21-11-2026, 09:16:16
Autor Tema: Service interval reset - AlfaRomeo 159, Brera, MiTo, 4c...  (Posjeta: 6109 vremena)
Offline LOŠA
  • Postova: 4438
  • Alfa Romeo Brera 2.0 JTDM
Reset servisnog intervala bez examiner-a na novijim Alfama.
Citat:
Reset the system after an oil change
Without pushing the brake pedal, cycle the ignition to the Mar/On position.
Do not start the engine.
Press and hold the accelerator pedal.
Press and release the brake pedal 6 times with a 1 second pause between each press of the brake pedal.
After the 6th release of the brake pedal, pause 1 second, then release the accelerator.
If you still see the message, then the system did not reset, and you’ll need to repeat this procedure.
Offline mislav
  • Postova: 525
  • 159 1.9 JTDM SW
Odg: Service interval reset - AlfaRomeo 159, Brera, MiTo, 4c...
« Odgovori #1 u: 19-02-2020, 23:48:23 »
Jel ovo funkcionira na AR 159, ja sam probao ali nisam uspio. Probat ću još jednom
Offline Marin156
  • Postova: 99
  • Alfa 156
    • Zagreb / Omiš
« Odgovori #2 u: 29-02-2020, 18:38:48 »
Neradi na 159 frendu
Offline Gigo
  • Postova: 99
  • 147 1.6TS, Giulietta 1.6 jtdm
« Odgovori #3 u: 13-07-2020, 15:27:05 »
Pozdrav. Jel ovo radi na Giulietti 2011god.? fala
Ko ne voli janjetinu, ne voli ni životinje
