Evo link sa uputama kompletnim za Alfu 166 na Engleskom
http://public.download.fedv.eu/166user.zip. Prema ovim uputama znakic je nesto drugaciji, ali buduci sam i sam imao Alfu 166 2.0 TS ako se dobro sjecam to je upravo ovo
Engine control system
(EOBD) failure (versions in
compliance with Directive
98/69/EC – EURO3 or Directive
2001/1/EC level B – EURO4)
Normally, when you turn the ignition
key to MAR, the warning light must
come on but must switch off when the
engine is running. It initially lights up to
indicate that the warning light is working.
If the warning light stays on permanently
or comes on when the car is moving:
1) With a fixed light - indicates
that the supply/ ignition system is malfunctioning
that could cause high exhaust
emissions, possible loss of performance,
bad driveability and high consumptions.
In these conditions, you way continue
to drive while avoiding asking a lot from
the engine or high speeds. The prolonged
use of the car when this warning light is
on could cause damage. Contact an Alfa
Romeo Authorized Service Station as
soon as possible. The warning light turns
off if the malfunction disappears, however
the system stores the warning anyhow.U
2) Flashing light - indicates that the
catalytic converter could be damaged
(see paragraph on “Engine control system
(EOBD)” in this chapter).
If the warning light is on and flashing,
take your foot off the accelerator and drive
at low speeds until the warning light
stops flashing; continue travelling at a
moderate speed trying to avoid driving
conditions that could cause the warning
light to flash again. Contact an Alfa
soon as possible.
