Tapecirung sam skidao prema uputama iz Workshop manuala, nisam provlačio kablove za pojačalo i sub jer me to "prošlo" nakon 33-ice u kojoj sam imao kW mjuze
. No, zato sam vadio kabel od CD changera koji sam deinstalirao, a prolazio je kroz centralni tunel. To traži skidanje centralne konzole, a to je nezgodan i dugotrajan posao. Nešto gurati kroz taj kanal nazad bi bilo još teže, ali valjda moguće.
Upute za skinuti P1 konzolu su ovo:
I have just done this for a couple of days ago... Lots of patience, very gentle and room tempereature is what you need. Roomtempereature? Yepp here in Sweden with -15 degrees the plastic will crack only by looking at it. Any way, here we go.
First remove the two covers on each side of the middle console, the covers are beside the leggs( feet). Two screws on the drivers side, two screws and a nut on the passenger side. Once the covers are away you will see two screws holding on the the lower middle console ( the one surrounding the shifter and so ...): Unscrew them. Then gently, lift upp the ashtray and you will find a screw under it. Unscrew. Then pull off the plastic piece holding the headlight adjustment and the sunroof manovering switch, you will find a screw there too. So, all in all 4 screws holding this part. Then lift up the back end ocf the console and pull it out. Do not forget to loosen the lether cover surrounding the shifter.
Once this part is away, you will see two screws holding the lower end of the upper middle console. Unscrew. Pull out the Stereo. Pull off the fan manovering knobs. Underneath you will see three tiny screws, one under each knob. Unscrew. Then gently pull out the ventilationpiece at the top of the console. Here you will find two more screws. Unscrew. All in all seven screws for this part. GENTLY pull back the console. Be carefull to dissconnect the wires on the the backside of the console before you totaly pull it away.
I hope this wxplanation can help. The toughest part to remove is the ventilation piece, but it is not impossible.
Good Luck..
