12-06-2026, 03:22:51
Autor Tema: Karburatori na boxerima i sve vezano uz njih...  (Posjeta: 44341 vremena)
  • Postova: 8255
« u: 14-10-2009, 22:14:14 »
Pošto ću se upustit u projekt instalacije karburatora na 16V boxera, otvaram ovu temu da možemo razmijenit iskustva, podjelit savjete i riješit nepoznanice kojih, što se mene tiće, ima dosta...
Tema može poslužiti i za opću raspravu o karburatorima/fergazerima/rasplinjačima!  :ok:
Nabavio sam dva Dellorta DRLA 40, koje je plan rastavit, prekontrolirat i prebrtvit...
Došla je i knjiga naručena iz Dellorto shopa u Velikoj Britaniji, jer bez znanja se ne može ništa:
Knjiga je prvenstveno pisana za instalaciju i podešavanje DRLA na VW motorima, ali ima i opčenitih dijelova i veliko brdo korisnih informacija.
Opisani su i DHLA ležeći karbovi i FRD jednostruki karbovi.
Prenjeti ću ovdje dio uvoda knjige zbog izravne usporedbe Dellorto i Weber karburatora:
Citat:
The Dellorto DRLA series of carburetors were originally developed for use on the Alfa Sud automobiles and manufactured in 36, 40 and 45mm size. The introduction of the DRLA carburetors eliminated many of the problems presented by the aging Weber IDF series.
The DRLA was a modern, state of the art carburetor that featured sealed ball bearing main shafts, improved fuel emulsion, and a double hinge float and fuel system that prevented fuel starvation due to high G forces encountered in high speed turns and S's.
The Weber IDF's previously used on the Alfa Sud had been adapted from an early model Fiat. The Dellorto DRLA represented a fresh new design that was less sensitive to altitude and temperature changes than the older IDF. Most of all, Dellortos presented less restriction to flow, and made more horsepower than Webers, model for model.
Prior to the availability of the DRLA carburetors the Weber IDF and IDA series were the dominate high performance carburetors in use bv VW and Porsche enthusiast. IDF's were available in 40, 44 and 48mm models.
Knjigu je napisao Bob Tomlinson... On je prvi donesao Weber, a zatim i Dellorto u SAD, te ih počeo koristiti, prodavati i servisirati.
Evo njegove izjave nakon pojave DRLA serije: "First there was Weber and nothing else, now there's Dellorto, and nothing else."
Na dosta mjesta sam čuo da su Weberi bolji, ali po ovome to pada u vodu...
Dellorto je noviji, moderniji, jednostavniji i bolji karburator.
  • Postova: 8255
Odg: Karburatori na boxerima i sve vezano uz njih...
« Odgovori #1 u: 14-10-2009, 22:17:08 »
Evo, prva stvar koja mi je privukla zanimanje listajući knjigu...
Ako sam dobro shvatio, Dellorto nema čok nego nekakav drugi sistem obogačivanja smjese u prvih 30 sekundi rada motora.
Ajmo vi sa karbosima, tko može ovo potvrdit?
Mirko?  :?:
Offline Radge
  • Postova: 1463
    • Đurđenovac
« Odgovori #2 u: 14-10-2009, 22:21:24 »
ako se ja dobro sjećam
ima ispod volana sajla za čok
i kad nju povučeš obogačuješ smjesu
naravno nakon nekog vremena je vraćaš
kao i na svim autima sa čokom...
Mirko
« Odgovori #3 u: 14-10-2009, 22:23:39 »
 :da: :da: ručni čok, ja ga još nikad nisan povuka
  • Postova: 8255
« Odgovori #4 u: 14-10-2009, 22:55:26 »
Evo što piše u knjizi: "Dells don't have chokes and rely on the accelerator pumps to keep them running for the first 30 seconds."
A ja isto znam da na ovim karbovima što sam uzeo ima nekakav mehanizam za čok. Ovo je vjerojatno nekakva šema za dodatno obogačivanje smjese...
Gledajući crteže u knjizi, na tim VW instalacijama stvarno nigdje nema sajle ili polugica za čok...
Možda naiđem na objašnjenje dok budem čitao knjigu dalje!  :ok:
Offline boris
  • Postova: 1607
  • 147 Q
« Odgovori #5 u: 15-10-2009, 11:00:11 »
Ja imam ručni čok na Dellortu..
I uvijek palim sa njim, ali ga vrlo brzo vratim, a kad aam imao Webera i to dobro nastelanog, nije htio paliti sa čokom ali isto tako nije htio raditi bez njega kad je motor bio hladan. Tako da sam palio bez njega i onda ga ukljucio kad je motor upaljen.
Offline nikola bozic
  • Postova: 1148
« Odgovori #6 u: 15-10-2009, 14:05:33 »
Citaj,citaj.Nadam se da ima i poglavlje o troubleshooting-u.Imam mali problemmmmmm............. :metak
  • Postova: 8255
« Odgovori #7 u: 15-10-2009, 16:47:19 »
Uopće nije u pitanju čok sajla i taj sistem jer to nema veze s karbovima,postoje i karbovi koji imaju čok a nemaju sajlu. Radi se o sistemu čoka odnosno njegovoj izvedbi na karbu :hap: :mah: :mah: :mah:
Nisam shvatio ništa šta si napisao...  :hehe: :hehe: :hehe:
Daj pojasni... Sjećam se kak sam imao čok na Ladi. Sajla je otvarala i zatvarala čok leptir...
Predpostavljam da je ovo polugica čoka:
Ali nema leptira, nego radi nešto drugo.
I tu se vjerojatno spaja čok sajla...
Problem mi je što nisam to nikad vidio uživo na autu... :redf:
Mirko
« Odgovori #8 u: 15-10-2009, 16:50:14 »
tako je i kod mene  :ok:
Offline stararaga
  • Postova: 2079
  • The Night Rider
« Odgovori #9 u: 15-10-2009, 17:04:17 »
Tu se spaja sajla. :da:
Offline Joke
  • Postova: 2559
« Odgovori #10 u: 15-10-2009, 18:48:02 »
Kakva sad akcelerator pumpa, ja to nemam  :) :)
A imam čok koji povučem na hladno i vratim nakon 30 tak sekundi. Naime duže od toga pod čokom počne radit nemirno i hoće se ugasit, a ako vratim čok tako brzo odmah nakon pola minute spusti okretaje u ler i nastavi radit normalno. Trebam sredit karbove očito  :rolll:
Mirko
« Odgovori #11 u: 15-10-2009, 19:04:18 »
jel se ta pumpica pali samo kad povučeš čok i može li se napravit npr kad dođeš do 5000 okretaja da povučeš čok i da ta pumpica doda još malo goriva i onda auto poludi :hap:
Mirko
« Odgovori #12 u: 15-10-2009, 19:09:03 »
ništa od čuninga  :sad:
  • Postova: 8255
« Odgovori #13 u: 15-10-2009, 19:11:58 »
Ta pumpa je, predpostavljam, sa druge strane karburatora, na sredini, ona dolje mala membrana... :?:
Mirko
« Odgovori #14 u: 15-10-2009, 19:28:16 »
napokon neka poučna tema  :clap:
  • Postova: 1148
« Odgovori #15 u: 16-10-2009, 00:10:48 »
Vidi dali pise u knjizi dali se ta membrana stela i u kojim uvjetima posto ima na sebi polugicu sa sustom i malom maticom!!!
Offline alfa1600boxer
  • Postova: 164
  • 145 boxer
« Odgovori #16 u: 16-10-2009, 10:30:58 »
ako nekog zanima mogu špstaviti na forum ovu knjigu,jest da nije bas za 33 ali za 75 i ostale alfe s lezecim,ali ima i opcenito za ostale aute kako i sta
  • Postova: 1148
« Odgovori #17 u: 16-10-2009, 11:16:02 »
Odlicna ideja  :ok:.
Offline boris
  • Postova: 1607
  • 147 Q
« Odgovori #18 u: 16-10-2009, 14:01:39 »
Evo imam i ja:
The Haynes Weber Carburetor Manual - pdf
pa ako kome treba...
  • Postova: 164
  • 145 boxer
« Odgovori #19 u: 16-10-2009, 14:49:13 »
evo danas sutra kad uhvatim vremena cu pocet postavljat jer ima 60 strana sad neznam kako da postavim u obliku slika pa da okaci mna forum ili da u zip stavim pa da se skida
  • Postova: 8255
« Odgovori #20 u: 16-10-2009, 16:29:50 »
Najbolje bi bilo zipat ili nekako, pa poslat Boxeru, a on će dignut u downloads rubriku!  :ok:
A ovdje se stavi samo link!
Offline tool75
  • Postova: 2063
    • RI
« Odgovori #21 u: 27-10-2009, 15:40:40 »
Koliko dugo drže karbovi kad se naštelaju?
I koji bi uzrok mogao biti ako se auto gasi hladan, onako postepeno okretaj po okretaj, ne odmah nego doslovno gledaš kako pada okretaj po okretaj čak i pod čokom. Upali bez čoka inače.
Offline Joke
  • Postova: 2559
« Odgovori #22 u: 27-10-2009, 17:11:41 »
To se i meni dešava na hladno. Ako u tim momentima spustim čok, ostane u ler gasu dalje radit normalno
  • Postova: 1148
« Odgovori #23 u: 27-10-2009, 23:03:37 »
Mozda je problem u tome da vuce falsi zrak  :o000:.
Offline tool75
  • Postova: 2063
    • RI
« Odgovori #24 u: 29-10-2009, 17:00:33 »
Ma nek vuče, tako i tako je prodana dok sam se ja odlučivao.  :wal: 75-ica 2.0 karb.
Offline sven
  • Postova: 492
  • 33
« Odgovori #25 u: 29-10-2009, 18:56:27 »
E, jbg sad!  :metak
Vidiš šta piše Nikoli u potpisu...
  • Postova: 1148
« Odgovori #26 u: 08-11-2009, 21:35:16 »
Gašenje na leru je obično problem ler pumpice tj. membrane koja postane porozna :da:
Dali je itko od vas pokusao stelati te membrane s obzirom da imaj maticu i sipkicu za stelanje???
edvin
« Odgovori #27 u: 06-03-2011, 00:59:08 »
znam da mozda nije tema ali dali netko ima za prodati weberove karburatore u dobrom stanju i di bi se mogao kupiti set za reparaturu istih treba mi za 33 1.5 hvala ako moze na pm
  • Postova: 1148
« Odgovori #28 u: 06-03-2011, 10:12:59 »
Evo ti set za reparaturu:
http://www.oldschoolhr.com/forums/showthread.php?t=9469
Za karburatore pogledaj u oglasima ili stavi oglas da trazis.Javi se coviku na 098 273 555 Arman.Mozda ima jos kojega.
Offline silvio
  • Postova: 232
  • GTV 2.0 V6 TURBO 156 2.4 JTD
    • Cavtat
« Odgovori #29 u: 14-05-2011, 13:18:26 »
gdje se u slavoniji ili u dubrovniku moze kupiti set za reparaciju dellorto 36-ica. imam ih hrpu( nekih 8 ili 9) ali stoje vec godinama pa bi ih rastavio, dao na ščenje i reparaciju....
inače sam u slavoniji a trenutno i sljedečih par mjeseci u dubrovniku pa eto...
