26-10-2026, 04:33:37
Autor Tema: Alfa Romeo 159 K&N Filter  (Posjeta: 7478 vremena)
XariX
« u: 19-10-2009, 12:30:27 »
K&N’s replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. We make over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N. See applicable instruction sheet for details. Our stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED.
Part E-9281 Product Specifications
Product Style: Oval Straight Universal Air Filter
Flange Inside Diameter: 4.469 in (114 mm)
Flange Length: 7.5 in (191 mm)
Flange Type: Centered
Height: 9.656 in (245 mm)
Outside Length: 7.438 in (189 mm)
Outside Width: 5.5 in (140 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Material: Cotton Gauze
Flanges: 1
Filter Re-Oiling Amount: 2.56 oz (76 ml)
Flange Inside Length: 4.469 in (114 mm)
Flange Inside Width: 2.563 in (65 mm)
Inner Wire: No
Weight: 2 lb (0.9 kg)
Product Box Length: 7.25 in (184 mm)
Product Box Width: 7.25 in (184 mm)
Product Box Height: 15.5 in (394 mm)
« Zadnja izmjena: 21-12-2011, 23:11:36 od mrcina »
Offline dugixy1
  • Postova: 962
  • Alfa 159 1.9 jtdm 16v
Odg: KN Air filteri...
« Odgovori #1 u: 23-10-2010, 19:37:33 »
jel ko stavljao te sportske filtere? jel se isplate na alfi 159,neke promjene zapažanja?
jel kolko čitam ima auti koji znaju raditi i lošije sa sportskim filterima!
neki info ako netko zna,razmišljam da uzmem a sad neznam koji i jel se isplati?
te koja im je cijena otprilike?
Offline xxx
  • Postova: 499
    • Biograd n/m
« Odgovori #2 u: 27-10-2010, 11:45:54 »
http://www.knfilters.com/search/product.aspx?Prod=E-9281
neko konkretno povećanje snage ne ćeš osjetiti iako ima veći kapacitet zraka (propusnosti), prednos filtera je što ga ne treba mijenjati on se ćisti cijena kod nas oko 500kn ima kupiti u http://www.intercars.eu/hr/
http://www.knfilters.com/search/appsearch.aspx
« Zadnja izmjena: 27-10-2010, 11:46:42 od xxx »
Offline dugixy1
  • Postova: 962
« Odgovori #3 u: 03-12-2010, 15:55:16 »
pa ti filteri su isplativi ako se samo čiste,nek idem 2 puta godišnje na servis i kupujem nove filtere dođe više nego ovaj što se čisti a tome je i  marka.jedino nije više 500 već 670 kn.
jel to sigurno za to čiščenje?
jek ikako moguče na alfi 159 pogledati stanje filtera a da se auto nediže u zrak? ili bar da se digne dizalicom za gume?
edit
ako netko ima neku sliku motora sa rasporedom svih filtera na alfi 159?
jel itko mjenjao sam?
edit 2
čitam na stranim forumima da je do filtera lako doči kad je auto na rampi,čak kažu dječja igra,neznam kao je sa dizalicom.
navodno kad se ukloni ta podna "ladica"  imate pristup večini filtera.
« Zadnja izmjena: 03-12-2010, 16:31:14 od dugixy1 »
Zagy
« Odgovori #4 u: 03-12-2010, 19:17:51 »
imaš bmc i sprintfilter panele....
Offline miro
  • Postova: 1941
  • benzinac
    • podstrana split
« Odgovori #5 u: 03-12-2010, 19:18:14 »
e sad si me zbunio,nemora ni biti K&N ,koji su još dobri a sportski?
makar K&N na stranicama kažu da je i potrošnja manja. a i realno gledajuči  samo kad je lijepo vrijeme možeš brže voziti,pa nek onda i potroši malo više a sa druge strane nemaš više ni gdje voziti brže,kazne su ogromne,radari svugdje... ja se više bojim davati gas, žali bože tih silnih konja :)
sad ozbiljno:
ne primjećujem razliku u potrošnji ali mi se čini da se motor ipak lakše vrti, kod mene je u kombinaciji ra ragazzon komplet ispušnim sustavom i ukupan dojam  :ok:
Zagy
« Odgovori #6 u: 03-12-2010, 19:23:20 »
sad ozbiljno:
ja imam sprintfilter  u karbonskom kučištu  sa filterom od poliestera i otvoreni auspuh i predobro ide auto... tj puno se lakše razvrtava nego prije kad je bila (zaštopana)  :craz
Offline dugixy1
  • Postova: 962
« Odgovori #7 u: 03-12-2010, 19:48:26 »
a šta si prije imao od filtera i pod ovo otvoren auspuh znači da si maknuo katalizator? samo to ili su bile još neke preinake na auspuhu?
kolko te koštalo to što si radio?
hvala :ok:
Zagy
« Odgovori #8 u: 03-12-2010, 19:51:53 »
hvala :ok:
al ti koliko vidim imaš jtd-a
filter je 1300 kn...  kat je probijen a otraga protočni lonac.  sad nezz koliko bi ti to značilo na dizelu..,..
Offline kolgate
  • Postova: 1051
  • Bmw 5
    • long village
« Odgovori #9 u: 06-12-2010, 15:32:20 »
zvao sam auto krešu i kažu mi da kn filter za 159 1.9jtdm košta 611kn...
ja ga mogu nabaviti istoga za 500kn, pa ko hoće neka se javi ovdje
mogu provjeriti cijene i za druge modele tj. motore...
« Odgovori #10 u: 06-12-2010, 15:47:53 »
...ako nije chipan, mislim da nema nekog smisla...ja sam na svoj 1.9 jtd (156) stavio SprintFilter KDR1, samo što sam modificirao i ispuh...downpipe cijev, Supersprint protočni de-cat i Remus protočni zadnji lonac...motor ljepše "diše", a čuje se bolesno...
bugija9
Alfa Romeo 159 SW K&N
« Odgovori #11 u: 09-08-2013, 13:46:04 »
Pozdrav ekipa.
Ako moze savjet od iskusnijih vezano za filter u 159tci.
Kako sa vremena na vrijeme sam u inozemstvu, stignem malo hodati po shopovima za auta.
U jednom takvom u Luxembourgu sam nasao K&N filtere za 159tku. Prodavac mi je posle kratke prezentacije preporucio da obavezno u svog Ljubimca ubacim zracni i uljni filter od ovog proizvodjaca. Naveo je vise razloga, da su life time filteri, da zracni filter poboljsava protok zraka i daje dodatnih 7-10 ks i tako to.. Uz filtere sma uzeo i set za ciscenje uz koji dodje ulje i degreeser. Da li neko zna nesto vise o tome i da li se moze samostalno zameniti ili se mora ici u servis.
Adi
  • Postova: 5243
Odg: Alfa Romeo 159 SW K&N
« Odgovori #12 u: 09-08-2013, 14:05:46 »
Pozdrav ekipa.
Adi
mozes i sam skinit stari filter i stavit ovaj novi, i moras ga nauljit prije nego ga stavis gore ( pazit da nestavis previse ulja )
ja dok sam imao takav filter nakon sta sam ga nauljio ostavio sam ga jedno 2-3 sata da odstoji pa onda ga vratio u auto.
a oko za 10ks zaboravi nema konja u tim filterima, jedino se auto lakse vrti i ima malo bolji odaziv na gas
bugija9
« Odgovori #13 u: 09-08-2013, 16:19:48 »
Da bas sam danas gledao neki klip na kojem se mijenja filter zraka. Ali ne znam da bih bas sam znao to odraditi.
Stvar je takva da sam ja prosli mjesec kada sam uzeo auto, odma bio na kontroli u ovlastenom servisu i oni su mi preporucili da ulje koje se razrijedilo od perioda stojanja auta se zamjeni, samim tim i sve filtere. Znam da su koristili neke filtere koji mi izgledaju jako lose (papirni ili sta vec), pa sada da ponovo idem i mjenjam ili da sacekam neku kilometrazu da odradim sa ovim. Znam da ce naplatiti uslugu servisiranja i to je ok...ali dvoumim se i dalje.
U svakom slucaju hvala na odgovoru.
Adi
  • Postova: 5243
« Odgovori #14 u: 09-08-2013, 16:40:52 »
Adi
ako mozes sam ili sa nekim zamjeni si, al mozes i cekat servis pa onda nek ti oni zamjene taj filter  :mah:
Offline Dama 166
  • Postova: 3780
    • Njemacka, Stuttgart
« Odgovori #15 u: 09-08-2013, 23:50:18 »
Filter moras ocistiti da bude bijel fobro ga osusiti i onda ga nauljiti da bude opet onsko roza crven al ne previse nego tek toliko da upije pamuk to ulje i to je to. Vremenski trebs oko 2-3 sata ali ga imas vjecno. Ja ga imam vec nekih 20000 km unutra i ok radi. Vise konja ???? Ako al onda muslim max. 2-5 a to je neprimjetno. Sta je jako osjetno je osjetljivost na gasu :)).
Za uljne nisam cuo da ih imaju bas cu morat vidit.
bugija9
« Odgovori #16 u: 10-08-2013, 05:48:45 »
Pa filter mi je dosao neke crvenkaste boje i da imaju i uljne filtere za 159tku.
Citao sam upustvo kako ga treba cistiti i uljiti ali on je nov sada i ne treba ga cistiti valjda..
Trebalo bi samo da se naulji i da se u auto namontira. No drago mi je da sto kazete obojca da se na gasu to osjeti malo. Ova masina je presla samo 44 000km i zelim da joj omogucim sto duzi i bolji vijek trajanja. Bukvalno da je odrzavam maximalno, sa redvonim servisima i svim.
Usput pretpostavljam da bi trebao korisiti Selenia ulje za nju?
Offline kilo529
  • Postova: 570
  • Giulia 2.2 JTDm AT8
Odg: Alfa Romeo 159 K&N Filter
« Odgovori #17 u: 10-08-2013, 22:55:28 »
imao sam k&n u 2.0 TS i to modificiran u originalnom kucistu...je, motor bolje dise ali zbog ulja mi je vrisnuo maf, tako da nikad vise u auto....
  • Postova: 5243
« Odgovori #18 u: 10-08-2013, 23:26:07 »
previse ulja si stavio.. kada ga nauljis previse onda ga samo omotas papirom moze i wc papir i ostavis ga tak par sati i papir povuce visak ulja  :mah:
