18-10-2026, 07:18:11
Autor Tema: Fiat Chrysler Automobiles (FCA) / STELLANTIS  (Posjeta: 197127 vremena)
Odg: Fiat Chrysler Automobiles (FCA)
« Odgovori #1140 u: 29-01-2021, 23:36:20 »
Taj Fiat model će biti u stvari produkcijski 120. Takav ne plan. Moguće i da tržišno ime bude Panda. Kao što znamo plan je da Panda napusti A-segment.
Offline Puh
  • Postova: 1366
« Odgovori #1143 u: 18-02-2021, 10:48:18 »
Di bi mi bili kad bi izbacili bar upola modela koliko izbacuju strategija, planova, vizija
« Odgovori #1144 u: 26-02-2021, 22:43:30 »
http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=%2Fnetahtml%2FPTO%2Fsearch-bool.html&r=1&f=G&l=50&co1=AND&d=PTXT&s1=%22US+10,914,362+B2%22&OS=
Modular motor vehicle hybrid transmission convertible between six, eight, and nine speeds
Abstract
A modular hybrid transmission configurable between a 9-speed configuration and an 8-speed configuration includes first, second, third, and fourth planetary gear sets each having first, second, and third elements. Seven torque transmitting devices are each selectively engageable to interconnect one of the first, second, and third elements of one of the planetary gear sets directly with (i) one of the first, second, and third elements of another one of the planetary gear sets, (ii) a housing, or (iii) an input member. The seven torque transmitting devices are selectively engageable to establish nine forward speed ratios and at least one reverse speed ratio. Upon removal of a fourth torque transmitting device, the transmission is arranged in the 8-speed configuration and the remaining six torque transmitting devices are selectively engageable to establish eight forward speed ratios and at least one reverse speed ratio.
Inventors:    Singh; Tejinder (Dexter, MI), Collins; John C (Lake Orion, MI)
Applicant:
Singh; Tejinder
Collins; John C
Assignee:    FCA US LLC (Auburn Hills, MI)
Family ID:    74043436
Appl. No.:    16/455,076
Filed:    June 27, 2019
Document Identifier    Publication Date
US 20200406739 A1    Dec 31, 2020
  • Postova: 593
« Odgovori #1145 u: 02-03-2021, 12:45:17 »
Citat:
Već sljedeće godine stiže novi mali Jeep na platformi PSA grupe
https://autogaraza.hr/novosti/vec-sljedece-godine-stize-novi-mali-jeep-na-platformi-psa-grupe/
Odlično. Sada očekujemo novog Punta, 3008 pod značkom Fiata.
  • Postova: 4704
« Odgovori #1146 u: 02-03-2021, 13:59:34 »
Po mogućnosti sa poznatim pežoovim 1.6 benzincima  :smijeh
  • Postova: 593
« Odgovori #1147 u: 02-03-2021, 17:04:56 »
1.2 THP
  • Postova: 593
« Odgovori #1148 u: 02-03-2021, 19:18:42 »
Nadajmo se da ćemo imati Giuliettu Astra/DS4/308, Alfa Romeo 508 karavan, Alfu 308 RCZ, tj sve ono što Alfa sad nema u ponudi.
« Odgovori #1149 u: 02-03-2021, 20:46:46 »
Da bar da bi.. Bolje to nego nista ko sada.
« Odgovori #1150 u: 04-03-2021, 08:40:57 »
Može li bilo koji Pure Drek izdurat do 100 iljada bez problema?
  • Postova: 593
« Odgovori #1151 u: 04-03-2021, 10:29:45 »
Koliko mi je poznato 1.2 THP su OK motori. Ali kako mene benzinci i njihove varijacije sa hibridima posebno ne zanimaju, tu materiju nisam detaljno pratio.
1.5 HDI i 1.6 HDI motori su pouzdani i bez konstrukcijskih problema.
  • Postova: 593
« Odgovori #1152 u: 04-03-2021, 15:28:54 »
https://www.jutarnji.hr/autoklub/aktualno/sto-se-dogada-s-ferrarijem-u-10-godina-popularnost-marke-se-drasticno-srozala-pokazuje-studija-15055087
Iako više nije pod Fiatom, zanimljiv tekst na temu Ferrarija i preferencija novih kupaca automobila.
« Odgovori #1153 u: 04-03-2021, 20:56:09 »
Pucaju blokovi.
To baš i nije istina. Na većini turbine doslovno potrošna roba.
  • Postova: 593
« Odgovori #1154 u: 04-03-2021, 21:25:17 »
Bilo u prvim serijama 16V 110 KS HDi motorima. Problematicna je bila i uljna pumpa.
Kasnije unapređenjem motora u 8V verziji nema problema sa turbinama, diznama i pumpom.
  • Postova: 2119
« Odgovori #1155 u: 05-03-2021, 06:19:20 »
Ja imam 1.6 16v hdi 110 i nema nikakvih problema samo treba redovito mjenjati ulje i na velikom servisu zamjeniti sito pumpe ulja koje košta 190kn i gas dalje. Izuzetno dobar i zahvalan motor
  • Postova: 593
« Odgovori #1156 u: 05-03-2021, 07:28:38 »
Moj HDI grabi 220k km i drugom velikom servisu, bez problema.
U familiji C4 HDI 150k km bez problema.
Problematicni su bili BlueHDI 2014 do 2016 su imali problen sa pumpom uree, koja je crkavala. Zamjena 500 do 600 eura i vozi dalje. Od sredine 2017 i taj problem je otklonjen.
  • Postova: 3656
« Odgovori #1157 u: 05-03-2021, 07:42:14 »
Prodao 407 2.0 HDI 136 KS sa 340k km, nakon godinu i pol je na 380 i vozi i dalje.
  • Postova: 593
« Odgovori #1159 u: 05-03-2021, 09:03:11 »
2.0 hdi 8v 85kw iz 2002 cca u fiat scudu okrenuo 400k sve oem na motoru, par velikih setova, set kvacila, par podloški na diznama i jedan master rele i to je to, kupljen rabljen i nije šparan.
Neide ko jtd ali znam ih dosta koji imaju veliku km i ne staju.
Ima jedan 306 hdi swap na 2.2 iz jumpera (isti ko 2.0) na cca 180ks ima hrpu km i ne špara se..
Kakvi su novi nisam upucen ali ovi stari su sasvim oke.
« Odgovori #1160 u: 05-03-2021, 09:57:01 »
  • Postova: 593
« Odgovori #1161 u: 05-03-2021, 13:30:18 »
A u Evropi?
« Odgovori #1162 u: 05-03-2021, 13:41:22 »
1370 eura u Italiji za oko 54 tisuće radnika. Bitan je naravno i broj radnika.
  • Postova: 593
« Odgovori #1163 u: 09-03-2021, 10:42:28 »
Solidna rugoba je novi 308
Ugledali se na Cadillac sa ovim nastavcima svjetala. Ali hajde bar nisu uska položena kao kod Citroena i Hyundaia.
Offline Puh
  • Postova: 1366
« Odgovori #1164 u: 09-03-2021, 13:56:34 »
Ružan ili ne, barem ga imaju u ponudi  :hap:
  • Postova: 3656
« Odgovori #1165 u: 09-03-2021, 19:04:10 »
I na ovaj novi Peugeot znak se treba naviknuti
Offline Puh
  • Postova: 1366
« Odgovori #1168 u: 14-03-2021, 13:09:09 »
Kamp kućica?
