K&N’s replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. We make over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N. See applicable instruction sheet for details. Our stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED.
Part E-9281 Product Specifications
Product Style: Oval Straight Universal Air Filter
Flange Inside Diameter: 4.469 in (114 mm)
Flange Length: 7.5 in (191 mm)
Flange Type: Centered
Height: 9.656 in (245 mm)
Outside Length: 7.438 in (189 mm)
Outside Width: 5.5 in (140 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Material: Cotton Gauze
Flanges: 1
Filter Re-Oiling Amount: 2.56 oz (76 ml)
Flange Inside Length: 4.469 in (114 mm)
Flange Inside Width: 2.563 in (65 mm)
Inner Wire: No
Weight: 2 lb (0.9 kg)
Product Box Length: 7.25 in (184 mm)
Product Box Width: 7.25 in (184 mm)
Product Box Height: 15.5 in (394 mm)
