16-11-2025, 11:03:37
Autor Tema: Alfa 33  (Posjeta: 595888 vremena)
Offline Veco
  • Postova: 601
  • Alfa Romeo
Odg: Alfa 33
« Odgovori #3900 u: 28-08-2009, 22:43:04 »
NSU prinz je imao tvorničke utege za naručiti za prednji kraj iz istog razloga.
Taj auto se isto dizao na ubrzanju, katastrofa...
No BOXER no FUN................................16V :drive:
402m= 15.7 s
Offline Veco
  • Postova: 601
  • Alfa Romeo
Odg: Alfa 33
« Odgovori #3901 u: 29-08-2009, 17:29:18 »
402m= 15.7 s
Offline Veco
  • Postova: 601
  • Alfa Romeo
Odg: Alfa 33
« Odgovori #3902 u: 29-08-2009, 17:32:06 »
Malo karburatori...
402m= 15.7 s
Boxer
Odg: Alfa 33
« Odgovori #3903 u: 29-08-2009, 17:40:44 »
Karbovi su zakon :ok: Ovo je koliko vidim neki 8v turbo :da:
Offline Veco
  • Postova: 601
  • Alfa Romeo
Odg: Alfa 33
« Odgovori #3904 u: 29-08-2009, 17:43:31 »
Jesu da,  8V je ali turbo nisam vidio :?:
402m= 15.7 s
Boxer
Odg: Alfa 33
« Odgovori #3905 u: 29-08-2009, 17:48:38 »
Nemaju mi ovolike cijevi na hladnjak ulja previše smisla na običan 8v :hap:
Offline Veco
  • Postova: 601
  • Alfa Romeo
Odg: Alfa 33
« Odgovori #3906 u: 29-08-2009, 17:51:27 »
Nikad neznaš šta ljudi kemijaju... ali karburatori na 16V to je posao
402m= 15.7 s
Offline Keke
  • Postova: 1755
    • Zagreb Centar
Odg: Alfa 33
« Odgovori #3907 u: 30-08-2009, 18:11:54 »
turbo nije ziher, a ovo lijevo je hladnjak vode a desno za ulje, ne vidim nigdje intercooler, a ni turba nema na vidiku
Offline Zagi17
  • Postova: 2524
    • Sv.Martin na Muri,Međimurje
Odg: Alfa 33
« Odgovori #3908 u: 30-08-2009, 19:04:21 »
 Pronašao na netu pa mi bilo zanimljivo...
The Alfa Romeo 33 is a small family car produced by the Italian automaker Alfa Romeo between 1983 and 1995. It was essentially an evolution of its predecessor, the Alfasud, which was based on the same floorplan, chassis and mechanicals albeit with some minor modifications. The 33 was discontinued in 1994 and replaced by the Alfa Romeo 145 and 146, which used the same boxer engines but built around an entirely new platform based on the Fiat Tipo.
The 5-door hatchback version was launched in 1983, and a station wagon version (initially badged Giardinetta, later badged SportWagon) was introduced the following year at the same time as a four-wheel drive version of the hatchback. The hatchback was styled by the Centro Stile Alfa Romeo, Ermanno Cressoni, while the station wagon was designed by Pininfarina.
The 33 became renowned for its nimble handling and powerful boxer engines, but also became equally well-known for its unreliable electronics and tendencies to rust (a frequent complaint on Italian cars in general at the time). Another issue was its braking and increased unsprung weight — the Alfasud's inboard front disks (mounted on the gearbox) had been moved to the more common outboard disks (mounted on the wheel hubs). The rear disks of the Sud's four-wheel disk arrangement had also been replaced with drums from the Nissan Cherry, as used on the Arna.
The 33 has a unique place in Alfa Romeo history - nearly 1 million of these cars were produced internationally.
During its 11 year lifespan the 33 saw two restyles; In consequence Alfisti tend to label each styling trend of the 33 after the flagship vehicle produced by Alfa Romeo at that time.[citation needed]
The First 33's are sometimes referred to as 'Alfa 90' 33s, as they most resemble that car. Further re-styles were to follow: a mild one in autumn 1986 (the Series II), when the 1.7 litre engine was introduced and a revised interior; these are known as 'Alfa 75' 33s. Later followed a much more extensive facelift in the end of 1989 (the Series III), with a revised interior, the introduction of fuel injection, the 1.7 litre engine upgraded to include a 137 bhp 16 valve version, and a heavily restyled exterior, in line with the new Alfa "family look" established by the flagship 164. Also new four wheel version was introduced called the Permanent 4, which was renamed to Q4 starting from 1992. The last 33s are known as either 'Nuova' or '164' 33s for their resemblance to that model. These models are particularly prized by Alfisti for their performance and sophistication. Late production 33s also do not suffer from the rust problems of their ancestors, as their frames are galvanized in the manner Alfa introduced with the 164.
First series (1983-1986)
Engines
    * 1.2 1186 cc flat-4, 50 kW (68 PS; 67 bhp) @6000 rpm, 92 N·m (68 ft·lbf) @3200 rpm (Single carburettor)
    * 1.3 1351 cc flat-4, 58 kW (79 PS; 78 bhp) @6000 rpm, 113 N·m (83 ft·lbf) @3500 rpm (Single carburettor)
    * 1.3 1351 cc flat-4, 63 kW (86 PS; 84 bhp) @5800 rpm, 121 N·m (89 ft·lbf) @4000 rpm
    * 1.5 1490 cc flat-4, 62 kW (84 PS; 83 bhp) @5800 rpm, 123 N·m (91 ft·lbf) @3500 rpm
    * 1.5 1490 cc flat-4, 70 kW (95 PS; 94 bhp) @5750 rpm, 133 N·m (98 ft·lbf) @4000 rpm (Twin carburettor)
    * 1.5, 1490 cc flat-4, 77 kW (105 PS; 103 bhp) @6000 rpm, 136 N·m (100 ft·lbf) @4000 rpm (Twin carburettor)
Second series (1986-1989)
Engines
    * 1.3 flat-4, 58 kW (79 PS; 78 bhp) (Single carburettor)
    * 1.3 flat-4, 63 kW (86 PS; 84 bhp) (Twin carburettor)
    * 1.5 flat-4, 77 kW (105 PS; 103 bhp) (Twin carburettor)
    * 1.5i flat-4, 77 kW (105 PS; 103 bhp) (Twin carburettor)
    * 1.7 flat-4 , 1712 cc, 87 kW (118 PS; 117 bhp) (Twin carburettor)
    * 1.8 TD straight-3, 1779 cc, 54 kW (73 PS; 72 bhp) (KKK 14 turbocharger)[2]
Third series (1989-1995)
Engines
    * 1.4 ie flat-4 , 66 kW (90 PS; 89 bhp) (Weber IAW)
    * 1.5 flat-4, 77 kW (105 PS; 103 bhp) (Twin DRLA40 carburettors)
    * 1.5 ie 1490 cc flat-4, 70 kW (95 PS; 94 bhp) @6000 rpm, 125 N·m (92 ft·lbf) @4500 rpm
    * 1.7 ie 1712 cc flat-4, 81 kW (110 PS; 109 bhp)/cat. 77 kW (105 PS; 103 bhp) @5800 rpm, 145 N·m (107 ft·lbf) @4500 rpm (Bosch L3.1)
    * 1.7 ie 16V 1712 cc flat-4, 95 kW (129 PS; 127 bhp) @6500 rpm, 151 N·m (111 ft·lbf) @4600 rpm (Bosch Motronic ML4.1)
    * 1.7 ie 16V flat-4, 101 kW (137 PS; 135 bhp)/cat. 97 kW (132 PS; 130 bhp) (Bosch Motronic ML4.1)
    * 1.8 TDI straight-3, 62 kW (84 PS; 83 bhp)
 :love: :love: :love:
La mia Alfa 33
La mia Alfa 156
Offline nezdr4v
  • Postova: 2654
  • Hyundai Accent
Odg: Alfa 33
« Odgovori #3909 u: 30-08-2009, 19:09:24 »
fali tu još dosta motora  :craz
i koliko ja znam serija 3 počinje od 1990 god.
Offline Zagi17
  • Postova: 2524
Odg: Alfa 33
« Odgovori #3910 u: 30-08-2009, 19:15:28 »
Znam da fali ali to sam našao..... :rolll:
La mia Alfa 33
La mia Alfa 156
Boxer
Odg: Alfa 33
« Odgovori #3911 u: 31-08-2009, 09:22:27 »
Intercooler nije neophodan a da se kemija na nečem se vidi po tome da je rpm senzor iz nekog razloga preseljen naprijed a obično se straga spajaju isušne cijevi u kolektor i stavlja se turbo...Ovo je moguće samo priprema odnosno radovi u tijeku :hap:
Offline Veco
  • Postova: 601
  • Alfa Romeo
Odg: Alfa 33
« Odgovori #3912 u: 31-08-2009, 13:42:28 »
Evo kao šta je Boxer mislio, jeli tako :?:
Jedna sa turbakom
402m= 15.7 s
Boxer
Odg: Alfa 33
« Odgovori #3913 u: 31-08-2009, 14:02:16 »
Da al ovo je IE a onaj gore je na karbove :love: :love:
Offline stararaga
  • Postova: 2079
  • The Night Rider
Odg: Alfa 33
« Odgovori #3914 u: 31-08-2009, 19:18:17 »
Karbovi+turbo= :ling: :ling: :ling:
Offline Zagi17
  • Postova: 2524
Odg: Alfa 33
« Odgovori #3915 u: 01-09-2009, 14:31:50 »
Šta se mučit kupiš nešto ovakvo i  :mahm :mahm
La mia Alfa 33
La mia Alfa 156
Boxer
Odg: Alfa 33
« Odgovori #3916 u: 01-09-2009, 20:20:10 »
I kaj s time???? Taj pogon niti je dobar niti je trajan niti je kvalitetan niti daje neka posebna vozna svojstva, pogotovo na tak malom laganom autu ukratko pendala :hap:
Offline sfreak
  • Postova: 2111
    • Jadranovo
Odg: Alfa 33
« Odgovori #3917 u: 01-09-2009, 21:19:29 »
ja bi ju samo zato jer je rijetka...i kao neki top model
Boxer
Odg: Alfa 33
« Odgovori #3918 u: 01-09-2009, 21:24:40 »
Bolje je imat jednu koja radi kak treba nego 2 koje uglavnom ne rade kak treba  :da:
Offline RoadRunner
  • Postova: 7764
Odg: Alfa 33
« Odgovori #3919 u: 02-09-2009, 10:33:39 »
Imam ja  :craz ,al mal pogon ne šljaka :hehe:
Gas Guzzler
Offline tvatavuk
  • Postova: 147
  • 33 S 16v Permanent4 GMo & 166 V6 3.2
Odg: Alfa 33
« Odgovori #3920 u: 04-09-2009, 16:29:19 »
SFreak- Top model je jos imao suncani krov, antenu, bio proizveden cca 2 god kasnije i imao oznaku Q4 :)
Nazalost kupovina jedne takve u dobrom stanju je bila nemoguca misija jos prije 11 god u nas  a kamo li sada kada svaka takva iza sebe ima 10 pristicavih vozaca koji su jedva prosli vozacki i zadnju lipu dali za kupovinu takve alfe i 2 litre benzine koliko im treba za drag jer misle  da su kupovinom 4x4 pogona dobili 33icu brzu od obicne 16v i onda je izmatretirali do kraja i preprodali.
Pogon je odlican za ono sto je zamisljen i tko tvrdi drukcije ocito se nikad nije vozio u njoj. Trajan je i kvalitetan kao i svaki 4x4 pogon u toj klasi automobila i cjenovnom rangu. Besmisleno ga je uspoređivati s 4x4 pogonima iz vise klase kao sto su  155, 164 i sl.
* Edit izbrisan jedan nika viska :)
« Zadnja izmjena: 10-09-2009, 22:17:26 od tvatavuk »
Offline 33 - 1.7 - 16v
  • Postova: 625
  • CuoreSportivo
    • slavonski brod
Odg: Alfa 33
« Odgovori #3921 u: 05-09-2009, 12:05:51 »
Pogon je odlican za ono sto je zamisljen i tko tvrdi drukcije ocito se nika nikad nije vozio u njoj. Trajan je i kvalitetan kao i svaki 4x4 pogon u toj klasi automobila i cjenovnom rangu. Besmisleno ga je uspoređivati s 4x4 pogonima iz vise klas kao sto su  155, 164 i sl.
na ovom forumu ti svi sve znaju bez i da probaju ...  :kosa:
vlada jedna vrsta vidovitosti... :da:
čudim se da to nisi uočio ... :?:
svaka 33 je smeče bila ona ovakva ili onakva sve su isto smeče...
netreba se uopče puno truditi da se to promjeni ,,
oni su pročitali da 33 nevalja i probali koju razvaljenu  33ojku i sad znaju sve o njima i na tome baziraju mišljenje ... :rolll:
nemislim konkretno na nikog iz ove teme več opčenito na ovom forumu su sveznalice ...
Offline nezdr4v
  • Postova: 2654
  • Hyundai Accent
Odg: Alfa 33
« Odgovori #3922 u: 05-09-2009, 12:13:03 »
teško se više šta pametna nađe na forumu nažalost...sve se svelo na ko je brži i pametniji i na stavljanje slikica u kako izgledamo i slične offtopic pizdarije
Boxer
Odg: Alfa 33
« Odgovori #3923 u: 05-09-2009, 12:25:14 »
Sad će recesija na takve stvari :ok: :da: :da: DOsta je bilo godišnjeg i popuštenih uzda :ok:
  • Postova: 625
  • CuoreSportivo
    • slavonski brod
Odg: Alfa 33
« Odgovori #3924 u: 06-09-2009, 12:14:38 »
rr ovaj je gratis trebaš mrežice druge stavit ...
a ovaj zeleni 200kn ...
imam i u tvojoj boji možda ali je na tavanu a nemogu se sad penjat...
vjerujem da ima i crni posve... :ok:
(nisam znao gdje da stavim pa stavljam ovdje)
Offline petra
  • Postova: 2698
  • 156 SW
    • Grad na 4 rijeke
Odg: Alfa 33
« Odgovori #3925 u: 07-09-2009, 19:09:38 »
 :mah: :mah:
Nepoznat vlasnik, nepoznata sudbina ...!  :sad: :sad:
Postoje dvije vrste ljudi:
Offline tool75
  • Postova: 2063
    • RI
Odg: Alfa 33
« Odgovori #3926 u: 07-09-2009, 19:42:49 »
Šteta. Prava boja, pravi motor, dobre felge i nema hrđe oko tanka.
Boxer
Odg: Alfa 33
« Odgovori #3927 u: 07-09-2009, 20:07:41 »
Pogledaj malo bolje :craz
Odg: Alfa 33
« Odgovori #3928 u: 07-09-2009, 20:14:29 »
i tko će bit spasitelj....?  :craz
Offline sven
  • Postova: 492
  • 33
Odg: Alfa 33
« Odgovori #3929 u: 07-09-2009, 20:16:01 »
Krasna 33, treba joj ostaviti neki letak ili poruku pod brisačem!
Meni ovo izgleda kao blato koje se nakupilo u utoru čepa pa curi niz blatobran kako ga kiše ispiru....
