07-04-2020, 17:48:29
Autor Tema: Voda u kabini  (Posjeta: 22924 vremena)
  • Postova: 6180
  • 156 2.0 JTS TI SS & 75 3.0 12v & 595 Competizione
Voda u kabini
« u: 03-07-2008, 01:17:10 »
eto imam problema sa vodom koja se skuplja kod suvozacevih nogu. kisa nije padala sigurno, nevjerujem da je od vode za stakla jer bi imala onaj miris tako da mi ostaje samo sumnja da nije to onaj kondezat od klime.. uglavnom sad vec ima dosta te vode jer je klima radila skoro 30 sati bez stati jucer i prekjucer i sad to vec i smrducka. jel moguce da to ima ikakve veze sa klimom ili da provjerim nesto trece? auto je 156 iz 12/03
CUPO V6
Odg: voda u kabini..
« Odgovori #1 u: 03-07-2008, 07:30:24 »
moze bit samo kond. voda od klime to je u njih bice normalno kad sam sebi trazio 156 cu jedna je toliko istrula ispod sica da ne znam kako sic nije ispao
pa sam citao po njemackom forumu da ih ajme ima
u kratko kako su to rijesavali
mislim da ces morat inst. tablu tablu izvadit da bi crijevo za kond. sproveo pravom putu
Offline Zvonimir
  • Postova: 794
  • Giulietta 2.0
    • Zagreb-zapad
« Odgovori #2 u: 03-07-2008, 10:37:29 »
Offline Zvonimir
  • Postova: 794
  • Giulietta 2.0
    • Zagreb-zapad
« Odgovori #3 u: 03-07-2008, 13:35:18 »
imaš na tom linku i dio teksta koji govori o vodi iz klime
evo cp
e)
Condensing water from the drain of the climate control unit:
- Incorrect placed drain so water runs out on the floor.
- Drain blocked. Water could fill up the climate control housing to finally run out on the floor.
- Faulty unit housing
Testing is easy: Run the engine for about 20 min. with climate control activated. If there is no wet spot under the car, you know where the water is.  :-(
I one case I have seen some fault in the plastic housing surrounding the whole unit.
The lower part of the unit contains two chambers: One to build up condensing water and leading it to the drains. Another that should be dry at all times.
If condensing water gets in to the “dry” chamber, it would eventually overflow and run into the cabin.
A successfully repair is seen by drilling holes between the 2 chambers so that water never builds up in the “dry” chamber. Some silicone sealing were also added inside the housing corners just in case of plastic damage.
Disassembling of the unit for outside testing and repair needs disassembling of the whole fascia panel, which takes about 3 hours at the garage and the same for assembling
Tim Devloo wrote:
In my case the problem was that in the motorcompartment, the drain that lets out the condenswater was blocked off because of the rubber pipe that aims downwards.
It is mentionned in a service news of 98 distribuated by the Fiat-group to all dealers.
According to yhe service news you should take a tube and cut it in a way and get it over the condenstube as far as possible. You can only get it fot about 1 cm over the other one and it has no other effect than not putting this on!
So i just made a cut with a a sharp knife so the hole isn't pressed any more by the rubber. This isn't the way how it is mentionned in the service news, simply because their explenation doesn't match with reality. According to yhe service news you should take a tube and cut it in a way and get it over the condenstube as far as possible. You can only get it fot about 1 cm over the other oneand it has no other effect than not putting this on!
Offline DOVLA
  • Član Alfa Kluba 3
  • Postova: 1682
  • 156 sw 1.9jtd Ti
    • zagreb,đubrava
« Odgovori #4 u: 06-07-2008, 12:25:23 »
vjerovatno ti je prdnuo mali hladnjak za grijanje nalazi se ispod armature,pogledaj vodu u posudi moguće da ti fali :mah:
Offline DOVLA
  • Član Alfa Kluba 3
  • Postova: 1682
  • 156 sw 1.9jtd Ti
    • zagreb,đubrava
« Odgovori #5 u: 08-07-2008, 00:03:49 »
u koju posudu? ono za hladenje motora? evo nisam palio klimu par dana osim na kratko i nema nikakve vode. sutra sestru vozim za rijeku i drzat cu upaljenu klimu pa cu vidjeti sta ce se desiti, ako se oped pojavi voda, znam bar od cega je.
posuda za hlađenje motora pogledaj kad je hladan motor dali ti fali ako da onda je hladnjak grijanja rikno ili vidi to sa klimom.. :mah:
CUPO V6
« Odgovori #6 u: 08-07-2008, 10:54:49 »
da je tekucina za hladenje osjetio bi se miris antifriza
ja ipak mislim da je od klime cim je ukljucena tepih natopljen  :)
Offline reddevill
  • Postova: 9515
  • 147 1.6 TS , BMW E60
    • Njemacka - Stuttgart
« Odgovori #7 u: 08-07-2008, 11:40:52 »
vjerojatno nije dobro sijelo crijevo od kondenze vode za klimu pa negdje kaplje voda, treba pogledati i crijevo dali je dobro sijelo.
sokre1983
Voda u kabini
« Odgovori #8 u: 09-02-2009, 23:56:05 »
halo ljudi!!!!
bas kak i pise imam baru u autu kad god kisa pada! :wal: i to samo ispod vozavevog tepiha ali doslovno se stvori bara...e sad jel bi ima ko kakvu ideju kak voda curi nutra jer sam gledal po svim stranama i nigdje jojj puta nisam naso...usput auto je bil iza razbijen pa zadnja ljeva sajba ni dobro zaljepljena al mislim da nije od tam a kad ga perem ne curi neg mora duze vrijeme bit na kisi :mad: :mad: :mad: jel moze bit sa antene gore? :?: nemam vise ideje....ak je neko imal slican problem pliz help!!!!!!!
Offline Dalibor-L
  • Postova: 2383
Odg: voda u kabini
« Odgovori #9 u: 10-02-2009, 15:58:44 »
Očigledno ti se zaštopao odvod pa curi-prelijeva kroz rupu di bi trebao bit filter. Nakupi se lišća i svačeg. Moraš skinut vanjsku plastiku ispod šajbe i vidit. Ali laganini jel kopče pucaju ko repa.
  • Postova: 15288
  • 164 TS
Odg: voda u kabini
« Odgovori #10 u: 10-02-2009, 18:06:21 »
meni je vlažno iza vozačkog sica. ne znam kak jer odozdola niej niš trulo jedino ak nije ispod plastičnog praga đumbus.
sokre1983
Odg: voda u kabini
« Odgovori #11 u: 10-02-2009, 18:32:26 »
moglo bi biti ja se nadam jer mi i tapecirung zna biti iznad vozaca na spoju s palastikom,znaci sami ljevi kut gore malo mokar...pa sad neznam
Milan
Odg: voda u kabini
« Odgovori #12 u: 10-02-2009, 18:33:28 »
pitaj fiumana...on je to uspjesno rijesio :ok:
  • Postova: 15288
  • 164 TS
Odg: voda u kabini
« Odgovori #13 u: 10-02-2009, 18:35:47 »
@šokre1983 vjerojatno ti curi kod antene, za to skini onaj dio sa svjetlom na krovu i vidi jel ti vlažno tam na rupi, vjerojatno vlaga ide uz žicu od antene.
sokre1983
Odg: voda u kabini
« Odgovori #14 u: 10-02-2009, 18:39:23 »
hvala decki budem probao ove dvije ideje realizirat i ak rijesim problem cuga je na mene....kad se sretnemo na nekom meetu  :pivo:
Offline gogo
  • Postova: 177
  • ALFA ROMEO 145 BOXER , 156
    • OGULIN
Odg: voda u kabini
« Odgovori #15 u: 11-02-2009, 10:19:19 »
odvod je zaštopan  :da:
gogo
Dule
Odg: voda u kabini
« Odgovori #16 u: 11-02-2009, 11:59:27 »
mene je prosle godine dva puta docekala bara u autu, ista stvar, vozaceva strana plivala u vodi, mislio sam da je stvar u shiberu, posto sam ga jednom vidio da curi iz plastike koja pokriva stok vrata... htio sam ocistit odvod sibera ali cjevcica od odvoda ide u stok od vrata tako da nisam imao ideju kako...
a problem je u meduvremenu jednostavno nestao...  :?:
Offline gogo
  • Postova: 177
    • OGULIN
Odg: voda u kabini
« Odgovori #17 u: 11-02-2009, 13:23:36 »
jednostavno sa godinama se sakupi smeča i zaštopa odvode iz kanala di je motorić  brisača meni je zbog toga motorić bio sav u vodi i riknuo a voda je uredno curila u auto   :wal: očistio odvode i problem rješen :da:
gogo
Offline Viktor
  • Trade Count: (+21)
  • Postova: 9224
Odg: voda u kabini
« Odgovori #18 u: 12-02-2009, 09:30:16 »
Za početak probiti rupicu u podu da opane vodostaj.
  • Postova: 4996
  • Fiat GP 1.4
« Odgovori #19 u: 11-10-2009, 15:09:28 »
Evo oživljavam temu jer sam od jučer primjetio isto da mi je suvozačev tepih mokar.
Mrlja je na tepihu i da je od vode vjerovatno bi se posušila.Ispod ladice je sve vlažno .
I skužio sam da je i tapecirung mokar više prema vratima sa strane .
Možda neko zna nešto više o tome :?:
