
Offline Ozzy
  • Postova: 437
    • Korcula
« Odgovori #4 u: 19-03-2018, 10:59:02 »
[quote author=S.M. link=topic=93144.msg1859189#msg1859189
[/quote]
Da rijeseni tako da su smanjili snagu motora tj. softverski u ECU zagusili odaziv na gas bez da su vlasnicima ista rekli pa ako primjetis primjetis ako ne nitkome nista. Isto sramota
« Odgovori #5 u: 19-03-2018, 12:17:52 »
Dovraga i bestraga, pa šta sad ti onda nemaš 280 konja?  :? :what:
« Zadnja izmjena: 19-03-2018, 12:18:28 od Flavio »
« Odgovori #6 u: 19-03-2018, 12:22:08 »
Kaže ePER da je snaga sada i veća. Ako se priča o jačoj 2.0 verziji. Sa 276 na cijelih 280 BHP.
Ona kojoj se smanjivalo nešto je verzija sa 197 BHP. No ona je u novijim verzijama i hardverski drugačija. Nema EGR.
« Odgovori #7 u: 19-03-2018, 13:02:57 »
Bez obzira, Alfu prati loš glas i bez dodatnih glasina. Ovo ih samo dodatno zakucava u pod. Na ovaj način im nema povratka u vrh
Sljedeći korisnici su zahvalili na ovom postu: darkoqv
« Odgovori #8 u: 19-03-2018, 13:08:39 »
Mogli su nastaviti proizvoditi AlFiate i to je to
Offline Ozzy
  • Postova: 437
    • Korcula
« Odgovori #9 u: 19-03-2018, 13:11:29 »
Smanjivana je ta sa 200ks ali i ova sa 280ks
« Odgovori #10 u: 19-03-2018, 13:44:35 »
Koliko znam sa Giuliom nema mehaničkih problema.
Da malo potražiš po ostalim proizvođačima onda bi vidio da je za današnje vrijeme ovo nešto sasvim normalno.
E sada, zašto se svi napale na Alfu kod ovih stvari je nešto drugo. Tu oni ne mogu ništa napraviti.
Pa pogledaj sa se prenose po godinu dana stari članci. Zbog čega? Sa kojim ciljom? A piše ih neki Božo Tatarević.
No ne vjerujem da ovo išta znači za Europu gdje je 90% prodaje dizel.
Ne, bar ne u D modu.
Offline boris
  • Postova: 1607
  • 147 Q
« Odgovori #11 u: 19-03-2018, 15:51:31 »
I to je sve još bolje nego šta VW radi sa svojim softwerskim downgradom MILIONIMA ljudi  :fp :fp zbog  NOx afere
I laže ih u oči da se ne smanjuje snaga i samo malo poveća potrošnja.
« Zadnja izmjena: 19-03-2018, 15:58:06 od boris »
Offline boris
  • Postova: 1607
  • 147 Q
« Odgovori #12 u: 19-03-2018, 15:56:13 »
Ruku na srce, nije baš neko veselje da se to dešava, ali detaljno sam pogledao te članke još davno i tu nema aposlutno ništa osim softwerskih upgradova, koji ima više ili manje i kod drugih brandova.
Hoćete da vam pričam o vraćenom M3 nakon godinu i pol dana jer ga nisu znali popraviti. I nije lovačka priča, znam vlasnika.
Offline Ozzy
  • Postova: 437
    • Korcula
« Odgovori #13 u: 19-03-2018, 16:04:45 »
Software upgrade nisu problem. Ali bi bilo fino i posteno da ti netko kaze u lice nismo rjesili sve probleme i bit cete obavjesteni o svakom novom upgradeu
Offline boris
  • Postova: 1607
  • 147 Q
« Odgovori #14 u: 19-03-2018, 16:27:49 »
Mislim da je to više stvar AC-a nego Alfe, a to je več prožvakana priča  :wc:
Mene više brine da ne bude sa MAIR-om stvar kao i sa Giuliettom i ostalim Fiatima
« Zadnja izmjena: 19-03-2018, 16:30:21 od boris »
Offline sasa.baska
  • Postova: 3231
  • Giulia 🍀
    • Baška ' Krk
« Odgovori #15 u: 19-03-2018, 17:37:33 »
 i ja cuo nesto o tom M3 al ne detalje...
Je to bila F80 serija? Sta mu bili?
« Odgovori #16 u: 19-03-2018, 17:38:17 »
« Odgovori #17 u: 19-03-2018, 18:01:37 »
Bilo je situacija kada je otkazivao poslušnost na nezavidnim kilometražama, nekima i nekoliko puta  :dontno:
« Odgovori #18 u: 19-03-2018, 18:08:08 »
A ja imam info od mehaničara ovlaštenog AR servisa u Munchenu da sa multiair motorima nije bilo nikakvih problema.
Offline senk
  • Postova: 302
    • Garešnica
« Odgovori #19 u: 19-03-2018, 18:11:46 »
Koliko se ja sjecam problemi su bili s prvom serijom od prije 5-10 god, ove nove inkarnacije nisam cuo da su nekome radile problema  :dontno:
« Odgovori #20 u: 19-03-2018, 18:14:37 »
Eto kolega Alex sa foruma je imao jedno lijepo iskustvo sa MA motorom u Mitu, ne znam koje godište je bio.
Možda je izuzetak, a možda i nije.
Offline senk
  • Postova: 302
    • Garešnica
« Odgovori #21 u: 19-03-2018, 18:20:42 »
Ne mora biti iznimka, ali i da 10/100 krepa to je dobar prosjek i vikat ce da je super sustav ... normalno ovih 10 se nece sloziti s time, ali ok
Offline KrunoStc
  • Postova: 227
  • giulietta 1.4 Multiair 170ks
« Odgovori #22 u: 19-03-2018, 19:08:47 »
Bilo je slučajeva da ode mair unit i onda ga zamjeniš sa novim unitom za cca soma eur. Taj novi unit se ugrađuje u novije giuliete i navodno nema problema.
najviše problema sam našao na poljskom i Uk forumu sa mair unitom. Jako je osjetljiv na duge intervale zamjene ulja koje prema knjižici treba raditi svakih 30k km što je ludost.
druga stvar je tzv. multi air filter koji košta točno 360kn u AC i koji se mijenja svakih 50k km čak i prije ako se nakupi "smeća".
Ima jedno 5-6 serija mair unita i najvise je problema bilo s ovima 2010godine i prije u giuletama i mitačima. Ako ode zamjeni se i amen, vozis dalje mirno.
također kontaktirao sam AC i Karića i nitko od njih nije imao do sada popravak mair unita odnosno da se netko javio u garanciji ili poslije da je otišao(znam, nema ih puno u RH ali eto).
Moj je mair i koristim iskljucivo ulje prema preporuci iz knjizice+kaj sam zamjenio filter....nadam se da necu imati problema.
« Odgovori #23 u: 19-03-2018, 19:37:21 »
Svaka čast na osvrtu, vidi se da si dobro proučio tematiku!  :respect:
Offline boris
  • Postova: 1607
  • 147 Q
« Odgovori #24 u: 20-03-2018, 10:20:45 »
Nisam ispitivao detalje.
« Odgovori #25 u: 20-03-2018, 10:25:43 »
Nije MAir takav bauk. Prodano je već više milijuna automobila sa MAir sustavom, prije svega u Americi gdje njima svaki osnovni motor da 4 cilindra ima MAir pa 2.4 atmosferac.
No na jednu stvar treba jako paziti, a to je ulje.
« Odgovori #26 u: 20-03-2018, 10:26:02 »
Kužin da to nisu mehanički problemi (o tome ćemo eventualno svjedočit kad Giulie odrade 200 000 km +), i kužin da i prestižnije marke imaju i večih problema ali, to je Alfa koju se gleda tako kako ju se gleda. Neznan šta bi tribali napravit za doć uz bok svetom trojstvu  :what:
« Zadnja izmjena: 20-03-2018, 10:34:24 od noiser »
« Odgovori #27 u: 20-03-2018, 10:48:55 »
Prije svega, spustiti cijenu.
  • Postova: 6639
« Odgovori #28 u: 20-03-2018, 11:05:23 »
Nedavno sam sudjelovao u raspravi i zaključak njurgala je bio da joj nedostaje ekran u većoj rezoluciji...
Svatko gleda ono sto mu je srcu drago.
Sa mojeg gledišta ona nije uz bok nego ih je presisala zbog voznih svojstava koje meni više znače od tog ekrana.
Realno, možda meni ne trebaju bolja voznost od bmw 3 ali onda se isto moze reći i za tu rezoluciju ekrana i taj "nedostatak premium osjećaja".
Kako mrzim tu "premium" frazu. Po svuda se sada koristi a to je tako subjektivno a određuje rezultate testova i time mjenje javnosti.
Pod taj "premium" osjećaj, Mercedesa prodaje 1.5dci za 30000€ u A klasi. Znači pogoni i vozna svojstava su postali ne bitni, glavno da je tu dobar ekran i par detalja na ventilaciji
« Odgovori #29 u: 20-03-2018, 11:08:47 »
Ne bih rekao da je Premium tako lako izdefinirati. Prije svega se radi o dugogodišnjm naporima i ustrajnosti u kvaliteti i održivosti iste, podršci itd.
