20-10-2026, 12:20:06
Autor Tema: Alfa 159  (Posjeta: 465144 vremena)
Offline Guro
  • Postova: 460
  • 159 1.9JTDm & 156 2.4JTD
    • Podgorica
Odg: Alfa 159
« Odgovori #540 u: 31-05-2011, 18:23:55 »
moze li mi ko reci kako funcionisu ovi senzori za brisace na 159???
ja sam imao ranije 406 sa istim senzorima, prvi plozaj je bio samo za njih...i tacno se znalo kako rade...slaba kisa, rade na prekid, malo jaca, opet sa kracim prekidima, jaca kisa povecava brzinu...ali se tacno vidi pravilo....naleti auto iz suprotnog pravca i baci vodu (pa i kad nbema kise) brisace se odmah pale...i ciste...dok kod 159 rade kao blesavi...ne pada kisa oni u najvecoj brzini...stojim na semaforima ne vidim nista od kise, onda odjednom prorade, pa ubrzaju bez ikakvog razloga na najvecu brzinu...pa uspore...ma da ne duzim, rade bukvalno bez nekog logicnog pravila!!! e sad to je pod uslovom da ja znam kako se koriste, a to je isto prvi polozaj rucice...druga dva su da rade konstantno...i nije mi jasno cemu sluzi ona poluga sa intervalom izmedju ciscenja???  :000:
Offline Guro
  • Postova: 460
    • Podgorica
Odg: Alfa 159
« Odgovori #541 u: 31-05-2011, 18:31:11 »
evo da odgovorim samome sebi :)
The rain sensor A-fig. 55, located behind the driving mirror, is an electronic device combined with the windscreen wiper which has the purpose of automatically
adjusting the number of wipes to intensity of the rain. All the other functions controlled by the right-hand stalk remain unchanged.
The rain sensor is activated automatically moving the right-hand stalk to position 1-fig. 54 and it has a range of adjustment that gradually varies between
wiper stationary (no wiping) when the windscreen is dry, to wiper at second speed (continuous, medium wiping) with heavy rain.
Turning the knurled ring A-fig. 54 it is possible to increase the sensitivity ofthe rain sensor, obtaining a quicker change from stationary (no wiping)
when the windscreen is dry, to first continuous speed (continuous, slow). A further stroke will confirm operation. Operating the windscreen washer with
the rain sensor activated (stalk at position 1-fig. 54) the normal washing cycle is performed at the end of which the rain sensor resumes its normal automatic
function. Removing the electronic key from the ignition device, the rain sensor is deactivated and the next time the engine is started it will not be reactivated even if
the stalk has remained in position 1- fig. 54. In this case to activate the rain sensor, simply move the stalk to 0 or 2 and then back to 1.
When the rain sensor is reactivated in this way, the wiper performs one stroke, even if the windscreen is dry, to indicate that reactivation has occurred.
Offline Guro
  • Postova: 460
    • Podgorica
Odg: Alfa 159
« Odgovori #542 u: 31-05-2011, 18:42:44 »
evo da odgovorim samome sebi :) ali opet ovo ne objasnjava njihov totalno nebulozni rad...
Offline patrik_s
  • Postova: 37
  • Giulietta
    • Varaždin
Odg: Alfa 159
« Odgovori #543 u: 02-06-2011, 07:31:38 »
meni se čini da se vrlo rjetko desi da brisači "luduju"
uglavnom, zadovoljan sam kako to radi,
istina da treba malo iskustva da se prepozna koja je osjetljivost primjerena
ali je to poslije vrlo zadovoljavajuće
isto je i stina da ponekad zna biti da polude, ali tada ih resetiram i ponovno uključim i dalje ide očekivano
moje je iskustvo da po danu za kišu srednjeg intenziteta odgovara druga crtica
za noć treća, s tim da ako ima potrebe automat sam intervalno se pojača ( novi nalet vode u prolasku drugog automobila i slično )
sve u svemu, nisu koma i nisam nikad došel u napast da ih izbacim
Floki
Odg: Alfa 159
« Odgovori #544 u: 02-06-2011, 08:45:13 »
Ček, jel se da podesiti "osjetljivost" tih brisača? Meni je to jedini veliki minus na 159-ki i u par navrata su me doslovno izludili(na autocesti sa kišom slabijeg do srednjeg intenziteta i nekad po gradu, kad uopće ne žele brisati ili brišu na suho).
Pogotov me živcira jer su na 156-ici intervali brisanja savršeni i uvije postoji savršena brzina brisanja?
I može li se taj senzor kiše isključiti?
Offline Guro
  • Postova: 460
    • Podgorica
Odg: Alfa 159
« Odgovori #545 u: 02-06-2011, 09:08:28 »
pa kod ovih koje imaju senzor...ona polugica na rucici brisaca koja sluzi za podesavanja pauze kod brisanja(prvi polozaj, gdje postoje pauze) sluzi za odesavnje osjetljivosti senzora...
ja jos nisam uspio da do detalja provalim kako funkcionise, jer imam auto nekih mjesec dana...a kisa nikako da pane duze od 2-3 minuta
Offline patrik_s
  • Postova: 37
  • Giulietta
    • Varaždin
Odg: Alfa 159
« Odgovori #546 u: 03-06-2011, 07:53:56 »
na polugi brisača imaš indekse osjetljivosti
označeno crticama
- najmanja osjetljivost ( najmanja crtica )
---- najveća osjetljivost
znači, kad staviš brisače u automatski rad
možeš birati osjetljivost prema intenzitetu kiše
ako ima i povremeno promjene tog intenziteta obzirom da se vrijeme mijenja, senzor prilagođava rad brisača
ponekad ne idealno
kao što rekoh, meni se pokazalo -- ( druga oznaka na indeksu ) kao dosta adekvatna za većinu situacija
premda kad ono samo koja kap padne, dovoljno je jedna a senzor bude sam povećal ritam ako trenutačno zatreba
« Zadnja izmjena: 03-06-2011, 07:56:23 od patrik_s »
Offline aaarrr
  • Postova: 1254
  • 159 V6 Q4, 155 TS, Giulietta Q2, MiTo Imola
Odg: Alfa 159
« Odgovori #547 u: 03-06-2011, 15:04:48 »
Bez obzira na te crtice za biranje osjetljivosti senzora, mene toliko živcira rad tih "automatskih brisača", da ako malo pada kiša brišem klikom u "nestabilni" položaj, a ako pada jako, stavim ih na kontinuirano brisanje.
Jako su loše riješili rad senzora.  :mad:
Zna mi se dogoditi da stojim na semaforu, padnu dvije kapi kiše, a brisači se razlete da mislim da će odletjeti!  :o000: :o000: :o000:
A opet - pada kao luda, a oni - cmiiic - cmaaac
Offline Guro
  • Postova: 460
    • Podgorica
Odg: Alfa 159
« Odgovori #548 u: 03-06-2011, 16:24:42 »
upravo to i ja pricam.....
ali opet nemam puno iskustva sa njima...jer je samo par puta padala kisa...i to po par minuta :)
Offline aaarrr
  • Postova: 1254
Odg: Alfa 159
« Odgovori #549 u: 03-06-2011, 16:45:07 »
Bio bi najsretniji kad bi se mogao isključiti taj senzor, pa ako već ne mogu brisati kako treba, neka brišu klasično, s intervalima.
I onaj senzor zagrijavanja ispod vjetrobrana na instrumentnoj mi ide na živce jer mi pali klimu kad on poželi iako klima nije na AUTO modu ( znam da jedno s drugim nema veze ).
Ne znam zašto se i to ne može isključiti...
Kad je sunčan dan volim otvoriti šiber i oba prednja prozora i laganini vožnja... A ova pali klimu sama jer je vani sunčano i toplo...
Offline dove
  • Postova: 654
  • Alfa 75 TS
Odg: Alfa 159
« Odgovori #550 u: 08-06-2011, 12:05:59 »
Uploaded with ImageShack.us
Offline Sesta166
  • Postova: 4177
    • Zenica
Odg: Alfa 159
« Odgovori #551 u: 08-06-2011, 12:32:37 »
ddooooooobbbbrrrraaaaaaaaaaaaaaaaa
Offline Nowa
  • Postova: 838
    • Celinac(BiH)
Odg: Alfa 159
« Odgovori #552 u: 08-06-2011, 12:36:23 »
malo reci da je dobra  :love3: :love3: :love3:
  • Postova: 21826
Odg: Alfa 159
« Odgovori #553 u: 08-06-2011, 13:23:17 »
 :love: :love: :love: :love: :love: :love: :love: :love: :love: :love: i jos toliko  :ling: :ling: :)
Odg: Alfa 159
« Odgovori #554 u: 08-06-2011, 14:16:07 »
nije to alfin stil,to je više za neku hondu ili tako nešta
Offline aaarrr
  • Postova: 1254
Odg: Alfa 159
« Odgovori #555 u: 08-06-2011, 14:35:51 »
Potpisujem!
Offline alfa romeo156sl
  • Postova: 1111
  • Alfa Romeo Brera&156 1.8 TWIN SPARK
    • Slatina
Odg: Alfa 159
« Odgovori #556 u: 08-06-2011, 14:48:05 »
Samo Alfa i ništa drugo!!!!Slavonija je moj dom!!
Offline Guro
  • Postova: 460
    • Podgorica
Odg: Alfa 159
« Odgovori #557 u: 08-06-2011, 15:55:59 »
 A ja nisam komentarisao nista, misleci da sam jedini kome se ovi plasticni dodaci ne svidjaju
Offline Nowa
  • Postova: 838
    • Celinac(BiH)
Odg: Alfa 159
« Odgovori #558 u: 08-06-2011, 16:47:16 »
ja bi to sve u crvenu prefarbao ovako mi lici jos sa onim velikim R na nekoga volva R serije felne su mi  :ling: :ling:
  • Postova: 1111
    • Slatina
Odg: Alfa 159
« Odgovori #559 u: 08-06-2011, 16:53:58 »
Bas to ,sve u boji auta i zvijer!!!
crobiker1
Odg: Alfa 159
« Odgovori #560 u: 08-08-2011, 21:00:16 »
pitanje:
Neki dan sam skuzil da ima onu opciju " follow me 30 sec."
Eh sad me muci kako to ukljuciti?
33QO
Odg: Alfa 159
« Odgovori #561 u: 08-08-2011, 21:46:29 »
Ablenduješ sa ugašenim motorom. Svaki potez ručice dodaješ 30 sec, do 120 (max).
Zagy
Odg: Alfa 159
« Odgovori #562 u: 08-08-2011, 21:47:27 »
koja je fora s tim?
crobiker1
Odg: Alfa 159
« Odgovori #563 u: 08-08-2011, 21:55:10 »
ali onda bi to trebalo svijetiti npr 30sec ,a kod mene se to odmah ugasi...
koja je fora s tim?
to je fora kao da ti osvijetli put na 30sec  dok npr ne dodjes do kuce...
33QO
Odg: Alfa 159
« Odgovori #564 u: 08-08-2011, 21:56:19 »
Nisam to nikad koristio, znam samo da me izneredilo kad mi se upalilo prvi put  :hehe:
Zagy
Odg: Alfa 159
« Odgovori #565 u: 08-08-2011, 22:15:25 »
a ha..... nisam povezal to je ono "follow me home"  :ok:
Offline rpichler
  • Postova: 2232
Odg: Alfa 159
« Odgovori #566 u: 10-08-2011, 08:51:47 »
ponekad ne idealno
Moja protestira kad se po kiši vozim u koloni (50-60 Km/h, gas-kočnica) i brisači gotovo uopće ne brišu  - kao da prigovara što se vozim u koloni, ali zato kad dam gasa i krenem pretjecati i držim tempo oko ili iznad 100 Km/h, odmah upali brisače... vratim se nazad na 50 Km/h - opet protestna nota...
Ona mene voli...  :love: :love: :love:
gala
Odg: Alfa 159
« Odgovori #567 u: 19-08-2011, 22:53:39 »
pozdrav ekipa. kupio bi 159... pa me zanima jel ima nekih učestalih problema ili kvarova?! uglavnom mislim uzet 159ti, ali se dvoumim između 1.9 i 2.4... preporuke?
33QO
Odg: Alfa 159
« Odgovori #568 u: 19-08-2011, 22:57:49 »
Ma daj, to je opel, to se ne kvari!  :hehe: :hehe:
« Zadnja izmjena: 19-08-2011, 22:59:22 od Q. ORO »
Offline Roko
  • Postova: 3189
  • 159 Ti
Odg: Alfa 159
« Odgovori #569 u: 20-08-2011, 02:28:11 »
Nema .Svaka ima svojih nekih musica ,nista strasno .
Kad je bal nek je maskenbal  :hap: . Uzmi sto ti srce zeli , jedino izbjegavaj 200ks verziju ,iako ni to nije pravilo  :mah: .
« Zadnja izmjena: 20-08-2011, 02:30:49 od MafiaMan »
