18-06-2026, 08:02:00
Autor Tema: radio code  (Posjeta: 1810 vremena)
Offline maki21
  • Postova: 232
    • pozega
radio code
« u: 27-01-2012, 22:09:36 »
mozda vec ima ovakva tema ali evo staviti cu,znaci ako vam ponisti radio code i nemate ga ovako ga mozete dobiti,radi samo sa blaupunkt radiima,skinuto je sa nekog stranog foruma pa je na engleskom ali nadam se da ce pomoci
osobno sam isprobao i radi
Hi Everyone,
This is my first post as I have recently become a new Alfa owner.
My first problem was the radio code was not present and the battery had been off. The stealer wanted £15! I had read many post about a little program that would get it for me but also found lots of people saying they could only find it with viruses. Well I found the program albeit in Chinese but with no virus and it worked a treat.
This is the address to down load from:
BP_PgAlfaFiat.exe*-*UPLOAD
And here are the instructions on how to do it:
1) Slide the radio out. 4 bits of metal coat hanger in each of the holes and a small screwdriver to prise the radio out do the job perfectly.
2) Look for the sticker printed with the serial number. Mine was on the right hand edge.
3) Write down the serial number - it starts with BP0 and is 14 digits long.
4) Google for the program BP_PgAlfaFiat.exe and download it. If you can't find it then leave a comment and I'll consider hosting it here.
5) Enter the serial number, dropping the BP0 and the 7th character:
e.g. BP037628001736 becomes 3768001736
Then start the car and enter the code. Hey presto, a working radio and £25 saved.
A couple of warnings: this will only work for Blaupunkt radios, not the Clarion or Alpine ones fitted in some Alfas. If it doesn't work first time (mine did) double-check the serial number. If you enter the code incorrectly 3 times it locks for an hour and you will need to keep the engine running for an hour before you can try again (it turns itself off after 20 minutes if the engine isn't running).
Hope this helps someone as it did me.
As with most Alfa's I will be looking for some help on all the other problems it has!
But i'm hooked so far!
« Zadnja izmjena: 27-01-2012, 22:11:02 od maki21 »
Offline dusan147
  • Postova: 287
    • Novi Sad
Odg: radio code
« Odgovori #1 u: 28-01-2012, 06:54:47 »
Biti Merlin, ne Artur!
