If it is not possible to deactivate the engine inhibitor with the Alfa Romeo CODE system, the CODE and 'immobiliser' warning lights stay on and the engine will not start. Emergency starting is needed to start the engine.
WARNING You are advised the carefully read the entire proceedure before carrying it out.
If a mistake is made during the emergency procedure, the ignition should be turned to stop and the operations must be repeated from start (point 1).
1) Read teh 5-figure electronic code on the CODE card.
2) Thurn the ignition to MAY.
3) Fully depress the accelerator pedal and keep it pressed. The immobiliser light will come on for eight seconds and then go off, now release the accelerator pedal.
4) The immobiliser warning light begins to flash: after it has flashed the same number of times as the first digit on the CODE card, press the accelerator pedal and keep it pressed until the immobiliser warning light turns on (for four seconds) and then goes off, now release the accelerator pedal.
5) The immobiliser warning light starts to flash: after the number of flashed corresponding to the second digit on the CODE card, press the accelerator pedal and keep it pressed.
6) Repeat this procedure for the remaining digits on the CODE card.
7) After entering the last figure, keep the accelerator pedal pressed. The immobiliser warning light turns on (for four seconds) and then goes off; now release the accelerator pedal.
8) A quick flash of the immobiliser warning light (for about four seconds) confirms that the operation has been carried out correctly.
9) Start the engine turning the ignition key from MAR to AVV without returning the key to the STOP position.
Conversley, if the immobiliser warning light stays on, turn the key to STOP and repeat the procedure staring from point 1.
WARNING After emergency starting it is advisable to contact an Alfa Romeo authorised service, because the emergency procedure must be repeated each time the engine is started.
