17-04-2026, 22:40:52
Autor Tema: Alfa Romeo Duetto / Spider  (Posjeta: 117711 vremena)
Offline veloce
  • Postova: 2255
    • kostrena
Odg: Alfa Romeo Duetto / Spider
« Odgovori #150 u: 29-09-2008, 22:13:03 »
a ča se nisi javil, kad si bil na poljudu :da:
super su ti filmići :ok:
  • Postova: 42873
« Odgovori #151 u: 02-10-2008, 16:38:12 »
  • Postova: 42873
« Odgovori #152 u: 02-10-2008, 21:50:49 »
  • Postova: 42873
« Odgovori #153 u: 03-10-2008, 18:52:45 »
  • Postova: 5332
« Odgovori #154 u: 05-10-2008, 12:38:12 »
Alfa Romeo, Spider, ...
Ar Spider
nema slika jedino..
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #155 u: 07-10-2008, 05:45:47 »
Features: very powerful, very fast street Alfa. Featured in several European Car Magazines (world famous). Motor has been modified (again) from magazine article shown. Now: 205HP @ 8000RPM / Burns Stainless Steel header and exhaust, Mega Cycle cams, oil coolers, oxygen sensor, etc. There is about 5 - 10 HP to be had with another cam change and timing if you want it? Bottom end is built to take it: main bearing girdle support, carillo rods, lightened 3mm oversize JE pistons with Total Seal rings, LA custom sleeves, Paul Spruell racing oil pump and windage trays, late model motronic block, everything precision balanced and clearanced. Engine is very smooth all the way up to the rev limiter. Top end is built to deliver the power: Sperry Stage 5 head, cc'd combustion chambers, oversized valves with Iskenderian springs and retainers, Mega Cycle cams, 48mm DCO Weber's, ITG horns and filter, Burns exhaust. Crane racing digital ignition / rev limiter and a smoking hot coil.
« Zadnja izmjena: 07-10-2008, 05:51:50 od veloce »
  • Postova: 42873
« Odgovori #156 u: 08-10-2008, 10:31:41 »
  • Postova: 8255
« Odgovori #157 u: 08-10-2008, 10:33:22 »
Fino zgleda hard-top!  :ok:
  • Postova: 5332
« Odgovori #158 u: 08-10-2008, 10:37:31 »
Bio jucer u Opatiji,vidio jednu crvenu RI rege,samo zadnju ima,prvu ne..
htio slikati ali me u zadnje vrijeme zeza kamera na mobu.
komentar na auto..
 :love: :love: :love:
ijuric
« Odgovori #159 u: 08-10-2008, 11:00:53 »
« Odgovori #160 u: 16-10-2008, 14:12:52 »
« Zadnja izmjena: 16-10-2008, 14:17:55 od Marin krk »
  • Postova: 42873
« Odgovori #161 u: 18-10-2008, 22:15:54 »
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #162 u: 27-10-2008, 21:07:00 »
padova, 25.10.08 :da:
Darjan1275
« Odgovori #163 u: 27-10-2008, 21:12:36 »
Šta se neko usrećio :love3:
  • Postova: 8255
« Odgovori #164 u: 31-10-2008, 00:11:29 »
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #165 u: 01-11-2008, 12:26:32 »
« Zadnja izmjena: 01-11-2008, 12:28:16 od veloce »
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #166 u: 03-11-2008, 17:53:53 »
« Zadnja izmjena: 03-11-2008, 21:12:10 od veloce »
  • Postova: 42873
« Odgovori #167 u: 03-11-2008, 17:55:47 »
veloce sve slike koje stavljaš sa te adrese se nevide  :sad:
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #168 u: 03-11-2008, 21:13:52 »
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #169 u: 08-11-2008, 14:26:20 »
retrovizor Vitaloni iz 1967 :ok:
« Zadnja izmjena: 08-11-2008, 14:32:37 od veloce »
  • Postova: 42873
« Odgovori #170 u: 08-11-2008, 15:40:34 »
  • Postova: 42873
« Odgovori #171 u: 08-11-2008, 15:42:36 »
  • Postova: 8255
« Odgovori #172 u: 08-11-2008, 17:52:40 »
Predobro mi izgleda sa hard-topom...  :love: :love:
  • Postova: 8255
« Odgovori #173 u: 09-11-2008, 10:45:12 »
stari
« Odgovori #174 u: 10-11-2008, 12:41:13 »
 posljednje slike prije odlaska ka novom vlasniku :da:
« Zadnja izmjena: 10-11-2008, 12:43:36 od stari »
  • Postova: 8255
« Odgovori #175 u: 10-11-2008, 23:06:02 »
Da sam barem je novi vlasnik... :smajlićkojitužnoirazočaranouzdiše:
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #176 u: 12-11-2008, 07:46:54 »
Offline Neven
  • Član Alfa Kluba 11
  • Postova: 5042
  • 147 JTDm
    • Varaždin
« Odgovori #177 u: 12-11-2008, 19:33:14 »
  • Postova: 8255
« Odgovori #178 u: 12-11-2008, 19:35:13 »
Prespor si Nevene! Kad sam ja tu sliku stavio... :song: :song:
Hehehe...  :hap:
« Zadnja izmjena: 13-11-2008, 20:04:41 od a.m.alfa »
ijuric
« Odgovori #179 u: 12-11-2008, 19:42:22 »
Hehehe...  :hap:
 :smijeh :smijeh ti ti svi ovi u vodstvu tako pale na guranje  :smijeh si vidio viktora danas u temi mito  :smijeh :smijeh e suze mi idu..nevene  a mumu  :hehe:
