12-08-2026, 05:27:06
Autor Tema: 33  (Posjeta: 13090 vremena)
Boxer
« u: 09-12-2006, 14:26:49 »
Boxer
Odg: 33
« Odgovori #1 u: 09-12-2006, 14:30:28 »
Serija 1
Tip         Proizvodnja       Obujam            Snaga
1.2        1983-1985        1186 cm3        68 KS/6000 RPM, 90 Nm/3200 RPM
1.3        1983-1985        1351 cm3        79 KS/6000 RPM, 111 Nm/3500 RPM
1.5        1983-1984        1490 cm3        84 KS/5800 RPM, 120,5 Nm/3500 RPM
1.5 Q.O.        1983-1984        1490 cm3        84KS /5800 RPM, 120,5 Nm/3500 RPM
1.5 4x4        1983-1984        1490 cm3        84 KS/5800 RPM, 120,5 Nm/3500 RPM
1.5 Giardinetta 4x4        1984-1986        1490 cm3        95 KS/5750 RPM,  130,5 Nm/4000 RPM
1.5 Q.V.        1984-1986        1490 cm3        105 KS/6000 RPM, 133,5 Nm/4000 RPM
1.3 S        1984-1986        1351 cm3        86 KS/5800 RPM, 119 Nm/4000 RPM
1.5 Q.O.        1984-1986        1490 cm3.        95 KS/5750 RPM,  130,5 Nm/4000 RPM
1.5 Giardinetta        1984-1986        1490 cm3        95 KS/5750 RPM,  130,5 Nm/4000 RPM
1.5 4x4        1985-1986        1490 cm3        95 KS/5750 RPM, 130,5 Nm/4000 RPM
1.5 cat        1985-1986        1490 cm3        92 KS/5750 RPM,130,5 Nm/4000 RPM
1.2        1986-1988        1186 cm3        68 KS/6000 RPM, 90 Nm/3200 RPM
1.3/ 1.3 Silver        1986-1988        1351 cm3        79 KS/6000 RPM, 111 Nm/3500 RPM
1.3 S        1986-1988        1351 cm3        86 KS/5800 RPM, 119 Nm/4000 RPM
1.5 TI        1986-1988        1490 cm3        105 KS/6000 RPM, 133,5 Nm/4000 RPM
1.5 4x4        1986-1988        1490 cm3        105 KS/6000 RPM, 133,5 Nm/4000 RPM
1.5 Giardinetta        1986-1988        1490 cm3        105 KS/6000 RPM, 133,5 Nm/4000 RPM
1.5 Giardinetta 4x4        1986-1988        1490 cm3        105 KS/6000 RPM, 133,5 Nm/4000 RPM
« Zadnja izmjena: 09-12-2006, 14:37:42 od Boxer »
Boxer
Odg: 33
« Odgovori #2 u: 09-12-2006, 14:36:34 »
Serija 2
TIP                 Proizvodnja       Obujam            Snaga
1.7 Q.V.         1986-1988        1712 cm3        114 KS/5800 RPM, 148 Nm/3500 RPM
1.7 cat Q.V.        1986-1988        1712 cm3        111 KS/5800 RPM, 143 Nm/3500 RPM
1.8 turbodiesel Berlina        1986-1988        1779 cm3 (3cilinder)        72 KS/4000 RPM, 153 Nm/2400 RPM
1.8 turbodiesel Giardinetta        1986-1988        1779 cm3 (3cilinder)        72 KS/4000 RPM, 153 Nm/2400 RPM
1.3 Sport Wagon S        *1988-1989        1351 cm3        86 KS/5800 RPM, 119 Nm/4000 RPM
1.7 Sport Wagon Q.V.        *1988-1989        1712 cm3        114 KS/5800 RPM, 148 Nm/3500 RPM
1.7 I E        *1988-1989        1712 cm3        107 KS/5800 RPM, 148 Nm/4500 RPM
1.7 I E cat        *1988-1989        1712 cm3        102 KS/5500 RPM,145 Nm/4500 RPM
1.7 I E cat S.W. Q.V.        *1988-1989        1712 cm3        102 KS/5500 RPM, 145 Nm/4500 RPM
1.7 I E cat S.W. 4x4 Q.V.        *1988-1989        1712 cm3        102 KS/5500 RPM, 145 Nm/4500 RPM
1.3 S Blue Line - Red        1989-1990        1351 cm3        86 KS/5800 RPM, 119 Nm/4000 RPM
1.3 Italia `90        1990        1351 cm3        86 KS/5800 RPM, 119 Nm/4000 RPM
1.5 T I  S        1989-1990        1490 cm3        105 KS/6000 RPM, 133,5 Nm/4000 RPM
1.7 Veloce        1988-1989        1712 cm3        114 KS/5800 RPM, 148 Nm/3500 RPM
1.7 Veloce S.W.        1988-1989        1712 cm3        114 KS/5800 RPM, 148 Nm/3500 RPM
« Zadnja izmjena: 09-12-2006, 14:37:20 od Boxer »
Boxer
Odg: 33
« Odgovori #3 u: 09-12-2006, 15:19:25 »
Serija 3
1.2        1990-1992        1186 cm3        77 KS/6000 RPM, 95 Nm/4500 RPM
1.3, V, VL, Veloce        1990-1992        1351 cm3        86 KS/6000, 111 Nm/4500 RPM
1.3 Sport Wagon, S.W. L        1990-1992        1351 cm3        86KS/6000 RPM, 111 Nm/4500 RPM
1.5        1990-1992        1490 cm3        105 KS/6000 RPM, 133,5 Nm/4000 RPM
1.7 I E Berlina, S, 4x4        1990-1992        1712 cm3        107 KS/5800 RPM,148 Nm/4500 RPM
1.7 I E cat        1990-1992        1712 cm3        105 KS/5800 RPM, 145 Nm/4500 RPM
1.7 I E  Sport Wagon, S.W.4x4        1990-1992        1712 cm3        107 KS/5800 RPM, 148 Nm/4500 RPM
1.7 I E cat Sport Wagon, S.W.4x4        1990-1992        1712 cm3        105 KS/5800 RPM, 145 Nm/4500 RPM
1.7 I E 16V        1990-1992        1712 cm3        133 KS/6500 RPM, 154 Nm/4600 RPM
1.7 I E 16V cat        1990-1994        1712 cm3        129 KS/6500 RPM, 149 Nm/4600 RPM
1.7 I E 16V Q.V.-S        1990-1992        1712 cm3        133 LS/6500 RPM, 154 Nm/4600 RPM
1.7 I E 16V cat Q.V.-S        1992-1994        1712 cm3        129 KS/6500 RPM, 149 Nm/4600 RPM
1.8 turbodiesel Berlina        1990-1992        1779 cm3        84 KS/4200 RPM, 177.5 Nm/2400 RPM
1.8 turbodiesel S.W.        1990-1992        1779 cm3        84 KS/4200 RPM, 177.5 Nm/2400 RPM
1.3 S.W. 4x4        1990-1992        1351 cm3        86 KS/6000 RPM, 111 Nm/4500 RPM
1.7 I E 16V S.W.        1990-1992        1712 cm3        133 KS/6500 RPM, 154 Nm/4600 RPM
1.7 I E 16V cat S.W.        1990-1992        1712 cm3        129 KS/6500 RPM, 149 Nm/4600 RPM
Boxer
Odg: 33
« Odgovori #4 u: 09-12-2006, 15:22:29 »
Serija 4
1.5 I E        1990-1994        1490 cm3        97 KS/6000 RPM 125,5 Nm/ 4500 RPM
1.5 I E cat        1990-1994        1490 cm3        95 KS/6000 RPM, 124,5 Nm/4500 RPM
Permanent 4        1991-1994        1712 cm3        133 KS/6500 RPM, 154 Nm/4600 RPM
Permanent 4 cat        1991-1994        1712 cm3        129 KS/6500 RPM,149 Nm/4600 RPM
Q.V. 4 cat        1991-1994        1712 cm3        129 KS/6500 RPM,  149 Nm/4600 RPM
Q.V. 4 cat S.W.        1991-1994        1712 cm3        129 KS/6500 RPM, 149 Nm/4600 RPM
1.4 I E* cat - L        1991-1994        1351 cm3        90 KS/6000 RPM, 119 Nm/4500 RPM
1.4 I E* cat S.W. - L        1991-1994        1351 cm3        90 KS/6000 RPM, 119 Nm/4500 RPM
1.4 I E* cat S.W. 4x4        1991-1994        1351 cm3        90 KS/6000 RPM, 119 Nm/4500 RPM
*- pojedina tržišta označavan kao 1.3 IE
  • Postova: 43039
Odg: 33
« Odgovori #5 u: 10-12-2006, 23:31:19 »
  • Postova: 43039
Odg: 33
« Odgovori #6 u: 10-12-2006, 23:46:23 »
Offline LOŠA
  • Postova: 4438
  • Alfa Romeo Brera 2.0 JTDM
Odg: 33
« Odgovori #7 u: 11-12-2006, 20:52:10 »
Gdje ste samo isčupali ove orginalne slike unutrašnjosti 33-ojke, svaka čast  :ok:
  • Postova: 43039
Odg: 33
« Odgovori #8 u: 18-12-2006, 18:15:17 »
Alfa 33 1.5 QO
Alfa 33 1.5 4X4
Alfa 33 1.5 QV
Alfa 33 Giardinetta 1.5 4X4
 Alfa 33 1.7 QV
Alfa 33 1.7 IE
Alfa 33 Sport Wagon 1.7 QV
 Alfa 33 Sport Wagon 1.7 IE QV
Alfa 33 1.5
Alfa 33 1.7 IE
Alfa 33 1.7 16V QV
Sport Wagon 1.7 IE
Alfa 33 1.8 TDi
Alfa 33 Sport Wagon 1.4 IE L
Alfa 33 Imola
« Zadnja izmjena: 27-06-2007, 20:30:33 od a.m.alfa »
Offline Tomek
  • Postova: 4056
  • Fiat Punto mk2a
Odg: 33
« Odgovori #9 u: 13-02-2007, 09:31:40 »
A di vam je 1,7 16V bez katalizatora sa 137 ks :o000: :?: :?: :?: :?: :?:
Offline RoadRunner
  • Postova: 7764
Odg: 33
« Odgovori #10 u: 15-09-2008, 10:04:31 »
Parkirana kod mene pred zgradom :craz ,98kw i u prometnoj piše i nema kata ni u papirima ni u stvarnosti   :hap:
Gas Guzzler
Offline Fabrizio Giovanardi
  • Trade Count: (-1)
  • Postova: 2351
  • Giulia 2.0 Competizione
Odg: 33
« Odgovori #11 u: 16-09-2008, 00:26:59 »
Fali i 1.7 IE bez kata iz '91. serie 3. (ako se ne varam, sa 110ks)
Alfa nel cuore
Offline RoadRunner
  • Postova: 7764
Odg: 33
« Odgovori #12 u: 23-10-2008, 00:05:20 »
Ljudi ,imam problem...kopa me taj problem još od Splita kad mi je neko rekao da prvi put ovo vidi ,naime ovakav nema i nepostoji nigdje u bazama moj model 33ce....toliko me to sad ubija da nemogu spavat doslovno.... :mad: :wal:
Znači stvar je ovakva : Model 33ce 1.7 16V Permanent 4 ima i sve i jedan bez ABS-a i sve imaju katalizatore. Klimu nisam ni na jednom podmodelu vidio da je navedena ,ni jedan model (e to mi je čudno) nema diskove iza (nisam siguran 100% za diskove ,ali za ABS sam siguran da nema nijedna)
1.7 16V QV koja ima i ABS i klimu i diskove iza. Ima verzija i sa katalizatorom od 129ks pa ona bez sa 137ks....
1.7 16V obična koja je u biti isto sve ko i 1.7ie 8V paket opreme samo 16V motor je u njoj ,isto 2 varijante sa i bez kazalizatora.
Govorim o seriji 3 naravno 1991 godište modeli...e sad koji mene problem muči :
Moja 33 bi bila :
Alfa 33 1.7ie 16V sa permanent4 pogonom ,ABS-om i klimom i nekim vražijim ESP-om koji ima lampica na tabli i upali se kad dam kontakt ali se nakon što se motor upali i ona ugasi) ,e sad : DISKOVI odozada na P4 osovini!!! i nema tvornički lamda sondu niti katalizatora!! E tu je problem!!!
Nema i nepostoji taj model doslovno nigdje niti u jednoj knjizi niti podatcima o 33 ,čak nema niti da je neko drugo godište ,naime NEMA Permanent s diskovima nazad i to još s rupama u ležajima za ABS!!!
Pitanje glasi...danas-sutra ak mi ležaj krepa ,što onda???
Koju vražiju 33 sam uzeo na kraju neznam ni sam.... :wal: :mad:
Gas Guzzler
Offline RoadRunner
  • Postova: 7764
Odg: 33
« Odgovori #13 u: 23-10-2008, 00:25:42 »
Evo nakon mukotrpnog kopanja po netu našao sam nešto :
Postojao je 92go model P4 s serijskim ABS-om ,a oprema od QV s nekom varijantom ESP-a i klimom samo je išlo uz doplatu tako da ti modeli zvanično nisu uvedeni u kataloge.
E sad to što je moja 33 1991g ...ko zna šta su radili prilikom uvoza ,ali sad mi je lakše jer znam čak i da zadnji ležaji štimaju i da će se vjerovatno po ovom modelu iz 1992 moć nać ak mi ikad nedajbože zatrebaju.
Sad mogu mirno spavat.... :zzz: :zzz:
Gas Guzzler
ALFA 166 DA
Odg: 33
« Odgovori #14 u: 02-01-2009, 20:03:58 »
 e moja je bila 1,8 TD i  7 godina smo se družili
a sada si tražim 33-ica ilu Sprinta  sa mirisom benzina da si je sredim i čuvam za sina kada naraste da i on ima jednu  :love:
Offline Bero
  • Postova: 2249
    • Jastrebarsko
Odg: 33
« Odgovori #15 u: 03-10-2010, 22:52:07 »
Ako može jedno pitanje:
Tu je navedeno 33 serija 3 i  33 serija 4, pa me zanima koje su razlike između te dvije serije, ili je to sve isto?
I još jedno pitanje: Netko mi je rekao da su se u 33-ojke pred kraj njihove proizvodnje ugrađivali twinspark motori. meni je ta informacija bila nevjerojatna :000:, te još uvjek baš ne vjerujem u tu tvrdnju. Pa ako netko zna nešto više o tome...
Mirko
Odg: 33
« Odgovori #16 u: 03-10-2010, 23:00:12 »
33 serija 4 ne postoji, a da je TS ugrađivan u 33ojku taj ko ti je to reka nema pojma o motorima ni autima
Odg: 33
« Odgovori #17 u: 04-10-2010, 09:30:19 »
njega je vjerojatno zbunilo ovo permanent4  :ok:
Offline Bero
  • Postova: 2249
    • Jastrebarsko
Odg: 33
« Odgovori #18 u: 04-10-2010, 10:03:16 »
Serija 4
ovo tu me zbunilo... :?:
Offline Italofan
  • Postova: 1189
  • Bravo Sport, 33 1.5 ie S
    • SLO - Il. Bistrica
Odg: 33
« Odgovori #19 u: 05-05-2012, 23:58:17 »
 :mah:  :alfisti:
Možda zna netko odgovor na moje pitanje :?: Znam za jednu 33-icu 93 godište 1.7 16v oznakom SS...  :rolll: :rolll: :rolll:
Dakle oznaka na stražnji haubi izgleda ovako 33 1.7 16v SS.
Šta bi taj SS značio :?: :?: :?:, malo sam googlao ali nigdje ne nađem ništa o ovom modelu.
Izvana mi izgleda kao svaka druga "obična" 16v, šta se tiče unutrašnosti samo se mi sicevi čine malo drugačiji...
Hvala  :mahm
Offline kristian 33
  • Postova: 196
  • alfa 75- 1.8.87,alfa 75 2.0ts& 1.6,giulia super
    • savudrija(umag)
Odg: 33
« Odgovori #20 u: 06-05-2012, 14:23:22 »
nije SS nego bi trebala biti 33 s 16v,koja se proizvodila od 92-94 i zamjenjuje model 33 16v  QV 90-92,u biti je samo naziv i mozda koja sitnica izmjenjena. :da:
"obozavam alfe na frgazere"
Offline Italofan
  • Postova: 1189
Odg: 33
« Odgovori #21 u: 06-05-2012, 15:24:31 »
Nažalost sada nimam nijedne slike, ali na haubi piše SS  :da: :da: :da:. Budem slikao... Da da, nije neke revolucionarne razlike, zato sam pitao dali možda netko zna koje su te sitnice...
 :mahm
Offline Italofan
  • Postova: 1189
Odg: 33
« Odgovori #22 u: 07-05-2012, 22:49:53 »
nije SS nego bi trebala biti 33 s 16v...
Eto jedne stare slike, slikana analognim fotičem, skenirana, pa zato loše kvalitete ali eto... SS  :rolll:  :?: :?: :?:
Offline RoadRunner
  • Postova: 7764
Odg: 33
« Odgovori #23 u: 08-05-2012, 15:10:52 »
doljepio još jedno "s"  :craz
Gas Guzzler
Offline Italofan
  • Postova: 1189
Odg: 33
« Odgovori #24 u: 08-05-2012, 22:05:55 »
Nije  :ne: :ne: :ne:, moj je susijed i 1. je vlasnik  :da:, tako da znam auto od 1. dana  :da:.
Rekao mi je da je bila rađena za neko tuđe tržište... Inače je auto  :ok: :ok: :ok:  :love: :love: :love:
Offline Bero
  • Postova: 2249
    • Jastrebarsko
Odg: 33
« Odgovori #25 u: 08-05-2012, 22:22:46 »
Moguće za njemačko tržište  :hehe: :hehe:
Vrlo cijenjena među neonacistima  :craz
Odg: 33
« Odgovori #26 u: 08-05-2012, 22:27:16 »
Najbliže si istini  :craz :o000: :ok:
