30-11-2026, 00:08:38
Autor Tema: Mjenjač (getriba), kvačilo (kuplung) i popratne stvari  (Posjeta: 89208 vremena)
  • Postova: 4371
Odg: Mjenjač (getriba), kvačilo (kuplung) i popratne stvari
« Odgovori #270 u: 23-11-2018, 08:53:37 »
tko maže, taj i vozi  :hap:
znaš da ja samo gledam prilike za upgrade  :hap:
« Odgovori #271 u: 23-11-2018, 08:57:19 »
Poluosovine su spremne ak si zainteresiran za crni petak ponudu  :tooth
Offline R
  • Postova: 317
« Odgovori #272 u: 23-11-2018, 21:55:54 »
:Rock: li
2 kom tj par, kao što je tu i navedeno da je cijena za par?
čem ovo služi?
"These gear linkage bushes are a known problem, giving stiff or slack gear sticks in Alfa Romeo's. They seize up, and causing a progressively worse stiff left to right movement. After time the stiffness will give way completely, providing a completely slack gear change.
These are a simple and cheap fix to a very common problem in Alfa Romeo's.
Remove old bushes, clean up linkage, lubricate and fit new bushes. Price is per pair."
"Reviews:
This is a great buy to fix the common stiff none centralising gear stick. Simple fix for anyone practical & mechanicaly minded. Save a fortune on garage bills. This product as simple as it is; is worth every penny."
Mr. Wolf
  • Postova: 7683
« Odgovori #273 u: 24-12-2018, 13:04:40 »
http://shop.alfisti.net/Tuning-Styling/Alfa-145-146/Motor-Sports-Airfilters/Repair-Kit-For-The-Gear-Lever::8837.html
da li je ovo da ručica mjenjača ne ide lijevo desno u brzini i da bude preciznije šaltanje :?
« Odgovori #274 u: 24-12-2018, 13:09:05 »
Može bit i do toga,al češče je na šalt hebli na getribi problem,a puškice za nju ti ima autolusso  :ok:
Makar sam ja uvjek uspio naštimat bez ičeg  :tooth
  • Postova: 7683
« Odgovori #276 u: 24-12-2018, 15:32:06 »
To sam ja mijenjao na 145 i dobio sam da ručica nema ništa lufta,stavio sam polovno sa 145 sa jako malo km
« Odgovori #277 u: 24-12-2018, 17:54:57 »
Kizo to su semerinzi poluosovina  :fp
« Odgovori #278 u: 24-12-2018, 17:56:31 »
Mislim da ih je neko naručio u gb-u pa tamo vidi. . .
Dva mala crna tuljca
  • Postova: 7683
« Odgovori #279 u: 24-12-2018, 17:57:04 »
reci koje pomogni čovjeku  :redf: :D
ili da ti to meni odradiš :hap:
  • Postova: 7683
« Odgovori #281 u: 24-12-2018, 18:02:39 »
To,da  :ok:
« Odgovori #282 u: 24-12-2018, 18:04:23 »
Jedino iduče godine,ove sam završio. . .  :tooth
  • Postova: 7683
« Odgovori #283 u: 24-12-2018, 18:05:34 »
a ove sam baš na GO :D
« Odgovori #284 u: 24-12-2018, 21:02:23 »
Onda odmori  :hap:
Offline R
  • Postova: 317
« Odgovori #285 u: 20-01-2019, 19:34:29 »
https://newalfaparts.co.uk/home/308-gear-linkage-bushes-top-hat.html
...ovo izgleda ipak nije za sve 147/156 kak piše nego samo za TS/JTS i JTD 1.9 8v CF3.
Kak je onda to riješeno na ostalim motorima/mjenjačima? :Hm
Mr. Wolf
« Odgovori #286 u: 20-01-2019, 21:08:33 »
Zašto?pa navode da je za sve. . . Kaj je drugi fi  :confus:
Offline R
  • Postova: 317
« Odgovori #287 u: 20-01-2019, 22:04:27 »
Nije ni meni jasno, ali kad upišeš tu šifru u ePer ne veže na sve motore.
Za 147 3.2 sigurno ne, čak ih nisam uspio ni pronać na onim slikicama u ePeru.
...i PW veli da nije za sve:
http://vi.vipr.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=230912613622&t=1508428152000&tid=310&category=174104&seller=partsworld-uk&excSoj=1&excTrk=1&lsite=3&ittenable=false&domain=ebay.co.uk&descgauge=1&cspheader=1&oneClk=1&secureDesc=0
Mr. Wolf
« Odgovori #288 u: 20-01-2019, 22:46:22 »
Di bi to išlo uopce tocno, djeluje mi kao piksa na biraču.
« Odgovori #289 u: 20-01-2019, 23:13:14 »
Da,piksa birača  :ok:
L-D
« Zadnja izmjena: 20-01-2019, 23:14:06 od litlebastard »
  • Postova: 7683
« Odgovori #290 u: 20-02-2019, 13:26:32 »
Frenda zanima kakv je automatik u 159 1,9 jtd 2008
Pa pomoć svaka je dobra
Offline Ivanov
  • Postova: 349
    • NA-VI Objekti
« Odgovori #291 u: 11-07-2019, 19:09:19 »
Jel moguce ugurati f40 umjesto m32 mjenjaca na 159 8v. Jel ima ko da je to radio.
Offline Surovi
  • Postova: 884
« Odgovori #292 u: 17-09-2019, 22:21:33 »
Pozdrav!
Jel tko imao problem s vibracijama kod kočenja motorom, ali samo u jednoj brzini?
M32 je u pitanju, naravno  :bic:
Ručica mjenjača vibrira u trećoj brzini kod kočenja motora samo na određenom broju okretaja.
Ne vibrira u drugoj, ne vibrira u četvrtoj, petoj... ne vibrira ako se koči motorom s 3000 na niže, al počne na oko 2500.
Vibracije prestaju ispod oko 1600 okretaja.
Ne vibrira kod ubrzavanja.
Ne iskače iz brzine.
Nema zvukova kako kad ode ležaj niti standardnog micanja  ručice kod promjene brzina (kad ode ležaj).
Iskustvo?
Pretpostavke?
« Zadnja izmjena: 17-09-2019, 22:22:22 od Surovi »
Offline Ivanov
  • Postova: 349
    • NA-VI Objekti
« Odgovori #293 u: 23-09-2019, 15:33:03 »
Pozdrav!
Iskustvo?
Pretpostavke?
Cudno mi je to kod tebe jer je kod mene drugacije a isto m32 i problem su vanjski lezaji unutar getribe. Ima ih 3 kom. dakle oni u poklopcu su dobili lufta i tako je kod svih pa i opela itd.
Desava mi se da samo u 4 trese kod ubrzanja a ostale su dobre. Kod usporavanja nista ne trese.
Probaj prije kocenja ubacit u nutralni polozaj pa stisni kocnicu. Ak opet trese onda nije do getribe.
Zna tresti zbog losih diskova, felga, guma pa mozda pomogne.
Getriba inace suska u neutralnom polozaju i trese pod opterecenjem al i osjetis po mjenjacu kak se krece kad dodas pa pustis gas... bar je tako kod mene.
Nemam sad vremena al ni para jer sam radio veliki servis te komplet kocnice a jos moram nove gume pa kad to sredim onda cu u home made varijanti probat spustit motor i skinut samo poklopac getribe.
Ak to uspijem onda ce ostalo puno lakse pa javim kak je proslo.
Najgore je skidat getribu i pokusat cu taj dio price skratit.
Isto je bilo za 156 kad sam mjenjao getribu svi su pricali mora most dole na kraju sam kod svog mehe bez komplikacija skinuo getribu bez pipkanja oko mosta.
Jedino sto smo otpustili to su nosaci motora i namjestili tako da getriba ispadne.
Naravno ovo je sad 159 al pricam o poklopcu getribe a ne cijeloj getribi ;)
Majstor od kojeg sam kupio alfu kaze da mi nije losa zamisao i da zna za moju getribu i da bi se mozda i moglo tako odradit ili ako ne onda samo most otpustit i mozda nece trebat cijelu getribu skidat skupa sa mostom.
Na autu su radili druge stvari koje su i ovako previse kostale.
Posto je covjek jako dobar ostao sam kod njega jer se kuzi u alfe i iskreno mi je rekao sta se radilo na mojoj 159 i sta jos treba da bi auto bio kak spada.
Inace odlaze bas ti vanjski lezaji zbog nedovoljnog podmazivanja.
Ima za narucit noviji tip poklopca za podmazivanje samih lezaja.
Naravno i nove lezaje trebas. Navodno su kvalitetniji al ne vrijedi jer su opet suhi ko barut jedino su izdrzljiviji.
Da bi posao bio da valja trebas lezaje i noviji model poklopca getribe ili mozda ovaj prepravit ak se da zarezat kanalcic do lezaja.
Sebi sam za pocetak zamjenio ulje plus aditiv 2.7l stvar se popravila al naravno do prvog zahvata koji me uskoro ceka :hat:
Lagano sa gasom ko ja pa se skupiti jer nije pametno vozikat posto uskoro pocme bas trgat lagere unutar lezaja i kad ispadnu podvuku se pod zubcanik i onda krece dernek kojem nema spasa jedino drugu m32 stavit. U glavnom cim prije to bolje.
« Zadnja izmjena: 23-09-2019, 16:17:08 od Ivanov »
Offline Surovi
  • Postova: 884
« Odgovori #294 u: 23-09-2019, 17:10:19 »
Hvala  :ok:
Tvoji simptomi su simptomi koji govore o potrošenosti ležajeva.
Moji su drugačiji. Ova se pojava može javiti zbog hrpe problema.
Loš sinhron, loš nosač motora, loše sajle, loš shifter...problem je što se može pojavljivati i kad ne postoji očiti kvar, odnosno dok je nešto malo potrošeno, ali se još na oko ne vidi  :Crazy dok te male vibracije dospiju do ručice mjenjača postanu veće.
Dobio sam par savjeta iz tvrtki koje rade reparaciju tih mjenjača i svode se na: "Promatraj i čekaj dok ne bude jače."  :tooth
Što se tiče unaprjeđivanja mjenjača, ako planiraš voziti auto još par godina i ako treba nešto raditi na mjenjaču, mislim da se isplati uzeti revidirani poklopac i ležajeve, ali i dodati (napraviti) kit za bolje hlađenje.
https://www.courtenaysport.co.uk/M32-Gearbox-Breather
Jednostavno je i neće koštati ni blizu cijeni koju traže na linku.
Revidirana kutija je dosta bolja, ali još ima problema jer odlazi ležaj koji proje nije odlazio. Bolja je od ove do 2012 i po cirkulaciji ulja i ako je napunjena kako treba, traje dulje  :tooth
Zbog toga su 2017.izbacili treću generaciju pa će vlasnici moži svjedočiti kvaliteti u usporedbi s prethodnicama  :tooth
http://www.wgmotorworks.co.uk/repairs/transmission/m32-gearbox/
« Zadnja izmjena: 23-09-2019, 17:13:56 od Surovi »
Offline aggressor
  • Postova: 169
  • 159 1.9 JTDm
    • Tuzla
« Odgovori #295 u: 24-09-2019, 22:21:01 »
Pozdrav!
Iskustvo?
Pretpostavke?
Zamajac
Ista stvar, treca brzina nakon pustanja gasa u rasponu izmedju 1600-1800 obr.
Vec 3 godina. Nikakvih luftova, ne cuje se mjenjac.
Offline Surovi
  • Postova: 884
« Odgovori #296 u: 24-09-2019, 22:23:45 »
Fala!
I to je jedna od mogućnosti, ali nije u ovom slučaju  :Crazy
Offline Alf
  • Postova: 184
  • 166 2.4jtd 10V 110kW ´03. pFL
    • Zg
« Odgovori #297 u: 14-01-2020, 10:47:16 »
Evo tu bi se nadovezao da ne otvaram novu temu;  znaci 166ica 03god.
Vrisnuo je mali cilindar kvacila u kabini,ali mi se cini da je i opruga pedale sumnjiva. Zna li netko kako treba stajati,gdje? Meni je sad opruga kao zabijena u pod ispod pedale u nekom limu..Nemam referencu jer nisam prije nista prckao po tome i ne znam dali mora biti tu,ili negdje drugdje..mozda brzinska slika za usporedbu ako netko moze okinuti....
Live Long And Prosper!  :Spock
Offline Scatman
  • Postova: 21
« Odgovori #298 u: 26-01-2020, 21:09:43 »
Pozdrav, kakav je 5-brzinski mjenjač u Alfi 147 1.9 jtd 8v? Rade li ga talijani ili general motors? Je li izdržljiviji nego M32?
« Odgovori #299 u: 26-01-2020, 21:34:18 »
Talijanski, drzi momenta ko m32 Mozda i vise i ne raspada se ko m32.
Sljedeći korisnici su zahvalili na ovom postu: Scatman
