28-11-2026, 09:20:36
Autor Tema: Twin spark motori  (Posjeta: 247767 vremena)
  • Postova: 43294
Twin spark motori
« u: 31-10-2006, 21:10:52 »
The Alfa Romeo Twin Spark (TS) technology was originally developed by Alfa in the early 1960s in their race cars (GTA, TZ) to enable it to achieve a higher power output from its engines. And in the early and middle 1980s, Alfa Romeo incorporated this technology into their road cars to enhance their performance and to comply with stricter emission controls.
The 'Twin Spark'
The TS series engines are all '4 cylinder inline' with twin cam (DOHC) shafts, and are developed first with 8 and later with 16 valves. All cars featuring the Twin Spark engines since the Alfa Romeo 155 (which originally also came with the 8V unit) use the 16 valve models over the 8V ones. The Twin Spark name comes from the fact that there are two spark plugs per cylinder. The two sparks on the early Alfa twin spark engines fired on the power stroke to help create a larger flame front ensuring less unburnt fuel in the exhaust as well as a higher thermodynamic efficiency. The 8V units have 8 identical spark plugs, while the 16V ones have a larger and a smaller plug in each cylinder. On the later 16v TS engines the smaller plug ignites on the exhaust stroke to reduce emissions. The common TS 16V engines, 1.6, 1.8 and 2.0, all use a 10 mm diameter and a 14 mm diameter plug per cylinder.
TwinSpark EngineThe engines also incorporate two devices to improve the performance under normal operation, the Camshaft Phase Variator and the air intake Variable Inlet Control on the two litre version.
« Zadnja izmjena: 28-07-2007, 10:52:14 od a.m.alfa »
  • Postova: 43294
Odg: Twin spark motori
« Odgovori #1 u: 31-10-2006, 21:15:24 »
Twin Spark 8v
Twin Spark 16v
akiramar
« Odgovori #2 u: 01-11-2006, 20:49:32 »
Twin Spark 8v
 :love: Ovaj sam motor imao ja u 155ici
Hvata me nostalgija... :sad:
Offline Buggy
  • Postova: 144
  • Alfa 159 SW, Alfa Spider 916
    • Mauro's Films
« Odgovori #3 u: 02-11-2006, 02:21:07 »
i mene..al bolje..sad imam onu sa 16v :hello:
DRIVING: 159 SW, Spider 916
Driven: Alfa 155 1.8 T.S.--ALFA 33 1.3 --ALFA 145 QV -
Offline reddevill
  • Postova: 9518
  • 147 1.6 TS , BMW E60
    • Njemacka - Stuttgart
« Odgovori #4 u: 03-11-2006, 12:13:25 »
Twin Spark:
dvije svijećice bolje pale
 :?: zbog čega neki automobili imaju dvije svijećice po cilindru?
-dvije svijećice po cilindru (twin spark) osiguravaju kvalitetnije i
učinkovitije paljenje benzinskog motora,no ta je tehnologija
znatno kompliciranija i skuplja od klasične te se rijetko koristi.
Dvije svijećice su prvi puta ugrađene 1906 g.u Rolls Royce.
Značajnije korištenje nije počelo u auto industriji več u
zrakoplovnoj industiji (zbog pouzdanosti).
Alfa Romeo ovu tehnologiju 90-ih godina uveo je u visokoserijsku
proizvodnju,u četverocilindarskim motorima,a posebice je zanimljiva
izvedba sdvije svijećice i četri ventila po cilindru.
Ddvije svijećice po cilindru omogučavaju stupnjevito paljenje iskre,
ovisno o brzini vrtnje i opterećenju motora .Time se poboljšava paljenje
smjese i omogućava bolje izgaranje,što pridonosi povećanju snage
motora te smanjenju potrošnje benzina i emisiju štetnih plinova.
Evo malo objašnjenja za T.S. :hello: :ok: :alfisti:
BigSaint
« Odgovori #5 u: 01-12-2006, 23:44:43 »
Znači li to da sa povlačenjem 147 (u dogledno vrijeme) i ''legendarni'' TS motori odlaze u povjest? :?: :sad:
Boxer
« Odgovori #6 u: 02-12-2006, 09:46:14 »
Vjerojatno da :da: :da: :da:
  • Postova: 43294
« Odgovori #7 u: 26-02-2007, 19:00:38 »
Offline Viktor
  • Član Alfa kluba 17
  • Trade Count: (+21)
  • Postova: 9231
« Odgovori #8 u: 11-06-2007, 19:53:57 »
Danas sam prvi put vidio da su kod TS motora spojene svjećice od 1. i 4. zajedno i 2. i 3. cilindra. Znači kada na 1. cilindru svjećica baca iskru za paljenje smjese, u isti trenutak baca iskru i u 4. cilindru koji je u fazi završetka ispuha (i obrnuto). Znači baca varnicu u ispušne plinove. Koja je svrha toga, meni to djeluje malo suludo?
Offline robi v6
  • Postova: 139
    • Buzet
« Odgovori #9 u: 11-06-2007, 20:02:35 »
To je samo iz ekoloških razloga. Pali se još jednom neizgorena smjesa. Ja sam ih probao spojit da se pale istovremeno dvije na svakom cilindru. Mislio sam da bi mogao ić malo bolje ali ista stvar. Kad sam ga spojio na eko test rezultati su bili puno lošiji nego standardno ali ne toliko da nebi prošao tehnički.
Offline reddevill
  • Postova: 9518
« Odgovori #10 u: 11-06-2007, 20:05:17 »
možda je svrha toga da bude iskoristivos što veča  :?:
Offline Viktor
  • Postova: 9231
« Odgovori #11 u: 11-06-2007, 22:04:16 »
To drugi motori nemaju pa ipak dobro rade. Mislim da je to najviše marketinški trik, imati nešto što drugi nema.
Enver
« Odgovori #12 u: 11-06-2007, 22:21:42 »
Je, noviji TS motori su imali tako da u isto vrijeme recimo mala i velika u istom cilindru pale, bas jednom pitao seb-a ako slobodno stavim da mi se pale u isto vrijeme, jer imam taj stariji TS, pa rekao da nece bit nikakve promjene, sto se tice snage i tih gluposti.
nego, jer moguce da ova mala zapali smjesu normalno, pa ako jedna ode, onda ove pomocne dozvoljavaju da motor radi an sva 4 cilindra, mozda malo grublje  :?:
adnan
« Odgovori #13 u: 07-09-2007, 17:36:24 »
twin spark sistem je prvenstveno zamisljen u zrakoplovstv za bolje iskoristavanje smjese i bolji rad motora na velikim visinama,rolls-roys motori za avione,pozdanost je velika a druga svjecica pali neizgoreni dio smjese povecava snagu i uspot smanjuje udio stetnih ispiusnih gasova, mercedes ga ugradjuje  u svoje motore a i neki japanski pruoizvodjaci,pozdrav za sve alfiste,i ja imam ts 164 i prava je zvjerka  :clap:
adnan
« Odgovori #14 u: 08-09-2007, 22:24:49 »
nije tako, kada prva svjecica baci iskru druga u neizgorni dio ispusnih plinova baca drugu iskru,malo bolje pogledaj,dakle cilj je veca snaga,bolja iskoristivost smese i na kraju manje zagadjenje!!!!
  • Postova: 43294
« Odgovori #15 u: 06-11-2007, 16:36:19 »
The Alfa Romeo twinspark engine in F3 racing
http://www.berlinasportivo.com/marquespec/Alfa/pdfs/artsf3.pdf
Magazine explanation of the Alfa Romeo twinspark system from the early 1990's
http://www.berlinasportivo.com/marquespec/Alfa/pdfs/twinspark.pdf
josip
« Odgovori #16 u: 15-02-2008, 20:52:09 »
Pozdrav svim alfistima!
Evo ja sam jedan od vlasnika 145 2.0 16 v TS i upravo sam proslavio 200 000 km. Još uvijek ide kao metak, također i plin sam ugradio i nemam primjedbe. Ali u zadnje vrijeme potrošnja mi je porasla , a i  termostat mi stalno pokazuje 60 ¨C.  Ali ovakav auto se nedaje svakome u ruke, svašta sam doživio...Tražim dobar savjet
Offline Dalibor-L
  • Postova: 2386
« Odgovori #17 u: 16-02-2008, 23:28:26 »
Promijeni termostat i riješit ćeš oba problema.  :ok:
Fiuman
« Odgovori #18 u: 14-04-2008, 17:37:41 »
Alfa Romeo Twin Spark engine
From Wikipedia, the free encyclopedia
Alfa Romeo TwinSpark engine
Manufacturer Alfa Romeo
Type: DOHC 2/4-valve I4
Production: 1986–
Predecessor: Alfa Romeo Twin Cam
Displacement: 1.4 L
1.6 L
1.7 L
1.8 L
2.0 L
Block alloy: aluminium alloy
and cast-iron
Head alloy: aluminium alloy
Power output: 76 kW (103 PS) - 114 kW (155 PS)
Alfa Romeo Twin Spark (TS) technology was used first time in Alfa Romeo Grand Prix car in 1914.[1] In the early 1960s it was used their race cars (GTA, TZ) to enable it to achieve a higher power output from its engines. And in the early and middle 1980s, Alfa Romeo incorporated this technology into their road cars to enhance their performance and to comply with stricter emission controls.
Contents [hide]
1 The 'Twin Spark'
2 Variable Inlet Control
3 Variable valve timing
4 2 valve Twin Spark engines
5 4 valve Twin Spark engines
 The 'Twin Spark'
Twin Spark name refers usually engines made after 1986 when the 164 Twin Spark was introduced. The TS series engines are all '4 cylinder inline' with twin cam (DOHC) shafts, and are developed first with 8 valves (an all alloy wet-liner engine, chain driven) and later with 16 valves (a modern iron block engine with alloy head, belt driven). All cars featuring the Twin Spark engines since the Alfa Romeo 155 (which originally also came with the 8V unit) use the 16 valve models over the 8V ones. The Twin Spark name comes from the fact that there are two spark plugs per cylinder.
The two sparks on the Alfa twin spark engines fire one after the other on the power stroke causing higher compression as the flame front travels across the combustion chamber. The second spark fires in the extra compressed mix, ensuring a cleaner burn and less unburnt fuel in the exhaust as well as a higher thermodynamic efficiency. The 8V units have 8 identical spark plugs, while the 16V ones have a larger and a smaller plug in each cylinder. On the later 16v TS there are 4 independent 8-ampere coils, connected to plugs; 1a and 4a, 1b and 4b, 2a and 3a, 2b and 3b. This arrangement facilitates the separate firing of the spark plugs in each combustion chamber, and also saves parts by utilising a "wasted spark" system, where - between the exhaust and inlet stroke of each pistons "partner" - a useless spark occurs, this may improve emissions very slightly, but the intention is to reduce cost. The common TS 16V engines, 1.6, 1.8 and 2.0, all use a 10 mm diameter and a 14 mm diameter platinum electrode spark plug per cylinder.
The spark plugs of the 8V TS Alfa Romeo engine are symmetrically located in the upper part of the chamber to the sides of the line passing from the opposing intake and exhaust valves and this allows the usage of larger intake valves due to the missing central spark. Thus the 2L version of the 8V engine uses 44mm intake valve. By firing the spark plugs at the same time and considering their location the burning lasts shorter time (faster burn) because the mixture is ignited simultaneously from 2 different locations. This allows usage of less ignition advance than when using single spark ignition.
The engines also incorporate two devices to improve the performance under normal operation, the Camshaft Phase Variator and the air intake Variable Inlet Control on the later (plastic cam cover) 1.8 and 2.0 litre versions.
The advancing of the inlet camshaft by 30 degrees (or 15 camshaft degrees) which makes the intake valves open and close earlier, when the predetermined rpm and load range is reached, makes the compression phase of the combustion process to begin earlier than when the camshaft is not in its advanced state and in this way the dynamic effective compression ratio is increased which produces more torque at the given engine speed. Also as the intake valve is also opened earlier the valve overlap is also increased at that mode. On some similar inlet cam phasing systems like VANOS the phasing is returned to the retarded state at higher rpm.
16 valve Twin SparkThe Variable Inlet Control causes the air intake (plenum) to shorten its path from the intake trumpet to the valve bores, again when the engine reaches a pre-defined RPM. This works on the principle that the air intake length is a tuned pipe that when operating at its ideal frequency-in tune with the valves, will allow a smooth and even air flow, and will assist with filling the cylinders efficiently. This works in a similar method to the tuned exhaust system on all modern cars, where the exhaust system creates back pressure to pull spent gasses from the cylinder bores. Modifying this tuned system in any way and failing to re-tune it will create performance drops.
The notable effect that these two devices have is that the engine will surge powerfully forward on hitting the ~4300 rpm mark, right up to the RPM limiter.
In the lower RPM mode the air path is longer which increases the intake air speed and improves mixing, combustion, emissions and low rpm torque.
It is a type of Variable Length Intake Manifold
Variable valve timing gave the Twin Spark engine very good performance for its cubic capacity it is one of the weaker areas of the 16 valve engine. The variator solenoid that controls the cam timing is prone to wear or jam. Symptoms are a slight loss of performance and a diesel type rattle from the top of the engine, which appears at startup and gradually lasts for longer. It is therefore adviseable to get the variator changed regardless of its apparent condition at the 36,000 mile (60,000 km) cambelt replacement. The variator problem is not often seen in the earlier 8V Twin Spark version, as these use a different type of cam timing variator system.
1.7 L 1749 cc 84 kW (115 PS) @6000 rpm, 146 N·m (108 ft·lbf) @3500 rpm
1.8 L 1773 cc 98 kW (129 PS) @6000 rpm, 165 N·m (122 ft·lbf) @5000 rpm
2.0 L 1962 cc 109 kW (148 PS)@5800 rpm, 186 N·m (137 ft·lbf) @3000 rpm
2.0 L 1995 cc 104 kW (143 PS) @6000 rpm, 187 N·m (138 ft·lbf) @5000 rpm (cat.)
applications:
Alfa Romeo 75
Alfa Romeo 155
Alfa Romeo 164
1.4 L 1370 cc 76 kW (103 PS) 6300 rpm, 124 N·m (91 ft·lbf) @4600 rpm
1.6 L 1598 cc 77-88 kW (105-120 PS) @5600-6200 rpm, 140-146 N·m (103-108 ft·lbf) @4200-4500 rpm
1.8 L 1747 cc 103-106 kW (140-144 PS) @6500 rpm, 163-169 N·m (120-125 ft·lbf) @3500-3900 rpm
2.0 L 1970 cc 110-114 kW (150-155 PS) @6400 rpm, 181-187 N·m (133-138 ft·lbf) @3500-3800 rpm
applications:
Alfa Romeo 145
Alfa Romeo 146
Alfa Romeo 155
Alfa Romeo 164
Alfa Romeo GTV (Type 916)
Alfa Romeo Spider (Type 916)
Alfa Romeo 156
Alfa Romeo 147
Alfa Romeo 166
« Zadnja izmjena: 14-04-2008, 17:41:06 od Fiuman »
Fiuman
« Odgovori #19 u: 14-04-2008, 17:51:18 »
Twin Spark
Normal engines have one spark plug per cylinder. However, since decades ago, Alfa Romeo insisted to put 2 spark plugs in each cylinder. As ignition takes place in two locations rather than one, this enable more efficient combustion and cleaner emission. However, besides Alfa, in the past 15 years only Mercedes and Porsche have ever applied Twin Spark design to their engines. This is mainly because of the complexity of cylinder head - it would be too difficult to put 4 valves and 2 plugs into the small cylinder head area. ( Mercedes' and Porsche's engines are 3 valves and 2 valves per cylinder respectively, so they have no such problem.) Only Alfa Romeo applied it to 4-valve engines.
   Alfa's famous 2.0 TS engine
Offline bansi
  • Postova: 459
  • Alfa GT M-jet, BMW 540i, Yamaha MT-07
« Odgovori #20 u: 28-07-2008, 14:01:40 »
Twin Spark sistem je počeo razvijati Mercedes ali kako švaba nije uspio odnosno odustao uzeli to talijani :da: :da: :da:
ALFAMENALNO
Offline reddevill
  • Postova: 9518
« Odgovori #21 u: 29-07-2008, 00:44:06 »
ima mercdes sa dvije svječice po cilindru  :ok:
Offline robi v6
  • Postova: 139
    • Buzet
« Odgovori #22 u: 30-07-2008, 18:13:37 »
Istovremeno kad na prvom baci velika svjećica kad je u stanju kompresije onda na četvrtom baca mala i pali neizgorenu smjesu dok je u ispuhu. Tako je na TS motorima '97 i '98 sigurno a za ostale ne znam
bronz
« Odgovori #23 u: 05-09-2008, 15:29:48 »
jel istina da ts motori ugrađivani u 156 i 147 nevaljaju bas jer su prezahtjevni za održavanje, za razliku od starih ts motora koji su ugradivani u 164 i 155 koji su imali lanac umjesto zupcastog remena?
  • Postova: 15311
« Odgovori #24 u: 05-09-2008, 16:08:56 »
Stari TS iz 75 ice, 164 i djelomicno 155 su bili 8v, pokretani lancem i na njima niej varijator odlazio.Koristili su blok kod starih alfinih twincam motora defakto blok koji je razvijen jos 30ih.
Imali su dvije svjecice iste velicine koje su okidale istovremeno ( skoro istovremeno).
Nakon Fiatovohg prezimanja Alfa sa 155 u se pojavili i 16V TS motri, koji su korsitili blok ( blago modificiran) od Fiat DOHC motora.
Glavu su razvlili alfini inzinjeiri (iako neki vele da je samo doradjena fiat glava), Uveden je remen, svjecice vise ne okidaju istovremeno vec razmaku, dvije razlicite svjecice su, glavna u centru i manja pored koja okida u ispuh kako bi se ostatak smjese zapalio i time smanjile emisije stetnih plinova.
bronz
« Odgovori #25 u: 05-09-2008, 17:14:33 »
i ventili na 16v hocu izgoriti, dali je to zbog teske noge na gasu ili je to zbog motora? koliko trosi ulja u usporedbi sa starim 8v?
sira
« Odgovori #26 u: 05-09-2008, 19:57:51 »
To ima puno motora drugih proizvođača samo ne sa dvije sviječice po cilindru, to se zove !"Wasted spark" sistem, prednost je šta s dva modula paljenja može dobiti paljenje bez rotacijskih dijelova, odnosno modul vrši paljenje u cilindru i kad je klip u gornjoj mrtvoj točki i u donjoj. A kako nema smjese ta jedna iskra je bačena ili potrošena ili na engleskom "wasted"
Inaće 8V TS motor je imao dvije sviječice iz razloga što su ventili bili toliko veliki da se nije mogla staviti svječica u centralni položaj hemisferične kupole te se nije s jednom svječicom moglo dobiti ravnomjerno i brzo izgaranje smjese.
Kod 16V TS motora glavna svječica je već u skoro središnjem položaju te druga koja kasnije pali služi samo za paljenje neizgorenih ostataka smjese
« Zadnja izmjena: 05-09-2008, 20:06:37 od sira »
sira
« Odgovori #27 u: 05-09-2008, 20:08:03 »
To ima puno motora drugih proizvođača samo ne sa dvije sviječice po cilindru, to se zove "Wasted spark" sistem, prednost je šta s dva modula paljenja može dobiti paljenje bez rotacijskih dijelova na četverocilindričnom motorom, jedan modul vrši paljenje u 1 i 4 cilindru i kad je klip u gornjoj mrtvoj točki i u donjoj, drugi u 2 i 3, a kako nema smjese ta jedna iskra je bačena ili potrošena ili na engleskom "wasted"
Zagy
« Odgovori #28 u: 07-09-2008, 21:05:42 »
 :mah:¸
da ne otvaram novu temu a vazano je uz ts motore..
jel normalno da kad se otvori poklopac za nadoljevanje ulja sa frcka ulje van.. navodno nebi smijelo.. eh sad kaj je za napraviti  :?: jel to lose jako za motor ili kaj??
Offline reddevill
  • Postova: 9518
« Odgovori #29 u: 07-09-2008, 22:50:21 »
:mah:¸
to ti je normalno da ti ulje malo štrca van, jer kada radi motor onda ti se ulje diže i podmazuje ventile , a s obzirom da nema nikakve zaštite kod čepa onda ti malo šprca ulje u malim kapljicama, to ti je normalno  :ok:
