03-12-2024, 21:53:15
Autor Tema: Maserati Buran  (Posjeta: 1373 vremena)
  • Postova: 41796
Maserati Buran
« u: 07-01-2007, 09:27:25 »
  • Postova: 41796
Odg: Maserati Buran
« Odgovori #1 u: 07-01-2007, 09:35:09 »
Type   4/5S HBK
Designer   Giugiaro
Number of doors    3
Wheelbase    2930 mm    115.4 in
Track    front
rear
Length    4983 mm    196.2 in
Width    1950 mm    76.8 in
Height    1630 mm    64.2 in
Length:wheelbase ratio    1.7
Manufacturer    Maserati
Type    V-8
DOHC
32 valves total
4 valves per cylinder
Main bearings
Construction
Bore × stroke    80.00mm × 80.00mm
3.15 in × 3.15 in
Bore/Stroke ratio    1
Displacement    3217 cc
(196.313 cu in)
Unitary capacity    402.13 cc/cylinder
Compression ratio    8.00:1
Fuel system    Magneti Marelli 4CM fuel inj.
Aspiration    Turbo
Compressor type    2 turbochargers
Intercooler
Catalytic Converter    Y
Max. output
(DIN)    375.1 PS (370.0 bhp) (275.9 kW)
@6250 rpm
Max. torque
(DIN)    491.0 Nm (362 lbft) (50.1 kgm)
@4500 rpm
Maximum rpm
Coolant    Water
Specific output    115 bhp/litre
1.88 bhp/cu in
Specific torque    152.63 Nm/litre
alfetta
Odg: Maserati Buran
« Odgovori #2 u: 07-01-2007, 18:32:59 »
Di si ovo naša???
Je li mi se čini ili stvarno ima jedna klizna "šiber" vrata???
Offline veron
  • Postova: 903
  • Doblo JTD
Odg: Maserati Buran
« Odgovori #3 u: 08-01-2007, 00:18:50 »
 :clap: :clap:
Offline Narayan
  • Postova: 3415
  • The One and Only
Odg: Maserati Buran
« Odgovori #4 u: 08-01-2007, 11:50:31 »
Jos samo da Ferrari pocne proizvodit "peglice" :hehe:
Offline Dama 166
  • Postova: 3780
    • Njemacka, Stuttgart
Odg: Maserati Buran
« Odgovori #5 u: 15-01-2007, 12:35:59 »
 :?: :?: :?: :wal: :wal:, ovo bas nikako meni barem pod kapu. Od naprijed jos nekako, al zadnji dio  :puke:
« Zadnja izmjena: 15-01-2007, 12:36:50 od Dama 166 »
Offline GoGGY-ARC
  • Postova: 109
Odg: Maserati Buran
« Odgovori #6 u: 22-02-2007, 11:11:06 »
Najružniji Maserati ikad.
Offline haky
  • Postova: 491
  • lancia y-GT
    • ZAGABRIA-sesvete
Odg: Maserati Buran
« Odgovori #7 u: 20-02-2010, 14:37:17 »
 :puke: :puke: :puke:
VOLIM SVE ŠTO MLADI VOLE
Offline gturcic
  • Postova: 220
  • Fiat Coupe 20vt+ / Lancia Delta 1.9mjeTT
Odg: Maserati Buran
« Odgovori #8 u: 11-04-2013, 13:22:31 »
Izgleda slično Fiatu Cromi i Stilu s 5 vrata.
Budući da je Grande Punto "kopirao" prednji kraj Maseratija 3200GT / Coupe, možda slijedeća Linea ili Marea bude ličila Quattroporteu  :hehe:
