09-06-2026, 20:20:12
Autor Tema: Alfa Romeo Scarabeo  (Posjeta: 2085 vremena)
Offline Sizif
  • Postova: 1359
  • Accord coupe V6
    • Sizifova 166 2.5 V6 24V
Alfa Romeo Scarabeo
« u: 22-04-2012, 19:49:58 »
Prvi 8c  :?:
 It might have had its chances for production snatched away in favour of other projects, but the Alfa Romeo Scarabeo was so innovative that it gave the legendary Tipo 33 racing car some of its pioneering features.
Project Scarabeo came about in the mid-1960s, when Alfa Romeo was developing a racing prototype with a view to returning to major competition, following its withdrawal in 1953. Thanks to an improved financial position resulting from the sales success of the Giulietta in its various forms, the company had the means to continue from where the development of the stillborn Tipo 160 Grand Prix prototype of 1954 had left off.
 The racing prototype sat on an H-shaped chassis, three of which were sent – along with a Giulia GTA engine – to OSI of Turin, which was a subsidiary of Ghia. Each chassis was given different bodywork and a slightly different seating position; one of the principles that the Scarabeo explored was to have the driver seated as far back in the car as possible. The idea had been suggested in the fifties by works driver Consalvo Sanesi, and was intended to give the driver a better position from which to assess the behaviour of – and thus to control – the car.
 The Scarabeo with seats furthest back was the silver coupé that debuted at the 1966 Paris Motor Show – also note the different bodywork from the yellow car. A third, spider version was built as a test mule (thought to have used the exact chassis of the racing prototype) and its bodywork was never completed. Unlike its siblings, the silver coupé was built with right-hand drive, necessitated by the positioning of the rear-mounted engine’s carburettors. They were located just behind the headrest of the seat on the left-hand side of the car, with the occupant only protected from deafness by a thin sheet of Perspex.
 Although the Scarabeo concept’s mechanical elements were advanced enough to be used in the prestigious Tipo 33, it seemed there was not a good enough business case to conclude its development with a small production run, as was originally intended. Of the three Scarabeos built, two remain in Alfa’s collezione storica, while the silver coupé escaped and is thought to be in a private collection in Canada.
Svaki Alfista je Sizif...
Offline Sizif
  • Postova: 1359
  • Accord coupe V6
Odg: Alfa Romeo Scarabeo
« Odgovori #1 u: 22-04-2012, 19:50:43 »
Offline Sizif
  • Postova: 1359
  • Accord coupe V6
« Odgovori #2 u: 22-04-2012, 19:51:18 »
moj-auto
« Odgovori #3 u: 30-05-2012, 10:09:44 »
Motor je bio 1.6 snage 115KS i sa 700 kg postizao 200km/h ako se dobro sjećam
  • Postova: 42942
« Odgovori #4 u: 29-11-2019, 19:16:02 »
L'ALFA ROMEO SCARABEO ESPOSTA ALLO CHATEAU DE COMPIEGNE Inaugurata presso l’affascinante Musée National de la Voiture a Compiègne (Francia), la mostra “Concept-car. Beauté pure” che illustra l'evoluzione del fenomeno delle concept-cars a partire dalle sue origini fino agli anni 70 del XX secolo. Tra gli esemplari in esposizione la rarissima Alfa Romeo Scarabeo (1966) di FCA Heritage. All’alba del 1966, dopo che il progetto della Tipo 33, nato dal team dell’ing. Orazio Satta Puliga, viene ceduto all’Autodelta, Giuseppe Busso propone il progetto di un’altra vettura sportiva Alfa Romeo a motore posteriore, ma che utilizzi il motore quattro cilindri della GTA: la Scarabeo. Il propulsore, di 1.570 cc con una potenza di 115 cv in grado di spingere la vettura di 700 kg fino a 200 km/h, viene installato trasversalmente al posteriore, in blocco con frizione e cambio, mentre il telaio tubolare riprende l’ambiziosa soluzione – vista proprio sulla 33 – dei grossi longheroni tubolari ai lati dell’abitacolo, contenenti i serbatoi del carburante. Lo studio della carrozzeria viene affidato alla carrozzeria OSI di Borgaro Torinese: un primo esemplare, con guida a destra, viene presentato al Salone di Parigi nell’ottobre 1966 e successivamente vengono costruiti un secondo prototipo dal disegno semplificato – la vettura attualmente in esposizione a Compiègne – e una barchetta, che però non viene completata.
  • Postova: 42942
« Odgovori #5 u: 29-04-2024, 19:18:42 »
