17-10-2026, 21:15:57
Autor Tema: Fiat Barchetta  (Posjeta: 6461 vremena)
Fiat Barchetta
« u: 19-08-2010, 17:14:11 »
The Fiat Barchetta (pronounced "bar-KET-ta") is a roadster produced by the Italian manufacturer Fiat from 1995 to 2005 (though production was paused between May 2002 and 2004). "Barchetta" in Italian means 'little boat'.
History
The Barchetta was developed between 1990 and 1994 under the project name Tipo B Spider 176. It was designed by Andreas Zapatinas, Alessandro Cavazza under the supervision of Peter Barrett Davis and other car designers at the Fiat Centro Stile, and prototyping was carried out by Stola.
Production began in February 1995 and lasted until June 2005 with a brief pause. The Barchetta was based on the chassis of the Mark 1 Fiat Punto. The Barchetta has 1747 cc dohc petrol engine fitted variable camshaft timing, for the first time in Fiat production car.The engine has 131 PS (96 kW; 129 hp) and 164 N·m (121 lb·ft) of torque. The Barchetta weighs 1056 kg (2328 lb) without air conditioning and can accelerate to 100 km/h (62 mph) in 8.9 seconds and has top speed of 118 miles per hour (190 km/h).It came in various trim levels which offered different features. Arguably one of the biggest external cosmestic changes was made by the addition of the third brake light, first introduced by Fiat on the Lido and Riviera in 2000, and on sub models thereafter.
The Barchetta was revised in 2003 for its relaunch the following year, with a myriad of small alterations inside and out. The most notable changes were the revised front spoiler and rear bumper. Production of the car finally stopped in June 2005.
 Production
Car bodies were welded at ILCAS in Sparone Canavese, and final assembly was done in Chivasso by the coachbuilder Maggiora. After Maggiora's bankruptcy in 2002, Fiat relocated production of the Barchetta to its Mirafiori plant and resumed production two years later. Production of the Barchetta was limited to left hand drive cars only, even though the car was marketed and sold in two right hand drive markets, the United Kingdom and Japan.
« Zadnja izmjena: 08-05-2016, 09:43:49 od a.m.alfa »
Odg: Fiat Barchetta
« Odgovori #1 u: 19-08-2010, 17:19:45 »
Barchetta GULF
« Zadnja izmjena: 02-03-2020, 15:30:55 od a.m.alfa »
  • Postova: 4704
Odg: Fiat Barchetta
« Odgovori #2 u: 15-06-2011, 10:09:32 »
Prekrasan auto, tim više kaj uz Coupea, pričamo o autima dizajniranim oko 1993. godine, tj prije skoro 20 godina
Offline Azzurro
  • Postova: 121
Odg: Fiat Barchetta
« Odgovori #3 u: 29-09-2011, 09:58:17 »
Dobar dizajn nema rok trajanja. Stvarno lijepi auto.
Offline zvrk
  • Postova: 386
    • Zagreb - Kvatrić
    • www.potrcko.com.hr
Odg: Fiat Barchetta
« Odgovori #4 u: 29-09-2011, 10:17:35 »
Fiat Barchetta Maggiora Coupe 1995.
Nažalost, ovaj coupe nikad nije ugledao svjetlo dana (osim ovog jedinog primjerka) jer su u Fiatu odlučili da ga neće proizvoditi jer su već imali Barchettu cabrio, pa su zaključili da im ne treba sličan proizvod.
Maggiora nije imala kapacitet da nastavi proizvodnju ovog modela, tako da je sve ostalo na tom jedinom primjerku.
Stola Dedica Fiat Barchetta 1995.
The Fiat Barchetta Dedica by Stola ima 2 litre 16V turbo motor iz Fiat Coupea sa 262 ks, ukupne težine 1020 kg, ubrzanje 0-100 km/h in 5.8 sekundi i max. brzinu od 270 km/h.
Stola je planirao proizvodnju od 50 komada za Japansko tržište...
Još jedan primjerak na bati Barchette je bio napravljen, ali od strane Abartha...
Stola Abarth Monotipo 1998
Razvijan je i testiran 2 godine da bi sudjelovao na Supercar Rally 2002.
Motor je bio posuđen iz Lancie Delte Integrale sa 335ks, karbonska karoserija na šasiji Barchette sa ukupnom težinom od 880kg, ubrzanje 0-100 km/h za 4.9 sekunde i max. brzinom od 290 km/h.
potrčko
Offline clubber
  • Postova: 206
    • BIH
Odg: Fiat Barchetta
« Odgovori #5 u: 29-09-2011, 10:20:13 »
Ovaj Coupe baš nosi duh 850 Sport i sličnih kupea iz 70-ih iz kuće FIAT - šteta što se nije proizvodio, ali vjerovatno nije bilo mjesta kraj Coupe-a.
  • Postova: 4704
Odg: Fiat Barchetta
« Odgovori #6 u: 29-09-2011, 13:44:00 »
Ovaj monotipo od prije 10 godina bi mogao tak kak je direkt u serijsku proizvodnju-PREDOBAR
Ova verzija Barchette coupe i je i nije dobra, mislim da je cabrio ipak pun pogodak
Odg: Fiat Barchetta
« Odgovori #7 u: 10-04-2012, 23:29:02 »
po OS se odnedavno(ili je ja nisam vidio prije) voza žuta,cupea nevolim ni vidit jer mi je gadan,ali ovo je stvarno pravi mali ferrari  :love:
Odg: Fiat Barchetta
« Odgovori #8 u: 20-09-2014, 10:25:41 »
« Zadnja izmjena: 14-09-2018, 19:28:35 od a.m.alfa »
Odg: Fiat Barchetta
« Odgovori #9 u: 14-02-2016, 08:50:33 »
Fiat Barchetta Concept - Bertone
« Zadnja izmjena: 02-03-2020, 15:32:52 od a.m.alfa »
Odg: Fiat Barchetta
« Odgovori #10 u: 08-05-2016, 09:40:05 »
Maggiora
« Zadnja izmjena: 02-03-2020, 15:36:08 od a.m.alfa »
Offline VIPER999
  • Postova: 1525
  • 155 & Alfetta in progress
    • Malinska, Otok Krk
Odg: Fiat Barchetta
« Odgovori #11 u: 24-11-2016, 07:46:44 »
Ima tko kakvih iskustva s Barchettom ... plusevi i minusi ... za održvanje vidima da je to Punto 1 ... a za ostalo ne znam ... pa svaki savjet je dobrodošao ... :mah:
Odg: Fiat Barchetta
« Odgovori #12 u: 14-09-2018, 19:28:55 »
Offline mikela
  • Postova: 2221
    • dugopolje-hvar-split
Odg: Fiat Barchetta
« Odgovori #13 u: 15-09-2018, 12:54:41 »
cisti talijanski hedonizam..... :love:
Odg: Fiat Barchetta
« Odgovori #14 u: 28-11-2018, 17:51:25 »
Online Big D
  • Postova: 3656
Odg: Fiat Barchetta
« Odgovori #15 u: 13-11-2019, 23:20:31 »
Momci, kolega traži tvrdi krov za Barchettu, pa ako tko ima...
Odg: Fiat Barchetta
« Odgovori #16 u: 01-03-2020, 19:48:18 »
« Zadnja izmjena: 02-03-2020, 15:37:23 od a.m.alfa »
Odg: Fiat Barchetta
« Odgovori #17 u: 28-03-2020, 09:19:09 »
Offline nino
  • Postova: 24
    • Zagreb zapad
Odg: Fiat Barchetta
« Odgovori #18 u: 28-03-2020, 09:41:13 »
U očekivanju (ne Gotota)
već "faceliftinga".
A tak sam se veselil ovom ljetu.
Solo Alfa
Odg: Fiat Barchetta
« Odgovori #19 u: 16-06-2020, 19:14:01 »
Offline nino
  • Postova: 24
    • Zagreb zapad
Odg: Fiat Barchetta
« Odgovori #20 u: 21-06-2020, 07:38:22 »
Picolla Barchetta.....
Solo Alfa
Offline nino
  • Postova: 24
    • Zagreb zapad
Odg: Fiat Barchetta
« Odgovori #21 u: 04-09-2020, 14:10:04 »
Quattroruote iz 1995 sa prvom reportažom o Fiat Barchetti.
Prekrasan naslov "Luda želja"
Eto tko traži taj i nađe.
Solo Alfa
Odg: Fiat Barchetta
« Odgovori #22 u: 28-02-2021, 09:27:01 »
  • Postova: 726
Odg: Fiat Barchetta
« Odgovori #23 u: 19-03-2021, 15:15:39 »
