29-11-2026, 21:25:32
Autor Tema: OBD kodovi - greške  (Posjeta: 122884 vremena)
0 Članova i 16 Gostiju pregledava ovu temu.
Boxer
OBD kodovi - greške
« u: 18-09-2010, 21:18:54 »
Uživajte :mah: :mah:
Bosch Motronic ME 1.5.5 Error codes
P0100 Air- mass sensor above upper limit
P0100 Air- mass sensor below lower limit
P0110 IAT sensor short to earth
P0110 IAT sensor open circuit/positive short
P0115 Coolant temperature sensor short to earth
P0115 Coolant temperature sensor signal improbable
P0115 Coolant temperature sensor open circuit/positive short
P0120 Throttle valve potentiometer short to earth
P0120 Throttle valve potentiometer open circuit/positive short
P0130 Oxygen sensor short to earth
P0130 Oxygen sensor open circuit
P0130 Oxygen sensor short to B+
P0170 Lambda control above upper limit
P0170 Lambda control below lower limit
P0201 Injection valve cylinder 1 short to earth
P0201 Injection valve cylinder 1 open circuit
P0201 Injection valve cylinder 1 short to B+
P0202 Injection valve cylinder 2 short to earth
P0202 Injection valve cylinder 2 open circuit
P0202 Injection valve cylinder 2 short to B+
P0203 Injection valve cylinder 3 short to earth
P0203 Injection valve cylinder 3 open circuit
P0203 Injection valve cylinder 3 short to B+
P0204 Injection valve cylinder 4 short to earth
P0204 Injection valve cylinder 4 open circuit
P0204 Injection valve cylinder 4 short to B+
P0230 Electric fuel pump relay short to earth
P0230 Electric fuel pump relay open circuit
P0230 Electric fuel pump relay short to B+
P0325 Knock sensor 1 signal improbable
P0335 Speed sensor no signal
P0336 Reference mark signal not in range
P0340 Phase sensor earth short
P0340 Phase sensor open circuit/positive short
P0443 Fuel evaporation/regeneration valve short to earth
P0443 Fuel evaporation/regeneration valve open circuit
P0443 Fuel evaporation/regeneration valve short to B+
P0480 Cooler fan relay 1 short to earth
P0480 Cooler fan relay 1 open circuit
P0480 Cooler fan relay 1 short to B+
P0481 Cooler fan relay 2 short to earth
P0481 Cooler fan relay 2 open circuit
P0481 Cooler fan relay 2 short to B+
P0483 Cooler fan control signal improbable
P0560 Battery voltage too low
P0560 Battery voltage too high
P0605 Control unit digitl.compont.(comp.) faulty
P0654 Engine sensor short to earth
P0654 Engine sensor short to B+
P1172 Lambda adaptat. 2 (additive) above upper limit
P1172 Lambda adaptat. 2 (additive) below lower limit
P1173 Lambda adaptat. 1 (multiplicative) above upper limit
P1173 Lambda adaptat. 1 (multiplicative) below lower limit
P1325 Control unit knock control module faulty
P1511 Idle actuator, throttle plate potentiometer short to earth
P1511 Idle actuator, throttle plate potentiometer open circuit/positive short
P1512 Idle control: regulation range not in range
P1512 Idle control: regulation range at maximum stop
P1512 Idle control: regulation range at minimum stop
P1513 Idle actuator circuit short to earth
P1513 Idle actuator circuit open circuit
P1513 Idle actuator circuit short to B+
P1531 A/C compressor short to earth
P1531 A/C compressor short to B+
P1653 Camshaft timing control short to earth
P1653 Camshaft timing control open circuit
P1653 Camshaft timing control short to B+
P1654 Intake-manifold change-over short to earth
P1654 Intake-manifold change-over open circuit
P1654 Intake-manifold change-over short to B+
D600 Immobilizer signal improbable
Bosch Motronic ME 2.1 Error codes
P0100 Air- mass sensor signal improbable
P0100 Air- mass sensor no signal
P0110 IAT sensor signal improbable
P0110 IAT sensor above upper limit
P0110 IAT sensor below lower limit
P0110 IAT sensor no signal
P0115 Coolant temperature sensor above upper limit
P0115 Coolant temperature sensor below lower limit
P0115 Coolant temperature sensor no signal
P0120 Throttle-valve position sensor signal improbable
P0120 Throttle-valve position sensor above upper limit
P0120 Throttle-valve position sensor below lower limit
P0120 Throttle-valve position sensor no signal
P0130 Oxygen sensor, bank 1 signal improbable
P0130 Oxygen sensor, bank 1 above upper limit
P0130 Oxygen sensor, bank 1 below lower limit
P0130 Oxygen sensor, bank 1 no signal
P0135 Oxy. sensor, heater circuit, bank 1 Heating too weak
P0135 Oxy. sensor, heater circuit, bank 1 open circuit
P0135 Oxy. sensor, heater circuit, bank 1 current too high
P0135 Oxy. sensor, heater circuit, bank 1 Plausibility error
P0150 Oxygen sensor, bank 2 signal improbable
P0150 Oxygen sensor, bank 2 above upper limit
P0150 Oxygen sensor, bank 2 below lower limit
P0150 Oxygen sensor, bank 2 no signal
P0155 Oxy. sensor, heater circuit, bank 2 Heating too weak
P0155 Oxy. sensor, heater circuit, bank 2 open circuit
P0155 Oxy. sensor, heater circuit, bank 2 current too high
P0155 Oxy. sensor, heater circuit, bank 2 Plausibility error
P0201 Injection valve cylinder 1 Plausibility error
P0202 Injection valve cylinder 2 Plausibility error
P0203 Injection valve cylinder 3 Plausibility error
P0204 Injection valve cylinder 4 Plausibility error
P0205 Injection valve cylinder 5 short to earth
P0205 Injection valve cylinder 5 open circuit
P0205 Injection valve cylinder 5 short to B+
P0205 Injection valve cylinder 5 Plausibility error
P0206 Injection valve cylinder 6 short to earth
P0206 Injection valve cylinder 6 open circuit
P0206 Injection valve cylinder 6 short to B+
P0206 Injection valve cylinder 6 Plausibility error
P0220 Accelerator position sensor signal improbable
P0220 Accelerator position sensor above upper limit
P0220 Accelerator position sensor below lower limit
P0220 Accelerator position sensor no signal
P0221 Accel. pedal sensor, full-load stop signal improbable
P0221 Accel. pedal sensor, full-load stop above upper limit
P0221 Accel. pedal sensor, full-load stop below lower limit
P0221 Accel. pedal sensor, full-load stop no signal
P0230 Electric fuel pump relay Plausibility error
P0325 Knock sensor 1 above upper limit
P0325 Knock sensor 1 below lower limit
P0325 Knock sensor 1 no signal
P0330 Knock sensor 2 signal improbable
P0330 Knock sensor 2 above upper limit
P0330 Knock sensor 2 below lower limit
P0335 Crankshaft position sensor signal improbable
P0335 Crankshaft position sensor above upper limit
P0335 Crankshaft position sensor below lower limit
P0335 Crankshaft position sensor no signal
P0340 Camshaft position sensor signal improbable
P0340 Camshaft position sensor above upper limit
P0340 Camshaft position sensor below lower limit
P0340 Camshaft position sensor no signal
P0443 Fuel evaporation/regeneration valve Plausibility error
P0480 Cooler fan relay 1 Plausibility error
P0481 Cooler fan relay 2 Plausibility error
P0500 Vehicle speed signal signal improbable
P0500 Vehicle speed signal above upper limit
P0500 Vehicle speed signal below lower limit
P0500 Vehicle speed signal no signal
P0505 Idle speed control above upper limit
P0505 Idle speed control below lower limit
P0505 Idle speed control Plausibility error
P0505 Idle speed control No control
P0560 Battery voltage Plausibility error
P0650 Fault lamp, engine control short to earth
P0650 Fault lamp, engine control open circuit
P0650 Fault lamp, engine control short to B+
P0650 Fault lamp, engine control Plausibility error
P0654 Signal output for tachometer short to earth
P0654 Signal output for tachometer open circuit
P0654 Signal output for tachometer short to B+
P0654 Signal output for tachometer Plausibility error
P1120 Throttle valve control unit short to earth
P1120 Throttle valve control unit open circuit
P1120 Throttle valve control unit short to B+
P1120 Throttle valve control unit Plausibility error
P1325 Control unit knock control module not in range
P1325 Control unit knock control module no function
P1325 Control unit knock control module Plausibility error
P1331 Air conditioner compressor relay Plausibility error
P1531 Air conditioner compressor relay short to earth
P1531 Air conditioner compressor relay open circuit
P1531 Air conditioner compressor relay short to B+
P1555 Stop-lamp switch short to earth
P1555 Stop-lamp switch open circuit
P1555 Stop-lamp switch short to B+
P1555 Stop-lamp switch Plausibility error
P1565 Operating lever, cruise control short to earth
P1565 Operating lever, cruise control short to B+
P1565 Operating lever, cruise control no signal
U1600 Immobilizer signal improbable
U1601 CAN communication short to earth
U1601 CAN communication signal improbable
U1601 CAN communication short to B+
U1601 CAN communication no signal
P1690 Safety fuel-shut-off device no function
P1690 Safety fuel-shut-off device Plausibility error
P1690 Safety fuel-shut-off device Function active
U1700 CAN bus gearbox control unit short to earth
U1700 CAN bus gearbox control unit signal improbable
U1700 CAN bus gearbox control unit short to B+
U1700 CAN bus gearbox control unit no signal
« Zadnja izmjena: 20-04-2013, 22:15:14 od a.m.alfa »
Offline batko
  • Postova: 455
  • Alfa Romeo 156 2.4 JTD
    • Sarajevo BiH
Odg: OBD kodovi - greške
« Odgovori #1 u: 26-05-2011, 17:11:32 »
Znali neko šta znači greška P2148, tj koji je kvar šta prestavlja
radi se o alfi 156 1.9 jtdM 110 kw
Batko
« Odgovori #2 u: 26-05-2011, 18:38:31 »
Fuel Injector Group "A" Supply Voltage Circuit High - šta god to značilo... :hap:
Offline Dj
  • Postova: 44
  • Bella
    • Holandija
« Odgovori #3 u: 20-04-2012, 18:17:15 »
Dali neko mozda zna sta znaci kod 380 dali je u pitanju relej za grijace ili grijaci danas sam vozio alfu na dijagnostiku tamo su mi ocitali da je greska 380 to jest cod posto nije ovlasteni servis ne mogu da preciziraju dali su u pitanju grijaci ili pak rele :ne2:
« Zadnja izmjena: 20-04-2012, 19:42:01 od Argor »
« Odgovori #4 u: 20-04-2012, 18:22:56 »
P0380 - Glow Plug/Heater Circuit "A" Malfunction.
It's not the plugs themselves, but check the supply to them and make sureall connections are secure.
Offline Dj
  • Postova: 44
  • Bella
    • Holandija
« Odgovori #7 u: 20-04-2012, 20:32:43 »
u pitanju je coda 380  ne 0380
...code 380, je u biti P0380...
Offline Dj
  • Postova: 44
  • Bella
    • Holandija
« Odgovori #8 u: 21-04-2012, 21:25:43 »
ok u pravu si sudeci po linku kojeg si postavio kod mene je riknuo relej grijaca ili vec kako se naziva to kod nas
Offline alfa156sarajevo
  • Postova: 708
  • AR 147FL 1.9JTD 2005
    • Sarajevo, BiH
« Odgovori #9 u: 17-05-2012, 12:51:13 »
u 98% slucajeva kada se na dijagnostici iscita greska P0380 ona znaci da je jedan ili vise grijaca neispravan.
ima slucajeva da ode relej grijaca, mada je to bas rijetko...
p.s. ovo vazi za sve jtd motore do 2005/ 6. godine... :hap:
zk001
« Odgovori #10 u: 13-02-2013, 14:17:39 »
Pozdrav
da li iko zna što znače ovi kogodi grešaka?
B1971-
0F07 ili OF07-
99722-
Riječ je o Alfi 147 JTD 2001-
Unaprijed hvala
Offline Bender
  • Postova: 85
  • Alfa 156 SW 1.9 JTD 16V MJET
« Odgovori #11 u: 15-02-2013, 18:07:54 »
Jutros u garaži sjednem, upalim auto, a kad ono upali se check engine i pise na BC-u engine control system error, go to dealer. Dan prije nikakvih naznaka problema, niti se otvarala hauba, niti se divljalo s autom.
Očitah ja poslije posla grešku u fiat ecu scanu i on kaže: P0480 Cooling fan relay error
Probam napravit iz FES-a test ventilatora, prvi ne pali, dok drugi uredno upali nekoliko puta koliko već mora u tom testnom ciklusu. E sad, pogledao sam osigurače na akumulatoru za koje piše da su za ventilator 1 i 2 i to čini mi se 60 i 40 A i oni su ok, probao sam zamijenit releje za ventilatore 1 i 2 pošto su jednaki i opet ista stvar, test ventilatora 2 prolazi a jedinice ne, dakle ne pali se prilikom testa.
Što dalje činiti? Gdje bi mogao još biti problem?
« Zadnja izmjena: 15-02-2013, 19:20:23 od Argor »
Offline Bender
  • Postova: 85
« Odgovori #13 u: 04-03-2013, 17:53:33 »
Evo da podijelim sa svima, malo WD-a po kontaktima konektora na ventilatoru i konektora na otporniku riješilo problem do daljnjeg...
Offline huan
  • Trade Count: (-1)
  • Postova: 53
  • 156-ica
    • Kutina
« Odgovori #14 u: 07-03-2013, 12:03:32 »
Radi se o AR147 1.6TS IZ 2001g sa 105ks.....pali mi gresku P0420--Sustav katalizatora, grupa 1 - učinkovitost ispod granice.
Dal je netko imao takav problem i kako ga rijesiti?
Offline Marko11
  • Postova: 659
  • PUG 508
« Odgovori #15 u: 11-04-2013, 19:51:12 »
Pozdrav, 156, 1.8TS, centrala je bosch motronic 7.3.1. EOBD injection, izbacuje mi kod greske P1680 "motorized throttle ( spring)", ima li tko kakvu ideju???
« Zadnja izmjena: 11-04-2013, 20:04:31 od Marko11 »
Offline NeoSky
  • Postova: 1649
    • BIH
« Odgovori #16 u: 11-04-2013, 20:55:18 »
Alfa 166 2.0 V6 Turbo...
Izbacuje mi navedenu gresku i gas se jednostavno oduzme... Mislim ide on al nije to to...
Sta trebam promijeniti i gdje se to nalazi?? :)
Zvone_ri
« Odgovori #17 u: 19-04-2013, 22:32:28 »
Pozdrav svima. evo imam jedno pitanje.
Danas mi auto cijelo vrjeme radi na 1200-1300 nikako nece dole. A kad stanem na semaforu mi varaju okretaji od 800-2000 rpm i kad se smiri stane na 1200-1300 rpm. Spoio sam ga maloprije na komp i javio mi je sljedecu gresku.
P1654 v.i.s. control
Fault status: Open circuit
Engine speed: 1040 rpm
Engine temperature: 97.2 *C
Dali je netko imao slican problem  a ako nije mozda mi moze pomoc. Hvala :(
« Odgovori #18 u: 19-04-2013, 22:37:24 »
Zvone_ri
« Odgovori #19 u: 19-04-2013, 22:43:15 »
Da to sam i ja nasao ali me je to dovelo do zakljucka da bi to mogo biti neki senzor temperature. jel to moguce
« Odgovori #20 u: 19-04-2013, 22:50:44 »
To bi bio neki senzor na usisnoj grani, možda MAF, pokušaj posuditi ispravni od nekoga.
« Odgovori #21 u: 20-04-2013, 08:40:09 »
mislim da v12 u lambu nema taj senzor, potrazi dalje gresku   :hello:
alfist166
« Odgovori #22 u: 22-07-2013, 01:58:37 »
Pozdrav svima
Stigla iz Italije nova alfica 156 JTDM 2004 god.
Auto bombon no pojavila se greška na motoru.
Frend sa autodatom našao grešku sa oznakom 512 (ako se dobro sječam) i poništio ju ali se drugi dan nakon nekoliko paljenja motora opet pojavila ta greška.
Inače auto ide sasvim normalno i ne pokazuje apsolutno nikakve greške u radu.
Objasnio je to kao krivo očitanje nečega a sami software nije mogao opisati tu grešku.
Jel netko ima iskustva s tim i koje je objašnjenje.
Thx svima
Offline ziko2306
  • Postova: 111
  • 156 sw 1.9 jtd
    • Sisak,Budaševo
« Odgovori #23 u: 13-01-2015, 21:19:42 »
pozdrav svima, dali ko zna o čemu se radi kod greške PO235 supercharging pressure, turbina neradi i neda preko 3500 obrtaja,signalna lampica motora upaljena..        map senzor je bio u pitanju,u prekidu kontakt!!
« Zadnja izmjena: 19-01-2015, 13:13:58 od ziko2306 »
Ž I K 0
Offline kilo529
  • Postova: 570
  • Giulia 2.2 JTDm AT8
« Odgovori #24 u: 14-01-2015, 08:07:40 »
Odi kod dr Andrije u Tomićev put...
Offline Surovi
  • Postova: 884
« Odgovori #25 u: 10-07-2015, 19:40:16 »
Eto kod mene je kratkotrajno označio 0234 - grešku tlaka turbopunjenja.
Prejaka mi turbina  :tooth:
Što sve može biti uzrok?
  • Postova: 21831
« Odgovori #26 u: 22-07-2015, 01:14:20 »
loša geometrija turba
Offline tronic24
  • Postova: 9
« Odgovori #27 u: 19-08-2015, 08:41:31 »
na dijagnostici su mi očitali sljedeće greške:
1. P1173 - Air inlet regulator valve - Malfunction
2. P1176 - Unknown code
3. P0606 - PCM Processor Fault.
U dosadašnjim postovima nisam uspio pronaći što bi to bilo pa eventualno ako neko možda zna nekaj o greškama.
Unaprijed se zahvaljujem na pomoći.
Offline draak
  • Postova: 2514
  • LD 12
    • Bruxelles
« Odgovori #28 u: 19-08-2015, 09:08:10 »
P1173 - Alfa Romeo P1173
 Long trem fuel trim - at increased engine RPM
 OR
 Rotor Calibration Fault
P1176 - Alfa Romeo P1176
 Cam Calibration Fault
P0606 - Alfa Romeo P0606 (generic)
 ECM / PCM Processor
Powered by Zorac's OBD Check Engine Code
Offline tronic24
  • Postova: 9
« Odgovori #29 u: 21-08-2015, 12:00:55 »
Hvala!
