25-10-2026, 04:51:07
Autor Tema: Fiat Chrysler Automobiles (FCA) / STELLANTIS  (Posjeta: 199822 vremena)
  • Postova: 6637
« Odgovori #1290 u: 06-01-2022, 21:48:03 »
Za DS se slažem ali zašto pobogu Ram.
Pa ako bi trebao na silu nešto odabrati jer članak kaže da se nešto miče. Po meni je greška tako izdvajati neki model van originalne marke. Uopće ne mislim da je ista bilo bolje ni dodgu ni viperu kad ga se izdvojilo u SRT. Tako ni to sa RAM-om. Dodge ram i pici dalje za iste pare
« Odgovori #1291 u: 21-01-2022, 08:31:16 »
Stellantis e-hybrid, zapravo FCA, je službeno vani. Riječ je P2.5 45V sustavu.
New Hybrid Electric Option
The new models debut an advanced hybrid system featuring a new 4-cylinder 1.5-liter turbo petrol engine, from the Global Small Engine family, which delivers 130 hp and 240 Nm of peak torque, coupled with a new 7-speed 7HDT300 dual-clutch automatic transmission.
The propulsion system includes a built-in 48-volt 15-kW (20-hp) electric motor delivering 55 Nm of torque - equivalent to 135 Nm at gearbox input level - which can propel the wheels even when the internal combustion engine is turned off. The new versions offer up to 15 percent lower consumption and CO2 emissions than the previous petrol models.
Courtesy of the new hybrid technology, the Jeep Renegade and Compass e-Hybrid models offer a new alternative in the two-wheel-drive segment. Customers can keep their driving habits intact and enjoy an authentic hybrid driving experience, with full-electric propulsion available at start-up, when travelling at low speeds, cruising and in parking maneuvers.
Designed for Hybrid Performance
The new 4-cylinder turbocharged engine has been designed to be the best fit for hybrid usage, to optimise thermodynamics, and therefore to save on fuel consumption. It operates on the Miller cycle which improves thermal efficiency and offers a high compression ratio (12.5:1), a new cylinder head with compact combustion chamber, dual variable valve timing and special ‘high-tumble’ intake ducts. Also new is the high-pressure direct injection system, operating at up to 350 bar. This petrol engine delivers an output of 130 hp, while peak torque reaches 240 Nm. A belt starter generator is also installed in the petrol engine, to guarantee fast and silent transitions when restarting.
The braking system of the new Renegade and Compass e-Hybrid includes the Intelligent Brake System which includes an ‘auto-charge’ feature using mixed regenerative braking to maximise the recovery of kinetic energy and improves efficiency.
An evolution of the driving experience
Courtesy of the new propulsion system, the hybrid models deliver a versatile and relaxing driving experience, with various features allowing the vehicle to move in electric mode (“EV features”). These include:
  • Silent Start: starts the vehicle with no need to turn on the petrol engine, by using an “EV” pure-electric, silent driving mode
  • Energy Recovery: recovers energy that would otherwise be wasted when the vehicle decelerates (e-Coasting) and during braking (Regenerative Braking);
  • Boost & Load Point Shift: ‘e-Boosting’ allows an increase in torque to the wheels thanks to the electric motor that supports the petrol engine; moreover, by taking advantage of the (drive or braking) torque delivered by the electric motor, it is possible to optimise the operating point of the petrol engine;
  • Electric Drive: the vehicle can travel in silence and with zero emissions using only the electric motor, while the petrol engine is turned off.
The new Jeep Renegade and Compass e-Hybrid can run in various driving scenarios using only the electric motor (and with the petrol engine turned off). This is made possible courtesy of an array of electric operating modes known as “EV capabilities”, which include:
  • e-Launch: starts the vehicle using only the electric motor, when starting up or restarting at traffic lights
  • e-Creeping: the electric motor provides the start-up normally seen in automatic vehicles, at a speed that can vary from 0 km/h to the equivalent of the petrol engine idling in first gear, or in reverse (for example when maneuvering)
  • e-Queueing: the vehicle can keep going in a traffic jam, following a ‘stop & go’ pattern in full-electric mode
  • e-Parking: simplifies parking maneuvers, which can be carried out using electric propulsion only, to ensure a practical and quiet experience.
EV capabilities are available depending on battery charge status and the power output required.
  • Postova: 593
« Odgovori #1293 u: 25-01-2022, 08:17:40 »
Odlična vijest. To bi trebalo onda da znači da će Stelasntis biti na FCA dizel motorima.
  • Postova: 4705
« Odgovori #1294 u: 25-01-2022, 10:15:43 »
Čudno mi je jedino da Fiat, koji je nekad dobro prodavao male i jeftine, solidne aute, da nije oživio neku "staru" marku, jeftinih auta kao Dača.
A sad imamo Daču s čak 2 modela u prvih 5 najprodavanijih auta
  • Postova: 2120
« Odgovori #1295 u: 25-01-2022, 16:20:15 »
Sažo oživiti nije dovoljno, treba to popratiti konkurentnim cijenama a za to trebaš jeftinu proizvodnju. Fiat to nema nigdje, čak ni u Turskoj
  • Postova: 593
« Odgovori #1296 u: 25-01-2022, 17:43:22 »
I ružno je kad se kaže da je auto proizveden u Kini, Turskoj, Indiji. Opet su Rumunija, Srbija, Poljska evropsje zemlje.
  • Postova: 4705
« Odgovori #1298 u: 25-01-2022, 20:04:59 »
Trebali su se Dačom udružiti a ne francuzima  :smijeh
  • Postova: 2120
« Odgovori #1299 u: 25-01-2022, 22:30:11 »
Dača kao nije francuz :)
« Odgovori #1300 u: 26-01-2022, 08:22:23 »
Čika Dača iz Srbije bre.
Offline Zagi
  • Postova: 161
    • Rogoza
« Odgovori #1301 u: 26-01-2022, 09:28:07 »
A jbg Dacia najprodavanija marka u Francuskoj. Isto kao i Vw u Italiji.
Offline Alfa bez Omege
  • Postova: 224
  • Fali mi Alfa
« Odgovori #1303 u: 26-01-2022, 15:19:19 »
Svi znamo da su ti rezultati takva neviđena glupost jer se ne uzima u obzir težina kvarova, tj. možda se i uzima ali ne utječe na krajnji poredak.
  • Postova: 4705
« Odgovori #1304 u: 26-01-2022, 17:18:06 »
Duster i Sandero u top 5 u RH 2021.
Niš, FCA asimilirati i Reno i nitko im beće biti ravan
Offline Zagi
  • Postova: 161
    • Rogoza
« Odgovori #1305 u: 26-01-2022, 18:03:58 »
Znaci ipak sam dobro izabrao. Hyundai u vrhu po pouzdanosti
« Odgovori #1306 u: 26-01-2022, 19:36:09 »
Ja ne znam  :tooth
Sljedeći korisnici su zahvalili na ovom postu: Zagi
  • Postova: 224
  • Fali mi Alfa
« Odgovori #1307 u: 27-01-2022, 12:18:08 »
Zna moj frend koji je morao mijenjati motor na Aurisu :)
Offline Zagi
  • Postova: 161
    • Rogoza
« Odgovori #1308 u: 27-01-2022, 13:38:29 »
I taj auto je mjerilo pouzdanosti. To je 1 od koliko ono miliona prodanih Toyota.
Offline Zagi
  • Postova: 161
    • Rogoza
« Odgovori #1309 u: 27-01-2022, 13:53:40 »
2006 god Darko Jakopcic iz Kutine vlasnik prijevoznicke firme Jatras uzeo je novu Bmw 5 530 dizel. Sa njim je napravio 980000 km prije neg ga je rijesio. Sad vec 3 god unazad vozi Bmw seriju 6 Gran Coupe dizel. Brat mu isto vozi samo Bmw.
  • Postova: 7648
« Odgovori #1310 u: 27-01-2022, 14:40:31 »
Kako uvijek imaju komentari na nevaljanost Alfi ljudi koji ih ne voze :gay:
Offline Zagi
  • Postova: 161
    • Rogoza
« Odgovori #1311 u: 27-01-2022, 15:17:05 »
Ja sam ju imao i prodao.
Offline Surovi
  • Postova: 884
« Odgovori #1312 u: 27-01-2022, 20:45:12 »
A ono smeće od Fijata...meni se na onom govnetu od Crome pokvario mjenjač.
Kaj je to auto?
Kakav je to Fijat kad se pokvario samo mjenjač. Sramota.
Lijepo su mi rekli da bum zapamtil kad sam kupil Fijata.
Bome budem. Jedan kvar u devet godina. Sramota.
« Zadnja izmjena: 27-01-2022, 20:46:00 od Surovi »
  • Postova: 43214
« Odgovori #1314 u: 28-01-2022, 05:38:42 »
  • Postova: 4705
« Odgovori #1315 u: 28-01-2022, 09:38:27 »
Podignuta Corsa  :smijeh
Offline Zagi
  • Postova: 161
    • Rogoza
« Odgovori #1316 u: 28-01-2022, 09:39:59 »
2008
  • Postova: 6253
« Odgovori #1317 u: 28-01-2022, 09:41:26 »
Offline Zagi
  • Postova: 161
    • Rogoza
« Odgovori #1318 u: 28-01-2022, 10:07:36 »
Znaci novi model ce bit Fiat Mokka 2008.
  • Postova: 6253
« Odgovori #1319 u: 28-01-2022, 10:29:31 »
ne
