Sve ti pise ispod
The Alfa Romeo Stelvio uses a brake-by-wire system called the Intelligent Braking System (IBS), developed in partnership with Continental. This system replaces traditional mechanical and hydraulic braking components with electronic controls, offering several advantages:
Enhanced Response: The brake-by-wire system provides more precise and immediate braking response compared to conventional systems. This is because the system directly interprets the driver’s input and adjusts the braking force accordingly1.
Reduced Weight: By integrating components like the master brake cylinder, brake booster, ABS unit, and ESC unit into a single compact unit, the system reduces the overall weight of the vehicle by nearly 10 pounds1. This is particularly beneficial for a sports-oriented vehicle like the Stelvio.
Improved Feel: The system eliminates the harsh pulses typically felt with conventional ABS systems during heavy braking. Instead, it offers smoother and more predictable pedal travel at all speeds1.
Safety Mechanism: In case of electrical power loss, a valve inside the ABS ECU re-engages the brake pedal with the hydraulic circuit, ensuring that the brakes still function2.Overall, the brake-by-wire system in the Alfa Romeo Stelvio enhances driving performance and safety by providing a more responsive, lighter, and smoother braking experience.
