11-06-2026, 21:09:02
Autor Tema: Novi motori iz FIAT-a !  (Posjeta: 12778 vremena)
Offline fbajlo
  • Postova: 1040
Odg: Novi motori iz FIAT-a !
« Odgovori #30 u: 05-03-2009, 11:38:52 »
Fiat Introduces Multiair Electro-Hydraulic Valve-Timing System
4 March 2009
Fiat Group and Fiat Powertrain Technology introduced their new air management technology Multiair at the Geneva Motor Show. Multiair is an electro-hydraulic valve-timing system that provides dynamic and direct control of air and combustion, cylinder by cylinder and stroke by stroke.
Fiat expects that Multiair, with direct control of the air through the intake engine valves without using the throttle, can help reduce fuel consumption by up to 10% for turbocharged or naturally aspirated gasoline engines. Pollutant emissions are likewise reduced through combustion control. Applied to a turbocharged, downsized engine, MultiAir can contribute to up to a 25% reduction in fuel consumption over conventional naturally aspirated engines with the same performance, according to Fiat.
The operating principle of the system, applied to intake valves, is the following: a piston, moved by a mechanical intake cam, is connected to the intake valve through a hydraulic chamber, which is controlled by a normally open on/off solenoid valve.
When the solenoid valve is closed, the oil in the hydraulic chamber behaves like a solid body and transmits to the intake valves the lift schedule imposed by the mechanical intake cam. When the solenoid valve is open, the hydraulic chamber and the intake valves are de-coupled; the intake valves do not follow the intake cam anymore and close under the valve spring action. The final part of the valve closing stroke is controlled by a dedicated hydraulic brake, to ensure a soft and regular landing phase in any engine operating conditions.
Through solenoid valve opening and closing time control, a wide range of optimum intake valve opening schedules can be easily obtained.
For maximum power, the solenoid valve is always closed and full valve opening is achieved following completely the mechanical cam, which was specifically designed to maximize power at high engine speed (long opening time).
For low-rpm torque, the solenoid valve is opened near the end of the cam profile, leading to early intake valve closing. This eliminates unwanted backflow into the manifold and maximizes the air mass trapped in the cylinders.
In engine part load, the solenoid valve is opened earlier causing partial valve openings to control the trapped air mass as a function of the required torque. Alternatively the intake valves can be partially opened by closing the solenoid valve once the mechanical cam action has already started. In this case the air stream into the cylinder is faster and results in higher in-cylinder turbulence.
The last two actuation modes can be combined in the same intake stroke, generating a so-called “Multilift” mode, that enhances turbulence and combustion rate at very low loads.
Potential benefits for gasoline engines include:
Maximum power is increased by up to 10% thanks to the adoption of a power-oriented mechanical cam profile;
Low-rpm torque is improved by up to 15% through early intake valve closing strategies that maximize the air mass trapped in the cylinders;
Elimination of pumping losses brings a 10% reduction of fuel consumption and CO2 emissions, both in naturally aspirated and turbocharged engines with the same displacement;
Multiair turbocharged and downsized engines can achieve up to 25% fuel economy improvement over conventional naturally aspirated engines with the same level of performance;
Optimum valve control strategies during engine warm-up and internal Exhaust Gas Recirculation, realized by reopening the intake valves during the exhaust stroke, result in emissions reduction ranging from 40% for HC / CO to 60% for NOx; and
Constant upstream air pressure, atmospheric for naturally aspirated and higher for turbocharged engines, together with the extremely fast air mass control, cylinder-by-cylinder and stroke-by-stroke, result in a superior dynamic engine response.
The first world-wide application of the Multiair technology will be the Fire 1400 cc 16V naturally aspirated and turbocharged engines. The second application will be a new small gasoline engine (SGE - 900 cc twin-cylinder) where the cylinder head design has been specifically optimized for the Multiair actuator integration.
Here again, there will be both a naturally aspirated and a turbocharged version. A specific turbocharged engine version will be bi-fuel (gasoline-CNG). Thanks to radical downsizing, the Turbocharged Small Gasoline Engine achieves diesel-like CO2 emission levels, which are further reduced in its natural gas version with CO2 emissions lower than 80 g/km in many vehicle applications.
Fiat says that Multiair will lead to further innovations such as:
Integration of the Multiair Direct air mass control with Direct gasoline Injection to further improve transient response and fuel economy.
Introduction of more advanced multiple valve opening strategies to further reduce emissions.
Innovative engine-Turbocharger matching to control trapped air mass through combination of optimum boost pressure and valve opening strategies.
Fiat began working on electro-hydraulic actuation in the mid-1990s, leveraging on the know-how gained during the Common Rail development. The goal was to reach the desired flexibility of valve opening schedule air mass control on a cylinder-by-cylinder and stroke-by-stroke basis. The electro-hydraulic variable valve actuation technology developed by Fiat was selected for its relative simplicity, low power requirements, intrinsic fail safe nature and low cost potential.
Offline mislav
  • Postova: 525
  • 159 1.9 JTDM SW
« Odgovori #31 u: 05-03-2009, 13:21:18 »
gledao sam jedan test 8C. kaže vozač "stisnem gas u 2., a ono ništa"
je, na testovima nije baš dobro prošla
  • Postova: 6230
« Odgovori #32 u: 05-03-2009, 13:35:48 »
Citat:
Fiat says its fuel-saving MultiAir technology is not for sale
Luca Ciferri
Automotive News Europe
March 4, 2009 17:01 CET
ENLARGE
Alfa Romeo will offer MultiAir on the MiTo.
GENEVA - Fiat considers its MultiAir variable valve timing technology a breakthrough application with the same potential impact of its 1997 common-rail diesel injection technology - but the Italian group will retain intellectual property right to the system.
Fiat developed and patented common-rail engine technology but sold it to Robert Bosch in the early 1990's in the middle of a financial crisis.
"MultiAir is available to other automakers as (complete) engines and as technology under license, but intellectual property for the system will remain within Fiat Powertrain Technology," said Alfredo Altavilla, CEO of Fiat Powertrain Technologies (FTP).
Altavilla said MultiAir technology is part of the technical cooperation talks Fiat is current having with BMW Group and Chrysler.
Rinaldo Rinolfi, FPT's chief technical officer, said MultiAir increases power 10 percent while decreasing fuel consumption and CO2 emissions by 10 percent.
"For MultiAir, we preferred an electro-hydraulic valve actuation technology because it is cheaper than electromagnetic and electromechanical systems. It can also be applied to diesel engines," Rinolfi said.
FPT hopes MultiAir technology will reduce nitrogen oxide emissions by up to 60 percent so that engines using the technology will not need a liquid additive to meet new Euro 6 emissions standards.
Alfa Romeo will be the first brand to offer MultiAir on a 1.4-liter gasoline engine in its MiTo small car, starting in April.
FPT and Alfa declined to disclose the added manufacturing cost or customer price premium for a vehicle equipped with MultiAir.
MultiAir technology will progressively spread out on all Fiat engines. The next application will come in 2009 on a new 900c two-cylinder engine, which will equip mini- and small-segment cars.
FPT last year built 2.9 million engines, generating 7 billion euros in revenue, of which more than 26 percent from outside clients.
  • Postova: 8255
« Odgovori #33 u: 05-03-2009, 18:03:02 »
Korak bliže potpunom uklanjanju bregastih osovina i elektromagnetnom otvaranju ventila!  :ok:
  • Postova: 6230
« Odgovori #34 u: 05-03-2009, 18:31:56 »
multiair je elektrohidraulično otvaranje ventila...i napravljeno je kao suparnik elektromagnenom otvaranju ventila.
  • Postova: 8255
« Odgovori #35 u: 05-03-2009, 18:37:02 »
Ma skužio sam da je elektrohidraulično, ali nisam znao da je suparnik elektromagnetskom...
Elektromagnetsko je još debelo u razvoju i tko zna kada će u proizvodnju...
Bitno je da se tehnologija razvija!  :ok:
Offline Drago
  • Postova: 1249
« Odgovori #36 u: 05-03-2009, 21:55:30 »
Jeremy Clarkson:
With the exception of the simply appalling Arna, I’ve loved all Alfas. In fact I’ve argued time and again that nobody can be a petrolhead until they’ve owned one. It’s a rite of passage. Think of it as the great sex that leaves you with an embarrassing itch.
Offline Drago
  • Postova: 1249
« Odgovori #37 u: 09-03-2009, 20:03:38 »
Jeremy Clarkson:
Serfo
« Odgovori #38 u: 10-03-2009, 00:30:54 »
To bi trebalo bit ovo
Offline Irvine159
  • Postova: 2285
  • Možda Giulia
    • bučino ulje iz istre
« Odgovori #39 u: 10-03-2009, 12:28:09 »
Jasko interesantno rješenje,valjda če bit pouzdanije od variatora!
  • Postova: 15308
« Odgovori #40 u: 10-03-2009, 12:29:45 »
Možda će iskopati varijaotre sa starih IE i 8V TS koji su valjali.
Serfo
« Odgovori #41 u: 10-03-2009, 14:57:19 »
Razvijaju i testiraju jako dugo vremena. Motor je trebao bit predstavljen s FIAT-om 500 pa ništa. I mene jako zanima što će s tim bit. S sistemom razvoda kasne godinama za ostalima. Zanima me kako radi ovaj novi motor od 1.8 turbo. On ima dvostruki varijator faze, ali ne znam dali regulira i visinu otvaranja ventila :?:
Offline Irvine159
  • Postova: 2285
  • Možda Giulia
« Odgovori #42 u: 10-03-2009, 16:46:56 »
ne varira visinu,samo vrijeme!
ova gore tehnologije (multiair) regulira visinu!
Offline boris
  • Postova: 1607
  • 147 Q
« Odgovori #43 u: 11-03-2009, 10:58:41 »
Nema, on nije mulitiar samo dvostruki varijator.
Prvi multiar će biti 1.4 T sa 135 i 165 konja
Serfo
« Odgovori #44 u: 11-03-2009, 11:01:34 »
Znam da multiair regulira visinu. Ja sam i stavio tu sliku.
Nisam znao što je motirano na ovaj 1.8 turbo :ok:
Offline Viktor
  • Trade Count: (+21)
  • Postova: 9231
« Odgovori #45 u: 12-03-2009, 08:18:23 »
Dobra stvar, ali jedna komplikacija više u motoru.
Npr. kod JTD motora ovo ne treba, on usisa uvijek maksimalnu količinu zraka i sa količinom i vremenom ubrizgavanja goriva se sve regulira.
Offline fbajlo
  • Postova: 1040
« Odgovori #46 u: 16-03-2009, 10:08:43 »
Evo malo opširniji tekst o Multiair motorima, na žalost samo na talijanskom... Ako nađem negdje englesku verziju stavim i nju...
La tecnologia Multiair Fiat
1-   Introduzione
Nell’ultimo decennio, lo sviluppo della tecnologia Common Rail per i motori Diesel ha rappresentato un’importantissima evoluzione tecnologica nel settore delle automobili e dei veicoli commerciali. Per essere competitivi anche nel segmento dei motori a benzina, il Gruppo Fiat ha deciso di adottare un approccio analogo, basato sull’identificazione di innovazioni tecnologiche strategiche. L’obiettivo è di offrire al cliente benefici sostanziali in termini di consumo di carburante e fun-to-drive mantenendo, nel contempo, le caratteristiche di confort intrinseche di questo motore, derivanti da un processo di combustione fluido e dalla leggerezza della struttura e dei componenti.
Il parametro fondamentale per il controllo della combustione di un motore Diesel, e quindi delle sue prestazioni, emissioni e consumo di gasolio, è rappresentato dalla quantità e caratteristiche del combustibile iniettato nei cilindri. Ecco perché il sistema di iniezione a controllo elettronico Common Rail ha rappresentato un vero e proprio nuovo paradigma nelle tecnologie dei motori Diesel ad iniezione diretta.
Il parametro essenziale per controllare la combustione di un motore a benzina, e di conseguenza le sue prestazioni, emissioni e consumo di carburante, è invece rappresentato dalla quantità e dalle caratteristiche della carica d’aria nei cilindri. Nei motori tradizionali, la massa d’aria immessa nei cilindri è controllata mantenendo l’andamento dell’apertura delle valvole di aspirazione costante e modificando la pressione a monte, mediante una farfalla. Uno degli svantaggi di questo semplice controllo tradizionale è lo spreco di circa il 10% dell’energia utile, per via delle perdite legate al pompaggio della carica d’aria fresca da una pressione di alimentazione più bassa rispetto alla pressione atmosferica allo scarico.
Il salto tecnologico realizzato nel controllo della massa d’aria, e quindi nelle tecnologie dei motori a benzina, si basa sul controllo della carica direttamente all’ingresso nei cilindri, mediante un sistema avanzato di attuazione elettronica e di controllo delle valvole di aspirazione, con il mantenimento di una pressione costante a monte dei condotti di aspirazione.
2-   Un po' di storia...
La ricerca che ha condotto a questa grande innovazione risale agli anni Ottanta, quando le tecnologie di controllo elettronico del motore erano ormai giunte a maturità.
All’inizio, gli sforzi di ricerca mondiali erano focalizzati sul concetto di attuazione elettromagnetica, laddove l’apertura e la chiusura della valvola è ottenuta energizzando alternativamente il magnete superiore e inferiore con l’armatura connessa alla valvola. Questo principio di attuazione aveva il vantaggio intrinseco della massima flessibilità e di una risposta dinamica nel controllo della valvola. Tuttavia, dopo un decennio di importanti sforzi di sviluppo, non fu possibile superare i principali svantaggi di questo tipo di tecnologia e cioè il suo non essere intrinsecamente fail-safe, nonché il suo elevato assorbimento di energia.
A quel punto la maggior parte dei costruttori automobilistici ripiegò sullo sviluppo di concetti elettromeccanici più semplici e robusti, basati sulla variazione dell’alzata delle valvole con meccanismi dedicati, solitamente combinati a variatori di fase, per consentire il controllo sia dell’alzata valvola che della fase. La principale limitazione di questi sistemi è da ricondurre al basso grado di flessibilità dei regimi di apertura delle valvole e in una risposta dinamica marcatamente inferiore, per cui, ad esempio, tutti i cilindri di un motore (o di una bancata nel caso di motori a “V”) vengono attuati simultaneamente, escludendo quindi ogni azione selettiva dei cilindri. Nel corso dell’ultimo decennio sono stati immessi in produzione molti sistemi di controllo delle valvole di questa tipologia.
A metà degli anni Novanta, la ricerca del Gruppo Fiat si indirizzò verso l’attuazione elettro-idraulica, sfruttando il know-how acquisito durante le fasi di sviluppo del Common Rail. L’obiettivo era quello di raggiungere la flessibilità auspicata nei regimi di apertura delle valvole e nel controllo della massa d’aria, cilindro per cilindro e colpo a colpo.
La tecnologia elettro-idraulica di attuazione variabile sviluppata da Fiat è stata scelta per la sua relativa semplicità, i bassi requisiti di potenza, la sua natura intrinsecamente “fail-safe” ed il basso costo potenziale.
3-   Il funzionamento
Il principio operativo del sistema, applicato alle valvole di aspirazione, è il seguente: un pistone, azionato da una camma meccanica, viene collegato alla valvola di aspirazione mediante una camera idraulica, controllata da una valvola solenoide, del tipo ON/OFF, normalmente aperta.
Quando la valvola solenoide è chiusa, l’olio nella camera idraulica si comporta come un corpo solido e trasmette alle valvole di aspirazione la legge di alzata imposta dalla camma di aspirazione meccanica. Quando la valvola solenoide è aperta, la camera idraulica e le valvole di aspirazione sono disgiunte e non seguono più la camma di aspirazione, chiudendosi per effetto della forza della molla. La parte finale della corsa di chiusura della valvola è controllata mediante un freno idraulico dedicato, in grado di garantire una fase di atterraggio morbida e regolare, in qualsiasi condizione d’esercizio.
Controllando gli istanti di apertura e chiusura della valvola solenoide, è possibile ottenere agevolmente diversi andamenti ottimali di apertura delle valvole di aspirazione.
Per la potenza massima, la valvola solenoide è sempre chiusa e la piena apertura delle valvole è realizzata seguendo completamente l’andamento della camma meccanica, che è stata ottimizzata specificamente per la potenza ad alti regimi (tempi di chiusura lunghi).
4-   A basso carico...
A basso numero di giri e pieno carico, la valvola solenoide si apre vicino all’estremità del profilo della camma realizzando una chiusura anticipata della valvola di aspirazione. Ciò elimina un riflusso indesiderato nel collettore e massimizza la massa d’aria intrappolata nei cilindri.
Nelle condizioni di carico parziale del motore, la valvola solenoide si apre anticipatamente (prima del completamento del profilo della camma meccanica) realizzando una parziale apertura delle valvole per controllare la massa d’aria introdotta a seconda della coppia richiesta. In alternativa, è possibile ottenere un’apertura parziale delle valvole chiudendo la valvola solenoide una volta già partita la camma meccanica. In questo caso, il flusso d’aria in ingresso nei cilindri ha una velocità superiore e genera un livello di turbolenza particolarmente elevato all’interno dei cilindri.
È possibile abbinare queste due modalità di attuazione per uno stesso evento di aspirazione, con la modalità cosiddetta “Multilift”, che aumenta la turbolenza e la velocità di combustione a carichi e regimi molto bassi.
5-   I vantaggi...
Ecco in sintesi i potenziali vantaggi della Tecnologia Multiair per i motori a benzina:
- Aumento della potenza massima del 10% grazie all’adozione di un profilo di camma meccanica indirizzato alla potenza
- Miglioramento della coppia a basso regime del 15% mediante strategie di chiusura anticipata della valvola di aspirazione, che massimizza l’aria immessa nei cilindri
- Eliminazione delle perdite di pompaggio con una riduzione del consumo di carburante e delle emissioni di CO2 pari al 10%, sia nei motori naturalmente aspirati, sia in quelli sovralimentati della stessa cilindrata
- I motori Multiair sovralimentati e a cilindrata ridotta (concetto del “downsizing”) possono raggiungere una maggiore efficienza in termini di consumo di carburante pari al 25% rispetto ai motori naturalmente aspirati, mantenendo lo stesso livello di prestazioni
- L’ottimizzazione delle strategie di controllo delle valvole in fase di “warm-up” del motore e di ricircolo interno dei gas di scarico, ottenuta mediante la riapertura delle valvole di aspirazione durante la fase di scarico, genera una riduzione delle emissioni del 40% di HC/CO e 60% di NOx
- La pressione costante dell’aria a monte dei cilindri, atmosferica per i motori naturalmente aspirati e superiore per quelli sovralimentati, abbinata al controllo estremamente rapido della massa d’aria, cilindro per cilindro e colpo a colpo, produce una migliore risposta dinamica del motore.
6-   I primi motori...
La prima applicazione della tecnologia Multiair riguarderà i motori Fire 1400 cm3 16 valvole aspirato e turbocompresso.
La seconda applicazione è rappresentata da un nuovo motore a benzina 900 cm3 bicilindrico (SGE – Small Gasoline Engine), nel quale la progettazione della testa cilindri è stata ottimizzata specificamente per l’integrazione dell’attuatore Multiair. Anche in questo caso sarà disponibile nelle versioni aspirata e turbocompressa.
Sarà inoltre disponibile una speciale variante sovralimentata a doppio combustibile (benzina – metano).
Il motore bicilindrico sovralimentato a benzina, grazie alla drastica riduzione della cilindrata, raggiunge livelli di emissione di CO2 simili al Diesel, con un’ulteriore riduzione nella versione a metano, che presenta emissioni di CO2 inferiori a 80 g/km in molte applicazioni.
7-   Sviluppi futuri...
Tutte le tecnologie di “breaktrough” aprono un universo di ulteriori potenziali vantaggi, che di solito non possono essere sfruttati da subito, per ridurre al minimo i rischi industriali.
Il Common Rail, una “prima” mondiale Fiat del 1997, preparò la strada a più di dieci anni di ulteriori evoluzioni tecnologiche come il “Multijet” per le iniezioni multiple, i motori Diesel di cilindrata ridotta e la recentissima tecnologia di iniezione modulare che vedremo presto arrivare sul mercato.
La tecnologia Multiair, presentata in anteprima da Fiat nel 2009, preparerà il terreno a una serie di evoluzioni tecnologiche successive per i motori a benzina:
- Integrazione del controllo diretto della massa d’aria con l’iniezione diretta di benzina, per migliorare ulteriormente la risposta transitoria e il risparmio di combustibile
- Introduzione di avanzate strategie di apertura delle valvole multiple per ridurre ulteriormente le emissioni
- Turbocompressore innovativo per il controllo della massa d’aria intrappolata attraverso l’abbinamento di una pressione di alimentazione ottimale e di specifiche strategie di apertura delle valvole.
8-   Applicazione indipendente dal combustibile impiegato...
Mentre l’iniezione elettronica di benzina sviluppata negli anni Settanta e il Common Rail sviluppato negli anni Novanta erano tecnologie avanzate specificamente connesse ai combustibili, la tecnologia di controllo delle valvole Multiair può essere applicata ai motori a combustione interna indipendentemente dal combustibile utilizzato.
Il Multiair, inizialmente sviluppato per i motori ad accensione comandata che utilizzano combustibili leggeri come la benzina, il metano e l’idrogeno, ha in realtà un ampio potenziale di riduzione delle emissioni anche per i motori Diesel.
Con il ricircolo interno dei gas di scarico (iEGR) attraverso la riapertura delle valvole di aspirazione in fase di scarico, è possibile ottenere una riduzione degli NOx fino al 60%, mentre le strategie ottimali di controllo delle valvole in fase di avviamento a freddo e “warm-up” portano fino ad un 40% di abbattimento di HC e CO. Un’ulteriore sostanziale riduzione si ottiene poi da una più efficiente gestione e rigenerazione del filtro anti-particolato e del catalizzatore per l’immagazzinamento degli NOx, grazie ad un più dinamico controllo della massa d’aria in fase transitoria del motore.
I miglioramenti in termini di prestazioni ottenuti sul motore Diesel sono simili a quelli del motore a benzina, basandosi sugli stessi principi fisici, mentre il vantaggio in termini di consumo di combustibile è limitato a pochi punti percentuali per via delle basse perdite di pompaggio del motore Diesel, che costituiscono una delle ragioni della sua superiore efficienza.
In futuro, l’evoluzione tecnica dei motopropulsori potrebbe beneficiare di una progressiva unificazione delle architetture dei motori a benzina e Diesel.
È così possibile concepire e sviluppare una testa cilindri unificata, nella quale entrambi i sistemi di combustione possono essere pienamente ottimizzati senza necessità di compromessi. Inoltre, l’attuatore elettro-idraulico Multiair è fisicamente lo stesso, a parte una differenza minima di lavorazione, mentre i sottocomponenti interni sono tutti derivati dalle applicazioni Fire e SGE.
Offline fbajlo
  • Postova: 1040
« Odgovori #47 u: 19-03-2009, 12:27:16 »
a evo i web stranice za sve one koji žele znati više o multiairu...
http://www.fptmultiair.com/flash_multiair_eng/home.htm
ima i video clip koji prikazuje princip rada
  • Postova: 6230
« Odgovori #48 u: 23-05-2009, 15:41:05 »
Offline yedwy
  • Postova: 2103
  • Ford C-Max 1.8 duratec
    • Sesvete Zagreb
« Odgovori #49 u: 24-05-2009, 09:30:03 »
Nice prvo Twin Phaser a sad i Multiair, ljepe stvari se kuhaju kod fiat-a... :ok:
Offline LOŠA
  • Postova: 4432
  • Alfa Romeo Brera 2.0 JTDM
« Odgovori #50 u: 25-05-2009, 08:17:32 »
Da konačno je krenuo taj Multiair, a kažu da krajem godine u proizvodnju kreće i Multijet 2 :ok:
http://www.italiaspeed.com/2009/cars/others/fiat_powertrain/05/multiair_production/2305.html
  • Postova: 15308
« Odgovori #51 u: 25-05-2009, 08:25:08 »
sam kaj je twin phaser baziran na GM bloku ( JTS...) i zbog tog dreka su zatvorili alfinu proizvodnju blokova  :wal: :wal: :wal:
Offline fbajlo
  • Postova: 1040
« Odgovori #52 u: 19-02-2010, 09:29:15 »
Od ovog ljeta u ponudu dolazi i dvocilindarski  Twinair motor, za početak u Fiat 500.
Motor je zapremine 0,9 litara u tri varijante: 65ks (atmosferski), 85ks i 105ks (turbo). Emisija CO2 je kod svih varijanti manja od 100g/km a potrošnja bi trebala biti ispod 5l/km. Motor bi trebao postepeno zamjeniti Fire 1.2 i 1.4 motore u manjim modelima.
http://www.quattroruote.it/news/immaginebig_articolo.cfm?codiceimg=183599&codedicola=271203&codice=232167&codarticolo=232167&pagina=271203&tornaa=/news/articolo.cfm#gallery
  • Postova: 15308
« Odgovori #53 u: 19-02-2010, 09:37:42 »
NICE  :ok: Idem odmah nabaviti jedan od 85 ks za Punto
Offline fbajlo
  • Postova: 1040
« Odgovori #54 u: 11-03-2010, 09:19:54 »
Ekipa iz FPT izgleda ne namjerava prestati s novim motorima. Ovaj put najavljuju primjenu Multiair sustava na JTDm motorima, tako da se već sad može reći da će 1.6 JTDm sa Multiairom zadovoljavati Euro 6 normu koja stiže tek 2014. uz dodatno smanjenje potrošnje (doduše ne radi se o velikom padu potrošnje jer su sadašnji JTDm toliko efikasni da nema puno prostora za poboljšanja). O poboljšanju što se snage motora tiče još ništa ne govore. Prvi diesel multiair motori počet će se ugrađivati već 2012.
Također su priznali da su Multiair glave testirane i na mutorima Ferrari F1 bolida i Ferrari V8 iz F430 ali da rezultati na motorima bez turba nisu spektakularni, pogotovo u visokim okretajima te se za sada odustalo od njihove primjene.
« Zadnja izmjena: 11-03-2010, 09:23:03 od fbajlo »
Offline LOŠA
  • Postova: 4432
« Odgovori #55 u: 23-03-2010, 12:29:54 »
Evo vam budućeg V6 za Alfe: Chrysler Pentastar 3.6 V6 :rolll:
http://www.italiaspeed.com/2010/cars/industry/03/chrysler/2103_pentastar_v6_overview.html
Nije baš neko čudno tehnike, ne puca ni od snage ni od momenta, ni potrošnja nije baš posebno niska.
Ako Fiat ne želi novi fijasko kao sa GM 3.2 V6, trebali bi obavezno u taj motor ubaciti Multiar i turbinu...
  • Postova: 42943
« Odgovori #56 u: 21-07-2010, 22:04:58 »
Fiat 500 i 500C dobili novi TwinAir motor sa dva cilindra!
Fiat je konačno izbacio model pogonjen dugo najavljivanim dvocilindričnim motorom iz TwinAir obitelji.
Popularni Fiat 500 prvi je automobil koji će biti pogonjen novim TwinAir motorom sa dva cilindra. Isti će u dogledno vrijeme biti dostupan i uz modele Panda i Punto Evo.
Radi se o 0.9-litrenom agregatu, koji uz pomoć turbo punjača razvija 85 konjskih snaga pri 5500 o/min i 145 Nm okretnog momenta pri 1900 o/min. Isti je uparen s manualnim mjenjačem, a s vremenom će biti dostupan u nešto slabijem i snažnijem izdanju. Snaga će se kretati u rasponu od 65 do 105 konja. Fiat čak razmišlja i o tome da ga upari s elektromotorom i ponudi u hibridnoj varijanti.
Prosječna potrošnja iznosi svega 4 l/100 km
Ovako motoriziran, Fiat 500 do 100 km/h ubrzava za 11 sekundi i postiže maksimalnu brzinu od 173 km/h. Prosječna potrošnja iznosi 4.1 l/100 km, dok se razina štetnih emisija zaustavlja na svega 95 g C02/km. Ukoliko je automobil opremljen robotiziranim Dualogic mjenjačem, potrošnja se spušta na 4 litre, dok je razina štetnih emisija niža za 3 grama.
Model opremljen spomenutim mjenjačem dolazi i sa gumbom putem kojega vozač može odabrati dva različita režima vožnje - Normal i ECO. U potonjem modu okretni moment je reduciran na 100 Nm.
Kompaktniji, lakši, snažniji, štedljiviji,...
Kako navode u Fiatu, 0.9-litreni TwinAir motor je 23% kraći i 10% lakši od četverocilindričnog motora sličnih performansi, dok je prosječna potrošnja manja za nemalih 30%. Usporedivši ga s 1.2-litrenim 8V motorom, Fiat ističe kako je novi stroj 23% snažniji, te kako nudi 30% bolje performanse.
Inovativni agregat implementira nekoliko tehnologija, uključujući turbo punjač nešto skromnijih dimenzija, zatim start-stop sustav i MultiAir elektro-hidraulični sustav upravljanja radom ventila, koji dodatno smanjuje potrošnju goriva, a time i razinu štetnih emisija.
Razvoj motora potpisuje FPT (Fiat Powertrain Technologies).
Offline Delta S4
  • Postova: 629
« Odgovori #57 u: 22-07-2010, 13:41:01 »
Ja bi to! 105 konja u pandi :love3: Znaš li možda koliki je predviđeni životni vijek?
Offline Toxy
  • Postova: 292
    • Zagreb - Jarun
« Odgovori #58 u: 16-08-2010, 10:12:39 »
U nekom auto časopisu sam pročitao da bi kao trebao preći 250 tkm bez otvaranja, tako barem pišu, a vrijeme će pokazati... :mah:
Offline Delta S4
  • Postova: 629
« Odgovori #59 u: 16-08-2010, 11:42:47 »
To je poštena cifra kilometara za dva cilindra  :ok: Mislim da je toliko predviđeno i za 1.3 JTD.
