14-05-2026, 11:20:58
Autor Tema: Alfa Brera  (Posjeta: 203579 vremena)
Offline SBAlfista
  • Postova: 1552
    • Slavonski Brod
Odg: Alfa Brera
« Odgovori #660 u: 22-01-2016, 15:39:08 »
Bussolina :ok:
Odg: Alfa Brera
« Odgovori #661 u: 22-01-2016, 18:54:14 »
Bussolina :ok:
Kakve tocno ima veze Brera sa Bussom? :D
  • Postova: 14018
Odg: Alfa Brera
« Odgovori #662 u: 22-01-2016, 20:02:53 »
Nije mislio na Đuzepea , nego na autobus , jer ima takve kotače.   :)
Offline SBAlfista
  • Postova: 1552
    • Slavonski Brod
Odg: Alfa Brera
« Odgovori #663 u: 22-01-2016, 20:04:47 »
Jel nemaju Brere Busso sestake??
Odg: Alfa Brera
« Odgovori #664 u: 22-01-2016, 20:08:06 »
Ne
  • Postova: 42909
Odg: Alfa Brera
« Odgovori #665 u: 22-01-2016, 20:13:16 »
Six-cylinder
3.2
The JTS direct injection system was first used in a V6 engine in 2005 with the introduction of the Alfa 159 and Brera. This is not related to the Alfa Romeo V6 engine, but is instead a derivation of the GM High Feature engine; built in Australia by GM Holden. While it retains the High Feature engine's 89 mm (3.5 in) bore, 85.6 mm (3.37 in) stroke and chain driven camshafts. It is modified by Alfa for their performance, fuel economy and sound characteristics. These modifications include: "TwinPhaser" variable valve timing (cam-phasing on both inlet and exhaust cams, thus the name), gasoline direct injection and a higher compression ratio of 11.25:1. It also operates with a lean burn system up to about 1500 rpm,[4] as on many other engines from the company. And is capable of generating 191 kW (260 PS; 256 hp), a number matching the larger LY7 3.6 L variant used by GM. Alfa Romeo stopped using the V6 JTS engine in 2010.
    Displacement: 3,195 cc (195.0 cu in)
    Power: 191 kW (260 PS; 256 hp) at 6200 rpm
    Torque: 322 N·m (237 lb·ft) at 3800 rpm
Applications:
    2004 Alfa Romeo Visconti (concept car)
    2005–2010 Alfa Romeo 159
    2005–2010 Alfa Romeo Brera
    2006–2010 Alfa Romeo Spider
Offline SBAlfista
  • Postova: 1552
    • Slavonski Brod
Odg: Alfa Brera
« Odgovori #666 u: 22-01-2016, 20:18:25 »
Ne
Onda pardon :ok:
Six-cylinder
3.2
Applications:
Hvala :da: :ok:
Offline Fabrizio Giovanardi
  • Trade Count: (-1)
  • Postova: 2351
  • Giulia 2.0 Competizione
Odg: Alfa Brera
« Odgovori #667 u: 23-01-2016, 22:59:13 »
Malo mi se rasklimala rucica mjenjaca. Jel zna netko kako to rijesiti? Cuo sam da se skine onaj aluminijski poklopcic i da je ispod poslic za kljuc 10. Jel to tocno?
Alfa nel cuore
  • Postova: 21701
Odg: Alfa Brera
« Odgovori #668 u: 23-01-2016, 23:02:33 »
Da
Poslano sa mog SM-T810 koristeći Tapatalk
  • Trade Count: (-1)
  • Postova: 2351
Odg: Alfa Brera
« Odgovori #669 u: 23-01-2016, 23:04:14 »
Ima neka fora kako skinuti taj poklopac da ga ne zgulim/ostetim? Jel ima kakve kopce ili...?
Alfa nel cuore
Stromboli
Odg: Alfa Brera
« Odgovori #670 u: 24-01-2016, 08:56:24 »
Nema kopce, drze ga dva nastavka sa strane. Samo zavuces nesto ispod poklopca i na gore lagano, videces uosatalom kako se pomera.
  • Postova: 42909
Odg: Alfa Brera
« Odgovori #671 u: 25-01-2016, 05:53:30 »
  • Postova: 42909
Odg: Alfa Brera
« Odgovori #672 u: 31-01-2016, 21:46:08 »
  • Postova: 21671
Odg: Alfa Brera
« Odgovori #673 u: 01-02-2016, 17:59:02 »
Offline superME
  • Postova: 293
    • Zagreb, Dubrava
Odg: Alfa Brera
« Odgovori #674 u: 02-02-2016, 22:32:00 »
Offline brerra92
  • Postova: 2
    • novska
Odg: Alfa Brera
« Odgovori #675 u: 06-02-2016, 17:28:38 »
Koje gume staviti na breru 19 cola thomason tn1??
Helppp
Odg: Alfa Brera
« Odgovori #676 u: 06-02-2016, 18:00:10 »
Helppp
235/40/19
  • Trade Count: (-1)
  • Postova: 2351
Odg: Alfa Brera
« Odgovori #677 u: 11-02-2016, 14:59:58 »
Danas sam se dvaput mimoišao na Zagrebačkoj cesti s crnom Brerom, zagrebačka rega, završava na FN čini mi se. Dobro izgleda auto. Jel znamo čije je to?
Alfa nel cuore
Offline Niko
  • Postova: 3471
    • ŠIBENIK
Odg: Alfa Brera
« Odgovori #678 u: 11-02-2016, 16:54:43 »
Koje felge ima?
  • Trade Count: (-1)
  • Postova: 2351
Odg: Alfa Brera
« Odgovori #679 u: 11-02-2016, 17:09:35 »
 :) Tvoja bivsa mi je odmah pala na pamet.
Takve iste, 8C antracit, i cini mi se ponizena malo.
Alfa nel cuore
Offline Niko
  • Postova: 3471
    • ŠIBENIK
Odg: Alfa Brera
« Odgovori #680 u: 11-02-2016, 19:35:26 »
Moguce da je moja bivsa, antracit 8C i eibach...
  • Postova: 42909
Odg: Alfa Brera
« Odgovori #681 u: 12-02-2016, 07:12:39 »
Offline Italofan
  • Postova: 1189
  • Bravo Sport, 33 1.5 ie S
    • SLO - Il. Bistrica
Odg: Alfa Brera
« Odgovori #682 u: 12-02-2016, 11:39:16 »
Uuuu...  :love: :love: :love: krasan auto, jel može još koja sa strane :?
Offline sfreak
  • Postova: 2112
    • Jadranovo
Odg: Alfa Brera
« Odgovori #683 u: 12-02-2016, 11:43:57 »
to je ona pred par strana za koju si vec kometirao da je dobra...stavio sam ju ja...
sad vidim da slike ne rade
Offline alfazara
  • Postova: 2737
  • 155 1.8
Odg: Alfa Brera
« Odgovori #684 u: 12-02-2016, 14:00:04 »
Alfa  u <3
  • Postova: 42909
Odg: Alfa Brera
« Odgovori #685 u: 22-02-2016, 20:29:25 »
Odg: Alfa Brera
« Odgovori #686 u: 12-03-2016, 13:09:09 »
Odg: Alfa Brera
« Odgovori #687 u: 12-03-2016, 14:38:11 »
Uuuu felge su mi zasad jedine koje mi se svidaju osim TI  :love: Jedino sto je ovo 20" Koje su to felge?
Offline sfreak
  • Postova: 2112
    • Jadranovo
Odg: Alfa Brera
« Odgovori #688 u: 12-03-2016, 14:49:00 »
Lorinser RS8...ili neka kopija istih
Odg: Alfa Brera
« Odgovori #689 u: 12-03-2016, 15:01:38 »
