I još uvijek nemamo nikoga s novim autom ili Mopar Map Care pretplatom tko je instalirao zadnju mapu?
Zašto gnjavim oko toga - jer je sam sustav složen tako (blesavo) da nema mogućnost za downgrade, a već sam jednom instalirao mapu koja je imala grešku i ne prikazivala kamere. Kako predzadnja radi uredno, sada me strah da ova zadnja slučajno nema to opet polomljeno.
"No, it's generally not possible to revert the navigation maps to an older version on the Alfa Romeo Giulia.The map update process (via USB from official sites like Mopar or Stellantis navshop) includes a built-in check that prevents installing an older map version. The system typically displays an error message like "not newer than the current installed version" or "the map on the stick is older than that on the car" if you try to load previous maps.This issue has been reported multiple times on owner forums (e.g., giuliaforums.com and alfaowner.com), including cases where a buggy new update (like a partial-coverage Europe map) was released, and users wanted to downgrade but couldn't. In those situations, the only resolutions were waiting for a fixed newer version or using unofficial sources for corrected files—not official older ones.Alfa Romeo provides free map updates for a period (often several years), but the system is designed for forward updates only. If you've encountered issues with a recent update, contacting an Alfa dealer or checking the official map portal for the latest corrected version is the recommended path. Some older infotainment firmware had a "restore software" option, but that's for system software, not maps, and it doesn't reliably allow map reversion either."
