09-06-2026, 19:01:55
Autor Tema: Alfa 156 TS getriba / omjeri brzina  (Posjeta: 1031 vremena)
Offline White156
  • Postova: 9
« u: 10-07-2023, 11:40:41 »
Rasipo mi se mjenjac na mojoj 1.8ts, probilo mi rupu u getribi i sve se polomilo. Zna li netko pasu li getribe 1.6/1.8/2.0? Ima li netko tablicu sa omjerima brzina za te modele? Koliko sam gledo i cuo 1.6 i 2.0 imaju iste getribe, a 1.8 ima razlicito. Jel itko stavljao na 1.8 getribu od 1.6 i 2.0 i obrnuto?
Ovdje sam nasao neke brojke sad neznam kak bi to bilo u praksi?
GEARBOX 1.6
Transmission   Manual
Number of gears   5
1st gear ratio   3,91:1
2nd gear ratio   2,24:1
3th gear ratio   1,52:1
4th gear ratio   1,16:1
5th gear ratio   0,97:1
6th gear ratio   -
7th gear ratio   -
8th gear ratio   -
9th gear ratio   -
Reverse gear ratio   3,91:1
Final drive   3,73:1
GEARBOX 1.8 106kw
Transmission   Manual
Number of gears   5
5th gear ratio   0,92:1
6th gear ratio   -
7th gear ratio   -
8th gear ratio   -
9th gear ratio   -
Final drive   3,73:1
GEARBOX 2.0 114kw
Transmission   Manual
Number of gears   5
1st gear ratio   3,55:1
5th gear ratio   0,95:1
6th gear ratio   -
7th gear ratio   -
8th gear ratio   -
9th gear ratio   -
Final drive   3,56:1
Ovdje sam naso te podatke:
https://car-lib.com/en/Alfa-Romeo/156/1997/Sedan/4-door/
  • Postova: 5868
Odg: Alfa 156 TS getriba / omjeri brzina
« Odgovori #1 u: 10-07-2023, 13:35:08 »
2.0 ima najduzu i to 156
2.0 147 ima kracu
1.8 kraca
1.6 kraca od 1.8
1.4 kraca od 1.6
Offline White156
  • Postova: 9
« Odgovori #2 u: 10-07-2023, 18:57:05 »
Onda je svaka brzina na 1.6 npr kraca od svake na 2.0 a ne samo zadnja? To bi mi cak i bilo oke zato sto mi ima stvarno predugacke brzine, znaci dobio bi ubrzanje malo bolje ali izgubio krajnju brzinu da stavim 1.6 getribu. Jedino me brine u 5. na autoputu mi je na 130km/h vec bila na skoro 4k okretaja ako se dobro sjecam. Sta cu sad bit na 130km/h na skoro 5k okretaja  :hmmm:
Offline White156
  • Postova: 9
« Odgovori #3 u: 29-07-2023, 21:16:49 »
Evo ako ikog zanima getriba 1.6 je na autu. 1. 2. 3. 4. nisam osjetio ama bas nikakvu razliku i dalje mi je 2. jaaako dugacka. Jedino 5. Osjetim da je kraca na 130km/h sam na 4k tocno, na 160km/h sam na 5k tocno.
Offline SBAlfista
  • Postova: 1552
    • Slavonski Brod
« Odgovori #4 u: 31-07-2023, 16:03:40 »
Vjerujem da je ista stvar ko i u 146. Kombinacija 1.6/1.6 u petoj na 6900 ide 220
« Zadnja izmjena: 31-07-2023, 16:04:31 od SBAlfista »
