30-05-2026, 02:25:27
Autor Tema: Faralli & Mazzanti  (Posjeta: 3097 vremena)
  • Postova: 42935
Faralli & Mazzanti
« u: 16-06-2007, 08:49:47 »
Faralli and Mazzanti, an Italian classic car restoration company created a Maserati-powered sportscar, which will be shown at the Top Marques exhibition in Monaco
ANTAS V8 GT is the first “Berlinetta” (touring car) created in the F & M workshop. It is completely inspired by the philosophy and material used in the “special series” of the past: the body, for example, is made of aluminium and completely built by hand.
ANTAS is driven by a powerful V8 MASERATI engine fed by carburettors and endowed with a pleasing elasticity of power, which gives the “driver” the sensation of “true” steering typical of the great touring cars of the past. Because of this, when the time came to name this “jewel,” a word was chosen that comes from the ancient Tuscan language of the ETRUSCANS: ANTAS, which means EAGLE, the noblest and most audacious dominator of open spaces.
  • Postova: 42935
Odg: Faralli & Mazzanti
« Odgovori #1 u: 16-06-2007, 08:53:00 »
  • Postova: 42935
« Odgovori #2 u: 17-06-2007, 10:22:41 »
ANTAS V8 GT - TECHNICAL SPECIFICATIONS
MOTOR Front length V8 90°
CYLINDER 4719 cc
CURRENT 4 vertical carburettors with double body
TYPE Weber 38DCNL5
POWER 310 PS / 6000 rpm
MAX SPAN 43 Kgm / 3500 rpm
BODY Steel box frame
BODY Berlinetta 2 + 2 in aluminium
FRONT SUSPENSION Transverse quadrilateral with spiral spring, telescopic shock absorbers and stabilising bar
REAR SUSPENSION Rigid axle with telescopic shock absorbers and stabilising bar
BRAKES front 294 mm rear 285 mm
WHEELS Front and rear 7J X 17"
TYRES Front 205 / 50 X 17
          Rear 225 / 55 x 17
TRANSMISSION Rear traction
GEARS Manual ZF 5 gears + RM
DIMENSIONS length 4.750 mm length 1.780 mm capacity 2.750 mm height 1200 mm
TANK CAPACITY 80 litres
PERFORMANCE over 270 km/h
ACCELERATION 0-100 km/h in 5"
« Zadnja izmjena: 23-12-2011, 18:10:30 od SZ »
Offline fbajlo
  • Postova: 1040
« Odgovori #3 u: 11-03-2008, 13:51:14 »
Evo novog uratka: F&M Vulca V12, serija od 10 primjeraka, cijena sitnica
tri različita V12:
6,0 l, 445 KS, 600 Nm, 280.000 €
7,1 l, 520 KS, 730 Nm, 320.000 €
7,5 l, 600 KS, 800 Nm, 340.000 €
I evo par slikica....
[privitak je izbrisao admin nakon 90 dana od objave]
  • Postova: 42935
« Odgovori #4 u: 31-03-2009, 19:30:22 »
Tvrtka Faralli & Mazzanti, specijalizirana za izradu brzih i skupih automobila, u prodaju je pustila ograničenu seriju od svega deset primjeraka modela Vulca S, 630 KS snažnog kupea čija cijena prelazi 350.000 eura
Još jedan istinski supersportaš i maksimalno ekskluzivan automobil krenuo je u prodaju. Radi se o modelu Vulca S čija je završna izvedba prikazana na salonu Internazionale del Lusso u Vicenzi, održanom ranije ovog mjeseca. O samoj ekskluzivnosti najbolje govori podatak da će 630 KS snažne Vulce S biti proizvedeno svega deset primjeraka. Dodatak S u imenu Vulca prati koncepciju i linije baznog modela, predstavljenog prvi puta na Ženevskom salonu prošle godine, a čija je cijena tada bila određena između 280.000 i 340.000 eura. Faralli & Mazzanti Vulca S je u potpunosti ručno izrađena od aluminija, oslonjena na OZ Racing naplatke i Continental gume. U skupocjeni kupe stanu četiri osobe, a kao što se i očekuje od automobila ovakvog kalibra, opremljen je LED svijetlima te s četiri ispušne cijevi straga. Unutrašnjost je opremljena vrhunskim audio sustavom, ukrašena elementima od pravog drva te svim ostalim dodacima koje možete poželjeti u luksuznom sportskom automobilu. Tu su i dva velika LCD zaslona od kojeg jedan prikazuje brzinu kretanja i broj okretaja motora, a drugi, podatke s navigacijskog i audio sustava. Sjedala i cijeli kokpit ukrašena su ručno postavljenom vrlo kvalitetnom kožom. Svaka od deset Vulci S imati će svoj jedinstveni broj, a iako cijena S modela još nije objavljena, sigurni smo da je već unaprijed rasprodana bogatijoj klijenteli.
« Odgovori #5 u: 31-03-2009, 22:20:08 »
hebote, onaj gore plavi, ima lexus lampe od 147-ice...  :craz
Offline kinggo
  • Postova: 1441
  • 147 2.0 TS
    • ZG Dumovec
« Odgovori #6 u: 31-03-2009, 22:56:17 »
:funny: :funny: :funny:
OK dijelove imas, jos ti samo auto fali  :hehe:
Ova vulca   :love: :love: :love:
... a htio sam crnu...
Offline Igica
  • Postova: 8323
  • Alfa 146
« Odgovori #7 u: 01-04-2009, 13:47:21 »
Dobre su pile :ok: :ok:
  • Postova: 42935
« Odgovori #8 u: 06-12-2011, 20:18:10 »
  • Postova: 42935
  • Postova: 42935
« Odgovori #10 u: 29-12-2011, 21:39:14 »
F&M Evantra: Talijanski pastuh hvata stotku za 3.7 sekundi!
http://autoholik.net/noviteti/fm-evantra-talijanski-pastuh-hvata-stotku-za-37-sekundi
« Zadnja izmjena: 16-08-2018, 11:15:32 od a.m.alfa »
  • Postova: 42935
« Odgovori #11 u: 16-08-2018, 11:13:53 »
