10-06-2026, 23:00:00
Autor Tema: Alfa Romeo C52 Disco volante (Flying Saucer)  (Posjeta: 16788 vremena)
  • Postova: 42943
« u: 04-11-2006, 07:56:29 »
« Zadnja izmjena: 02-03-2007, 14:05:36 od a.m.alfa »
  • Postova: 42943
Odg: Alfa Romeo C52 Disco volante (Flying Saucer)
« Odgovori #1 u: 04-11-2006, 08:00:44 »
Disco Volante touring coupè
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #2 u: 04-11-2006, 16:58:17 »
disco volante 1900 C52
filmić od cca 9 minuta
    YouTube
      - Broadcast Yourself.
« Zadnja izmjena: 07-01-2007, 13:06:37 od veloce »
  • Postova: 42943
« Odgovori #3 u: 07-01-2007, 11:29:34 »
engine     Inline-6
position    Front Longitudinal
displacement    1997 cc / 121.9 cu in
power    117.8 kw / 158 bhp @ 6500 rpm
hp per litre    76.79 bhp per litre
bhp/weight    306.67 bhp per tonne
drive wheels    RWD
body / frame    Aluminum over Steel Space Frame
weight    750 kg / 1653 lbs
top speed    225 kph / 139.8 mph
  • Postova: 42943
« Odgovori #4 u: 07-01-2007, 11:30:23 »
One of the most original stylistic offerings form Alfa Romeo, the ‘Disco Volante’ (Flying Saucer) is a highly streamlined spider that was designed by Touring to participate in Sport Category races. Its name comes in part from science fiction, and in part from the descriptions of the first UFOs that feature highly in the collective imagination during this period. But it is also a way of describing an uncommon car, a low spider with rounded forms that does in fact owe a great deal to aerodynamic design, which was fundamental to Alfa Romeo. The convex body is described as the "ornamental model" for its aerodynamic characteristics, which give the car great penetration characteristics even in a side-wind. It was also created with two other types of bodywork, including a coupe and a slab sided model, but none of the cars got past the experimental stage.
Story by Alfa Romeo
  • Postova: 42943
« Odgovori #5 u: 27-02-2007, 18:23:50 »
Alfa Romeo Disco Volante - nepoznati cestovni objekt
Krajem 1951 godine Alfa Romeo odlučuje da se službeno povuče iz auto-sporta. Naravno, kada tvrtka tako bogata sportskim uspjesima objavi tako nešto ne čudi što svijet takvu vijest primi s određenom rezervom. Kako bilo, Talijani su u životu ostavili svoj sportski odjel kojemu je na zadatak dato da eksperimentiraju na šasijama i motorima. Već sljedeće godine razvijena je nova cijevasta spaceframe šasija koja se pokazala višestruko čvršćom od uobičajenih, rešetkastih (ljestve), bez povećanja težine. Na tu «svemirsku» šasiju ugradio se prednji i stražnji ovjes poznat iz modela 1900, a taj model je posudio i 2-litreni motor koji je za C52 (kako se nazivao taj novi projekt) prošao detaljnu preradu (blok od aluminija, Weberovi rasplinjači, ...), te je na kraju razvijao impresivnih 158 KS.
Da sve kod Alfe C52 izgleda napredno na kraju se pobrinula i dizajnerska kuća Touring. Dizajneri su se fokusirali na aerodinamičnost automobila, ali ne samo na prednjem dijelu, kao što je tada bilo uobičajeno, već i na bokovima. Zato je C52 ispao neuobičajeno zaobljen, s djelomično prekrivenim kotačima. Početkom 50-ih ovakav dizajn izgledao je itekako svemirski, pa je ubrzo nakon predstavljanja od strane javnosti prozvan letećim tanjurčićem, dok su u Alfi na C52 dodali službeni naziv Disco Volante. O uspješnosti dizajna dovoljno govori činjenica da i danas mnogi stručnjaci, ali i mnogi drugi ovu Alfu smatraju jednom od najljepših automobila svih vremena.
Nakon uspješnih testiranja u Monzi Talijani su shvatili da bi njihov eksperiment mogao postići vrlo dobre rezultate i na utrkama, pa lako zaboravljaju ideju da se povuku iz auto-sporta. Jedini problem bio je što se pri brzinama od 220 km/h 750 kg težak, odnosno lagan Disco Volante znao opasno podizati od tla, i sprijeda, i straga. Vjerojatno zato, Alfa se na kraju nije niti pojavila na Le Mansu iako se već najavila, i to s legendarnim Fangiom, te Gonzalesom i Corteseom kao vozačima. Godine 1953 Touring je izradio još jedan Spider i poseban kupe koji je trebao postizati bolje rezultate na brdskim utrkama, gdje se Spider po uskim zavojima i nije baš najbolje ponašao.
Disco Volante se ipak nikada nije pojavio na utrkama. Alfa je odlučila nastupati, ali s drugim modelom (6C 3000 CM) koji izgledom je podsjećao na Disco, ali imao je klasičnu šasiju i tako je u neku ruku naspram njega bio nazadan, a ne napredan model. Spaceframe šasija u Alfama je zaživila ponovo tek desetljeće poslije.
Alfa Romeo Disco Volante u svojoj Spider (na slici) i Coupe izvedbi iz godine u godinu nastupa na izložbama dizajna i elegancije gdje uredno mami poglede i izaziva uzdahe. Vlasnik je jedan – povijesni muzej u Areseu.
  • Postova: 42943
« Odgovori #6 u: 17-09-2008, 21:10:49 »
Alfa Romeo C52 Disco Volante 'Narrow Hipped' Spider
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #7 u: 02-11-2008, 21:32:16 »
Serfo
« Odgovori #8 u: 02-11-2008, 22:33:34 »
 :da: :ok:
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #9 u: 22-09-2009, 16:14:47 »
  • Postova: 42943
« Odgovori #10 u: 31-12-2009, 10:23:03 »
AR 3000 Disco volante
Offline veloce
  • Postova: 2255
    • kostrena
« Odgovori #11 u: 18-02-2010, 23:10:49 »
  • Postova: 42943
« Odgovori #12 u: 06-06-2010, 21:17:03 »
« Zadnja izmjena: 26-11-2014, 20:49:11 od a.m.alfa »
  • Postova: 42943
« Odgovori #13 u: 27-11-2010, 20:54:35 »
« Zadnja izmjena: 26-11-2014, 20:47:37 od a.m.alfa »
  • Postova: 42943
  • Postova: 42943
« Odgovori #15 u: 17-03-2012, 07:10:12 »
  • Postova: 42943
« Odgovori #16 u: 17-09-2019, 18:59:40 »
  • Postova: 6230
« Odgovori #17 u: 17-09-2019, 19:01:30 »
kakav auto....uživo spektakl...
« Zadnja izmjena: 17-09-2019, 19:03:53 od piquet »
  • Postova: 6230
« Odgovori #18 u: 17-09-2019, 19:10:51 »
  • Postova: 42943
« Odgovori #19 u: 15-12-2019, 09:20:59 »
  • Postova: 42943
« Odgovori #20 u: 31-01-2020, 18:49:03 »
  • Postova: 42943
« Odgovori #21 u: 10-05-2021, 07:49:41 »
  • Postova: 42943
« Odgovori #22 u: 10-04-2022, 20:33:55 »
  • Postova: 42943
« Odgovori #23 u: 10-04-2022, 20:34:33 »
  • Postova: 42943
« Odgovori #24 u: 30-12-2023, 07:47:59 »
