22-10-2026, 06:58:25
Autor Tema: AR 159 - Zadnji branik (montaža,demontaža problemi)  (Posjeta: 8548 vremena)
Offline Guro
  • Postova: 460
  • 159 1.9JTDm & 156 2.4JTD
    • Podgorica
pozdrav,
mislio sam da na 159 ugradim parking senzore, pa me interesuje jel neko moze da mi kaze kako se skida zadnji branik...ili da trazim sam nacin :D
gdje je sve fiskiran...i sto sve mora da se skida
« Zadnja izmjena: 17-05-2014, 21:10:02 od a.m.alfa »
Offline Guro
  • Postova: 460
    • Podgorica
Odg: kako se skida zadnji branik
« Odgovori #1 u: 19-03-2012, 09:17:29 »
mozda nekome bude trebalo...ja cu da probam na osnovu ovoga...
To remove the rear bumper -
1 -Remove four star head screws located in each wheel arch
2 -Remove the two lower torx T30 screws from the underside of the bumper, roughly in line with the two center parking sensors. When under there its best to undo the two electrical connectors (parking sensors and number plate lights)
3- Remove the rear tail lights to access another two torx T30 bolts, one below each light. (Lights are removed by undoing the screw up bolt in light cover inside boot and then removing three M5 bolts)
4 - Remove bumper by pulling it towards you
  • Postova: 5243
« Odgovori #2 u: 19-03-2012, 09:52:13 »
kada sam sebi stavljao kameru nisam skidao zadnji branik, vec samo odsarafio sve doljnje vijke i onda provuko kablove, a prostora ima dovoljno da mozes ruku gurnit unutra
Offline Guro
  • Postova: 460
    • Podgorica
« Odgovori #3 u: 19-03-2012, 12:54:54 »
mislis da bih mogao da probam da stavim senzore bez skidanja branika?..ja nedje pogledah ispod kola, onako na brzinu...djelovalo mi nemoguce..
  • Postova: 5243
« Odgovori #4 u: 19-03-2012, 13:48:34 »
probaj odsarafit sve vijke od dolje i u blatobranu i onda ga mozes malo i povuc prema naprijed.. ja sam sebi mislio stavljat senzore al sam odustao jer nisam htio busit branik .. al vijerujem da bi se dalo sve napravit bez skidanja branika ...
Offline Guro
  • Postova: 460
    • Podgorica
« Odgovori #5 u: 19-03-2012, 13:53:57 »
ma jas ranije htio da stavljam to...pa sam odustao bas zbog toga...pa sam onda htio da stavljam one sa trakom, za koje se ne busi branik...ali su mi rekli da su losi...
i onda sam u par prilika provalio da apsolutno iz auta ne mogu da procijenim gdje mi zadnji kraj..i da sve mnogo blize izgleda nego st oje stvarno...i onda porucih od kineza senzore za 15eur...
malo me omeksalo to sto mi je auto crno, pa ce i sami senzori biti manje primjetni nadam se...
  • Postova: 5243
« Odgovori #6 u: 19-03-2012, 14:13:19 »
bit ce da manje primjetno... ja cu vidit za senzore jel cu ih stavljat sad naknadno jer mi auto zna vozit brat i stari pa radi njih stavit jer se uvijek muce sa tim parkiranjem, i da ne naprave vise stete nego sto ti senzori kostaju .. budem bas vidio ak mi ostane boje od farbanja unutrasnjosti onda idu senzori gore :))
Offline wiking
  • Postova: 511
  • 156 1.9 JTD
« Odgovori #7 u: 19-03-2012, 14:28:28 »
ja ih imam i nisam se pokajao,vrijedi svake kune i pase mi crno na sivo :rolll:
Offline Guro
  • Postova: 460
    • Podgorica
« Odgovori #8 u: 19-03-2012, 15:29:12 »
ja bih trebao da ugradjujem danas, sjutra ili za koji dan...pa javljam kako to izgleda... :) i slikacu...
nadam se da necu morati da skidam branik
  • Postova: 5243
« Odgovori #9 u: 19-03-2012, 16:30:29 »
:ok: i sretno nadam se da nece bit puno posla sa branikom
Offline kolgate
  • Postova: 1051
  • Bmw 5
    • long village
« Odgovori #10 u: 19-03-2012, 17:41:02 »
možda se i da ugraditi bez skidanja branika, al mislim da bez velike dizalice
ili jame gotovo nemoguće tj. jako mukotrpno...
neog kad smo već kod branika, daj nam mrcino otprilike opis gdje se sve nalaze
 i šarafi za prednji branik, pošto sam vidio da si to radio..
ps: kak mi je čudno napisati ovo; "mrcino"  :hehe:  :ok:
  • Postova: 5243
« Odgovori #11 u: 19-03-2012, 19:24:00 »
evo slika iz ELEARN-a
ak treba sutra slikam di se nalaze vijci iza na braniku kod tocka
samo treba pazit za kabel od maglenki da nebi slucajno pokidao ..
vijci su torx, krizni, i dvije trinajstice bar kod mene su taki ..
nemora se skidat tockovi samo ih zakrenes u jednu stranu i odsarafis ..
kada se odsarafis branik povuces prema van jer je za blatobran ucvscen sa zupcima .. tako ga isto i vracas mora ti uc u taj kanal i onda se samo udari po vrhu da sjednu zubci u svoje ..
a kak je meni tek bilo cudno kada me kolegica tak nazvala  :hehe: :hehe:
« Zadnja izmjena: 19-03-2012, 19:29:16 od mrcina »
  • Postova: 5243
« Odgovori #12 u: 19-03-2012, 19:28:25 »
evo i zadnjeg kako se skida
Offline kolgate
  • Postova: 1051
  • Bmw 5
    • long village
« Odgovori #13 u: 19-03-2012, 20:41:06 »
super ...ugrađivati ću xenon u maglenke, pa će ova skica skratit muke
  • Postova: 5243
« Odgovori #14 u: 19-03-2012, 20:47:49 »
ja cekam nove blastere i zarulje da mi stignu pa isto selim ove stare u maglenke al necu lecu stavljat samo zarulje :))
Offline kolgate
  • Postova: 1051
  • Bmw 5
    • long village
« Odgovori #15 u: 19-03-2012, 23:30:15 »
pa tako ću i ja, bez leće..i tako su dolje nisko a i ne koriste se tako često
 i mislim da je 4300 sasvim dovoljno...
ove maglenke na 159 su voda, kakvu korist daju. kurc.. ne vrijede  :craz
koje ćeš si uzeti za kratka svjetla?  reko sam ti da sam uzeo 5000k i preporučam to svakome
  • Postova: 5243
« Odgovori #16 u: 20-03-2012, 08:22:09 »
imam 6300k i zadovoljan malo vuku na plavo al nista strasno, takve ce i ostat  u maglenkama idu isto take posto cu onda imat jedana set h7 viska
Offline kolgate
  • Postova: 1051
  • Bmw 5
    • long village
« Odgovori #17 u: 20-03-2012, 20:46:19 »
a jesi ti siguran da će se h7 dat pripasati u maglenku, pošto je tamo h2?
  • Postova: 5243
« Odgovori #18 u: 20-03-2012, 21:27:59 »
meni u knjizi sto sam skinio manual za 159 pise da ide H7
Offline kolgate
  • Postova: 1051
  • Bmw 5
    • long village
« Odgovori #19 u: 20-03-2012, 21:38:39 »
u mom priručniku koji sam dobio sa autom, piše h2...luda kuća  :)
  • Postova: 5243
« Odgovori #20 u: 21-03-2012, 09:08:43 »
bome jee luuda totalno  :funny: :funny: bas cu pogledat danas koje su u farovima
  • Postova: 5243
« Odgovori #21 u: 21-03-2012, 09:09:04 »
Offline Guro
  • Postova: 460
    • Podgorica
« Odgovori #22 u: 22-03-2012, 14:56:15 »
ja ugradih senzore...
za sad su ok..pokazuju dosta precizno :)
nisam morao da skidam branik...i dosta dobro su stali...ljepse nego sto sam mislio...
« Zadnja izmjena: 22-03-2012, 14:58:41 od Guro »
Offline alfist@
  • Postova: 312
    • Beograd/Zadar
« Odgovori #23 u: 23-03-2012, 22:48:58 »
Da li se zadnjem senzoru moze prici rukom bez da se skida zadni branik, samo da ga malo pritisnem sa zadnje strane, mislim na onaj pored (iznad) tablice.
« Zadnja izmjena: 24-03-2012, 00:49:15 od alfist@ »
  • Postova: 5243
« Odgovori #24 u: 24-03-2012, 09:23:31 »
pa receno je da se moze samo moras prvo odpustit sve doljnje vijke koi drze branik i onda se on malo povuce prema van i mozes prici rukom
Offline Guro
  • Postova: 460
    • Podgorica
« Odgovori #25 u: 24-03-2012, 16:01:25 »
ja nisam siguran da moze...
ja cak nisam uspio da vidim i ove koji su ispod tablice...samo sam uspio da spustim kabal dolje i da ga uvucem u kabinu..
to se odnosi na ove kod tablice...do ovih bocnih se moze doci bez problema...makar je meni tako izgledalo :D
« Zadnja izmjena: 24-03-2012, 16:03:04 od Guro »
  • Postova: 5243
« Odgovori #26 u: 24-03-2012, 17:15:57 »
mozes kada otpustis vijke onda mozes branik povuc prema napred , malo je zeznuti al ide
Offline damir77
  • Postova: 13
Alfa 159 - zadnji branik/dijelovi
« Odgovori #27 u: 10-02-2016, 13:30:09 »
Potrebna mi je pomoć oko sljedećeg:
Na zadnjem branike svoje Alfe159 1.9 JTDm imam na dnu s lijeve strane otvor za auspuh, i s druge strane otvor za drugi auspuh koji je imao poklopac s kopčama koji je zatvarao tu rupu, a kojeg sam ja uspio putem izgubiti pa sada imam rupu.
Zna li netko gdje bi se taj dio mogao nabaviti kao polovni ili kako se točno taj dio zove i gdje bih ga mogao kupiti kao novog.
Lp, Damir
Offline Vendetta
  • Postova: 591
  • Montreal Verde Giulia QV
Odg: Alfa 159 - zadnji branik/dijelovi
« Odgovori #28 u: 10-02-2016, 14:01:59 »
Nema ti taj dio naziva niti se vodi kao zaseban dio. Jedino kako ćeš doć do njega je da ga skineš sa drugog takvog branika. Ne mislim na krađu, već kupovinu  :D
Offline Vendetta
  • Postova: 591
« Odgovori #29 u: 10-02-2016, 14:33:24 »
Na forumu nema i namučit ćeš se po njuškalu ili ebay-u dok nađeš neki slupani branik i osobu voljnu da ti skine samo taj poklopac.
Možda neki auto otpadi sa slupanim 159kama.
